  4. [Dev] Inheritance in MQTT templates?
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
40 Posts 4 Posters 12.0k Views 4 Watching
      Sounds great!
      I thought of something like this when creating templates for combined humidity & temperature sensors where I in some locations want humidity as primary attribute and other temperature, this generates duplicate templates bundled in the same file and the only difference is the primary_attribute or is this doable with the requires: key already?
      Base files for devices using the same keys would ease things up and could simply be included in a bundled zip file.
        It's already done. Great minds think alike. I did it a couple of weeks ago, haven't released it yet. I also broke things out so that the templates can be spread out across any kind of directory structure you want to create.
        I'll push it up for you.
          @toggledbits Thanks for the quick build. I've updated to the latest version of MQTTController and I'll soon update my templates. I've found a minor problem related to custom capabilities.
          In previous iteration, it was tolerated, but now it's emitting an arror (Configuration for X is incomplete because the following requested capabilities are unrecognized: Y).
          Is there a way to define and pack definitions of capabilities with custom templates? Otherwise, I'll have to find an alternative way for my shelly_hem.yaml, because I must expose 2 energy sensors in one device (one for imported, the other for exported KwH). Thanks.
            What is/are the capabilties?
              it's a custom one, just to have two values:
              https://github.com/dbochicchio/reactor-mqtt-contrib/blob/main/shelly_hem.yaml#L59-L63
                Yes, yes, I've already looked at the definition in Github, I need you to be more specific. What are the names you redacted at Y in your previous post.
                  @toggledbits oh, my bad. I'll try to re-pro again when home, but it should be x_energy_sensor_exported for Y and the device name for X.
                    OK. That helps. And problem understood. I think I have an answer. New build later today.
                      OK. MQTTController build 24144 up. Adds support for a capabilities section at the top level of any template file. Format is same as for system_capabilities.yaml. See MQTTController docs, updated.
                        That’s huge! Thank you!
                          Ok, version 24146 of my templates is now ready, refactored with this new feature and starting to include Shelly Gen 3 (I've also used a couple of system templates as base).
                          The only minor thing is that if I have a primary_attribute defined in a template, MQTTController will not use the last one in the hierarchy, but the first one, and complain. Maybe just a brief note on the docs to highlight this.
                            Quick question, looking at MQTTController integrated templates for Shelly, they are in separate files. Is it possible to define all these in one yaml file? Because I'm trying to do that for common Zigbee2MQTT capabilities and getting errors in the log that I can't figure out why. If not possible I get it but if it is possible I will elaborate my issue.
                              Yes, it's possible.
                                Yes, it's possible.
                                OK, here goes.
                                [1/2]
                                Reactor latest-24152 bare metal.
                                MQTTController 24144.
                                I can't figure this out
                                "MQTTController:CRIT ReferenceError: Capability string_sensor not extended (mosquitto-mqtt>sovrumsdorr [-]"
                                reactor.log
                                [latest-24152]2024-06-05T20:20:25.153Z <app:null> Reactor build latest-24152-3455578a starting on v20.13.1 /usr/local/bin/node
                                [latest-24152]2024-06-05T20:20:25.153Z <app:null> Process ID 317180 user/group 1000/1000; bare-metal; platform linux/x64 #117-Ubuntu SMP Fri Apr 26 12:26:49 UTC 2024; locale sv_SE.utf8
                                [latest-24152]2024-06-05T20:20:25.154Z <app:null> Basedir /home/homebridge/reactor; data in /home/homebridge/reactor/storage
                                [latest-24152]2024-06-05T20:20:25.154Z <app:null> NODE_PATH=/home/homebridge/reactor
                                [latest-24152]2024-06-05T20:20:25.169Z <app:null> Resolved timezone=Europe/Stockholm, environment TZ=(undefined); offset minutes from UTC=120
                                [latest-24152]2024-06-05T20:20:25.171Z <app:null> Configured locale sv-SE; selected locale(s) sv-SE
                                [latest-24152]2024-06-05T20:20:25.177Z <app:null> Loaded locale sv-SE for sv-SE
                                [latest-24152]2024-06-05T20:20:25.178Z <app:null> Local date/time using configured timezone and locale formatting is "2024-06-05 22:20:25"
                                [latest-24152]2024-06-05T20:20:25.180Z <Structure:null> Module Structure v24110
                                [latest-24152]2024-06-05T20:20:25.181Z <Capabilities:null> Module Capabilities v23331
                                [latest-24152]2024-06-05T20:20:25.191Z <Capabilities:NOTICE> System capabilities loaded from core distribution, data version 24108 revision 1
                                [latest-24152]2024-06-05T20:20:25.197Z <Plugin:null> Module Plugin v22300
                                [latest-24152]2024-06-05T20:20:25.214Z <TimerBroker:null> Module TimerBroker v22283
                                [latest-24152]2024-06-05T20:20:25.216Z <Entity:null> Module Entity v24138
                                [latest-24152]2024-06-05T20:20:25.218Z <Controller:null> Module Controller v24099
                                [latest-24152]2024-06-05T20:20:25.232Z <default:null> Module Ruleset v24099
                                [latest-24152]2024-06-05T20:20:25.232Z <default:null> Module Rulesets v24099
                                [latest-24152]2024-06-05T20:20:25.250Z <GlobalExpression:null> Module GlobalExpression v24099
                                [latest-24152]2024-06-05T20:20:25.275Z <Predicate:null> Module Predicate v23093
                                [latest-24152]2024-06-05T20:20:25.277Z <AlertManager:null> Module AlertManager v24099
                                [latest-24152]2024-06-05T20:20:25.278Z <Rule:null> Module Rule v24149
                                [latest-24152]2024-06-05T20:20:25.280Z <GlobalReaction:null> Module GlobalReaction v24099
                                [latest-24152]2024-06-05T20:20:25.289Z <Engine:null> Module Engine v24113
                                [latest-24152]2024-06-05T20:20:25.292Z <httpapi:null> Module httpapi v24148
                                [latest-24152]2024-06-05T20:20:25.298Z <wsapi:null> Module wsapi v24148
                                [latest-24152]2024-06-05T20:20:25.299Z <app:NOTICE> Starting Structure...
                                [latest-24152]2024-06-05T20:20:25.308Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
                                [latest-24152]2024-06-05T20:20:25.331Z <TaskQueue:null> Module TaskQueue 24138
                                [latest-24152]2024-06-05T20:20:25.332Z <VeraController:null> Module VeraController v24050
                                [latest-24152]2024-06-05T20:20:25.375Z <Structure:INFO> Structure#1 loading controller interface ezlo (EzloController)
                                [latest-24152]2024-06-05T20:20:25.381Z <EzloController:null> Module EzloController v23345
                                [latest-24152]2024-06-05T20:20:25.384Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                                [latest-24152]2024-06-05T20:20:25.386Z <DynamicGroupController:null> Module DynamicGroupController v24128
                                [latest-24152]2024-06-05T20:20:25.390Z <Structure:INFO> Structure#1 loading controller interface virtual (VirtualEntityController)
                                [latest-24152]2024-06-05T20:20:25.393Z <VirtualEntityController:null> Module VirtualEntityController v24147
                                [latest-24152]2024-06-05T20:20:25.395Z <Structure:INFO> Structure#1 loading controller interface hass (HassController)
                                [latest-24152]2024-06-05T20:20:25.399Z <HassController:null> Module HassController v24146
                                [latest-24152]2024-06-05T20:20:25.450Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                                [latest-24152]2024-06-05T20:20:25.452Z <SystemController:null> Module SystemController v24076
                                [latest-24152]2024-06-05T20:20:25.453Z <Structure:INFO> Structure#1 loading controller interface scheman (ScheduleController)
                                [latest-24152]2024-06-05T20:20:25.455Z <ScheduleController:null> Module ScheduleController v24097
                                [latest-24152]2024-06-05T20:20:25.455Z <Controller:INFO> Loaded ScheduleController version "0.1.24097"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com>
                                [latest-24152]2024-06-05T20:20:25.456Z <Structure:INFO> Structure#1 loading controller interface mosquitto-mqtt (MQTTController)
                                [latest-24152]2024-06-05T20:20:25.459Z <MQTTController:null> Module MQTTController v24144
                                [latest-24152]2024-06-05T20:20:25.491Z <Controller:INFO> Loaded MQTTController version "0.2.24144"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/MQTTController/
                                [latest-24152]2024-06-05T20:20:25.503Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
                                [latest-24152]2024-06-05T20:20:25.503Z <Controller:INFO> Loaded MQTTController version "0.2.24144"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/MQTTController/
                                [latest-24152]2024-06-05T20:20:25.507Z <Structure:INFO> Starting controller VeraController#vera
                                [latest-24152]2024-06-05T20:20:25.507Z <VeraController:NOTICE> VeraController#vera starting...
                                [latest-24152]2024-06-05T20:20:25.510Z <Controller:INFO> VeraController#vera loaded vera capabilities ver 22253 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.521Z <Controller:INFO> VeraController#vera loaded implementation data ver 23109 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.521Z <Structure:INFO> Starting controller EzloController#ezlo
                                [latest-24152]2024-06-05T20:20:25.523Z <Controller:INFO> EzloController#ezlo loaded ezlo capabilities ver 22266 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.528Z <Controller:INFO> EzloController#ezlo loaded implementation data ver 22344 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.528Z <Structure:INFO> Starting controller DynamicGroupController#groups
                                [latest-24152]2024-06-05T20:20:25.530Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
                                [latest-24152]2024-06-05T20:20:25.530Z <Structure:INFO> Starting controller VirtualEntityController#virtual
                                [latest-24152]2024-06-05T20:20:25.531Z <Controller:INFO> VirtualEntityController#virtual loaded virtualentity capabilities ver 22263 rev 2 format 1
                                [latest-24152]2024-06-05T20:20:25.532Z <Controller:INFO> VirtualEntityController#virtual loaded implementation data ver 22280 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.532Z <Structure:INFO> Starting controller HassController#hass
                                [latest-24152]2024-06-05T20:20:25.532Z <HassController:NOTICE> HassController#hass starting...
                                [latest-24152]2024-06-05T20:20:25.533Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23289 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.536Z <Controller:INFO> HassController#hass loaded implementation data ver 24146 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.536Z <Structure:INFO> Starting controller SystemController#reactor_system
                                [latest-24152]2024-06-05T20:20:25.537Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                                [latest-24152]2024-06-05T20:20:25.580Z <Structure:INFO> Starting controller ScheduleController#scheman
                                [latest-24152]2024-06-05T20:20:25.580Z <ScheduleController:INFO> ScheduleController#scheman Sun Information entity is reactor_system>sun
                                [latest-24152]2024-06-05T20:20:25.582Z <Controller:NOTICE> Controller ScheduleController#scheman is now online.
                                [latest-24152]2024-06-05T20:20:25.582Z <Structure:INFO> Starting controller MQTTController#mosquitto-mqtt
                                [latest-24152]2024-06-05T20:20:25.583Z <Controller:INFO> MQTTController#mosquitto-mqtt loaded mqtt capabilities ver 22353 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.583Z <Controller:INFO> MQTTController#mosquitto-mqtt loaded implementation data ver 24122 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.583Z <Structure:INFO> Starting controller MQTTController#mqtt
                                [latest-24152]2024-06-05T20:20:25.583Z <MQTTController:WARN> mqtt_capabilities redefines existing x_mqtt
                                [latest-24152]2024-06-05T20:20:25.584Z <MQTTController:WARN> mqtt_capabilities redefines existing x_mqtt_device
                                [latest-24152]2024-06-05T20:20:25.584Z <Capabilities:INFO> [Capabilities][object Object] overriding capability x_mqtt
                                [latest-24152]2024-06-05T20:20:25.584Z <Capabilities:INFO> [Capabilities][object Object] overriding capability x_mqtt_device
                                [latest-24152]2024-06-05T20:20:25.584Z <Controller:INFO> MQTTController#mqtt loaded mqtt capabilities ver 22353 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.584Z <Controller:INFO> MQTTController#mqtt loaded implementation data ver 24122 rev 1 format 1
                                [latest-24152]2024-06-05T20:20:25.587Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
                                [latest-24152]2024-06-05T20:20:25.587Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
                                [latest-24152]2024-06-05T20:20:25.588Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
                                [latest-24152]2024-06-05T20:20:25.588Z <EzloController:WARN> EzloController: implementation of capability battery_maintenance does not provide attribute state
                                [latest-24152]2024-06-05T20:20:25.589Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
                                [latest-24152]2024-06-05T20:20:25.602Z <EzloController:INFO> EzloController#ezlo: connecting to hub "xxxxxx" via anonymous local connection to wss://xxx.xxx.xxx.xxx
                                [latest-24152]2024-06-05T20:20:25.605Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Dyr El (dyrEl)
                                [latest-24152]2024-06-05T20:20:25.612Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Solar Production Forecast (solar_production_forecast)
                                [latest-24152]2024-06-05T20:20:25.617Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged
                                [latest-24152]2024-06-05T20:20:25.617Z <HassController:NOTICE> HassController#hass connecting to ws://xxx.xxx.xxx.xxx/api/websocket
                                [latest-24152]2024-06-05T20:20:25.622Z <MQTTController:WARN> MQTTController#mqtt file my_tasmota_generic_relay.yaml in /home/homebridge/reactor/config/mqtt_templates/my_tasmota_generic_relay.yaml overrides existing template definition my_tasmota_generic_relay
                                [latest-24152]2024-06-05T20:20:25.622Z <MQTTController:WARN> MQTTController#mqtt file shelly_plug_s.yaml in /home/homebridge/reactor/config/mqtt_templates/shelly_plug_s.yaml overrides existing template definition shelly_plug_s
                                [latest-24152]2024-06-05T20:20:25.622Z <MQTTController:WARN> MQTTController#mqtt file tasmota_sensor_lyw.yaml in /home/homebridge/reactor/config/mqtt_templates/tasmota_sensor_lyw.yaml overrides existing template definition tasmota_sensor_lyw
                                [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file wallbox_pulsar_plus.yaml in /home/homebridge/reactor/config/mqtt_templates/wallbox_pulsar_plus.yaml overrides existing template definition wallbox_pulsar_plus
                                [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file xiaofang_motion_light_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/xiaofang_motion_light_sensor.yaml overrides existing template definition xiaofang_motion_light_sensor
                                [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_availability
                                [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_availability_no_get
                                [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_lqi
                                [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_ota
                                [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_power_switch
                                [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_dimming
                                [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_battery_power
                                [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_control_outlet.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_control_outlet.yaml overrides existing template definition zigbee2mqtt_tradfri_control_outlet
                                [latest-24152]2024-06-05T20:20:25.625Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb
                                [latest-24152]2024-06-05T20:20:25.625Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_d
                                [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_ws
                                [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_ws_d
                                [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_door_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_door_sensor.yaml overrides existing template definition zigbee2mqtt_tuya_door_sensor
                                [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_light_bulb_rgbcw.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_light_bulb_rgbcw.yaml overrides existing template definition zigbee2mqtt_tuya_light_bulb_rgbcw
                                [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_tuya_motion_light_sensor
                                [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_tuya_light_motion_sensor
                                [latest-24152]2024-06-05T20:20:25.627Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_smart_plug_pm.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_smart_plug_pm.yaml overrides existing template definition zigbee2mqtt_tuya_smart_plug_pm
                                [latest-24152]2024-06-05T20:20:25.628Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online.
                                [latest-24152]2024-06-05T20:20:25.642Z <ScheduleController:INFO> ScheduleController#scheman entity ValueSensor#scheman>weekends edge "22:00" active, setting primary attribute value to natt
                                [latest-24152]2024-06-05T20:20:25.651Z <HassController:NOTICE> HassController#hass connected, starting protocol
                                [latest-24152]2024-06-05T20:20:25.654Z <HassController:INFO> HassController#hass successful authentication with ws://xxx.xxx.xxx.xxx; fetching initial data...
                                [latest-24152]2024-06-05T20:20:25.658Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_mini_switch.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_mini_switch.yaml overrides existing template definition zigbee2mqtt_aqara_mini_switch
                                [latest-24152]2024-06-05T20:20:25.658Z <HassController:INFO> HassController#hass Hass reports version "2024.5.5" location Hem timezone Europe/Stockholm state RUNNING safe_mode false
                                [latest-24152]2024-06-05T20:20:25.661Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_aqara_motion_light_sensor
                                [latest-24152]2024-06-05T20:20:25.661Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_aqara_light_motion_sensor
                                [latest-24152]2024-06-05T20:20:25.664Z <MQTTController:INFO> MQTTController#mosquitto-mqtt instance topic ident is mosquitto-mqtt
                                [latest-24152]2024-06-05T20:20:25.669Z <Controller:INFO> MQTTController#mosquitto-mqtt 0 dead entities older than 86400000s purged
                                [latest-24152]2024-06-05T20:20:25.669Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt connecting to broker at mqtt://127.0.0.1:1885/
                                [latest-24152]2024-06-05T20:20:25.686Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml overrides existing template definition zigbee2mqtt_aqara_sensor_temperature_humidity
                                [latest-24152]2024-06-05T20:20:25.686Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml overrides existing template definition zigbee2mqtt_aqara_sensor_humidity_temperature
                                [latest-24152]2024-06-05T20:20:25.687Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt
                                [latest-24152]2024-06-05T20:20:25.689Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged
                                [latest-24152]2024-06-05T20:20:25.689Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://127.0.0.1:1888/
                                [latest-24152]2024-06-05T20:20:25.690Z <app:NOTICE> Starting HTTP server and API...
                                [latest-24152]2024-06-05T20:20:25.692Z <httpapi:NOTICE> [HTTPAPI]#1 starting HTTP service on port 8111
                                [latest-24152]2024-06-05T20:20:25.695Z <app:NOTICE> Starting Reaction Engine...
                                [latest-24152]2024-06-05T20:20:25.695Z <Engine:INFO> Reaction Engine starting
                                [latest-24152]2024-06-05T20:20:25.696Z <Engine:INFO> Checking rule sets...
                                [latest-24152]2024-06-05T20:20:25.697Z <Engine:INFO> Checking rules...
                                [latest-24152]2024-06-05T20:20:25.750Z <Engine:INFO> Data check complete; no corrections.
                                --- Rules redacted to posting limits
                                [latest-24152]2024-06-05T20:20:25.883Z <httpapi:NOTICE> [HTTPAPI]#1 HTTP server listening on "0.0.0.0":8111
                                [latest-24152]2024-06-05T20:20:25.896Z <httpapi:INFO> [HTTPAPI]#1 local docs found in /home/homebridge/reactor/docs/html; setting up static service
                                [latest-24152]2024-06-05T20:20:25.897Z <app:NOTICE> Starting WSAPI...
                                [latest-24152]2024-06-05T20:20:25.898Z <wsapi:NOTICE> wsapi: starting version 24148
                                [latest-24152]2024-06-05T20:20:25.919Z <Engine:INFO> [Engine]Engine#1 master timer tick, local time "2024-06-05 22:20:25" (TZ offset 120 mins from UTC)
                                [latest-24152]2024-06-05T20:20:25.966Z <Controller:INFO> VeraController#vera 0 dead entities older than 86400000s purged
                                [latest-24152]2024-06-05T20:20:25.968Z <Controller:NOTICE> Controller VeraController#vera is now online.
                                [latest-24152]2024-06-05T20:20:25.973Z <MQTTController:INFO> MQTTController#mosquitto-mqtt connected; opening subscriptions
                                [latest-24152]2024-06-05T20:20:25.978Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_supervisor_update
                                [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_core_update
                                [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.terminal_ssh_update
                                [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.esphome_update
                                [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.file_editor_update
                                [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_operating_system_update
                                [latest-24152]2024-06-05T20:20:25.980Z <HassController:NOTICE> HassController#hass no signature match for conversation.home_assistant
                                [latest-24152]2024-06-05T20:20:25.980Z <HassController:NOTICE> HassController#hass no signature match for sun.sun
                                [latest-24152]2024-06-05T20:20:25.982Z <HassController:NOTICE> HassController#hass no signature match for remote.samsung_vardagsrummet
                                [latest-24152]2024-06-05T20:20:26.005Z <HassController:NOTICE> HassController#hass no signature match for update.infopanel_hall_firmware
                                [latest-24152]2024-06-05T20:20:26.009Z <Controller:INFO> HassController#hass 0 dead entities older than 86400000s purged
                                [latest-24152]2024-06-05T20:20:26.020Z <MQTTController:INFO> MQTTController#mosquitto-mqtt sending inits and going online!
                                [latest-24152]2024-06-05T20:20:26.021Z <Controller:NOTICE> Controller MQTTController#mosquitto-mqtt is now online.
                                [latest-24152]2024-06-05T20:20:26.025Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyix3-98CDAC2F5883/online) for ljussensor
                                [latest-24152]2024-06-05T20:20:26.026Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyplug-s-80646F811E35/online) for server
                                [latest-24152]2024-06-05T20:20:26.029Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending shellies/shellyplug-s-80646F811E35/command with 6 byte payload to server
                                [latest-24152]2024-06-05T20:20:26.033Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending shellies/shellyuni-C45BBE6C6DE8/command with 6 byte payload to poolvarmepump
                                [latest-24152]2024-06-05T20:20:26.034Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Datarummet/get with 12 byte payload to datarummet
                                [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Sovrummet/get with 12 byte payload to sovrummet
                                [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Milia/get with 12 byte payload to milia
                                [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Hallen 1/get with 12 byte payload to hallen1
                                [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Hallen 2/get with 12 byte payload to hallen2
                                [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Hallen 3/get with 12 byte payload to hallen3
                                [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Fönster köket/get with 12 byte payload to fonster_koket
                                [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Soffan/get with 12 byte payload to soffan
                                [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Framsida/get with 12 byte payload to framsida
                                [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Skänk/get with 12 byte payload to skank
                                [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Baksida/get with 12 byte payload to baksida
                                [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa spel/get with 12 byte payload to lampa_spel
                                [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Ellas rum/get with 12 byte payload to lampa_ella
                                [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa gym/get with 12 byte payload to lampa_gym
                                [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa TV/get with 12 byte payload to lampa_tv
                                [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Vitrinskåp/get with 12 byte payload to vitrinskap
                                [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending shellies/shelly1-34945471EBCF/relay/0/command with 6 byte payload to vvb
                                [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Framsida/get with 12 byte payload to jul_framsida
                                [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Köket/get with 12 byte payload to jul_köket
                                [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Sovrummet/get with 12 byte payload to jul_sovrummet
                                [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Datarummet/get with 12 byte payload to jul_datarummet
                                [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Element gillestugan/get with 12 byte payload to element_gillestugan
                                [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Växtbelysning källare/get with 12 byte payload to vaxtbelysning_kallare
                                [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Kompressor/get with 12 byte payload to kompressor
                                [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Luftrenare/get with 12 byte payload to luftrenare
                                [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Uttag uterummet/get with 12 byte payload to uttag_uterummet
                                [latest-24152]2024-06-05T20:20:26.039Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Entrebelysning/get with 12 byte payload to entrebelysning
                                [latest-24152]2024-06-05T20:20:26.039Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa uterummet/get with 12 byte payload to lampa_uterummet
                                [latest-24152]2024-06-05T20:20:26.050Z <Controller:NOTICE> Controller HassController#hass is now online.
                                [latest-24152]2024-06-05T20:20:26.051Z <MQTTController:INFO> MQTTController#mqtt connected; opening subscriptions
                                [latest-24152]2024-06-05T20:20:26.062Z <MQTTController:ERR> MQTTController#mosquitto-mqtt event handler failed for zigbee2mqtt/Rörelse förrådet on rorelse_forradet: [ReferenceError] Capability string_sensor not extended (mosquitto-mqtt>rorelse_forradet [-]
                                [latest-24152]2024-06-05T20:20:26.062Z <MQTTController:CRIT> ReferenceError: Capability string_sensor not extended (mosquitto-mqtt>rorelse_forradet [-]
                                    at Entity.setAttribute (/home/homebridge/reactor/server/lib/Entity.js:465:19)
                                    at MQTTController.handle_event (/home/homebridge/reactor/config/ext/MQTTController/MQTTController.js:1240:19)
                                    at MqttClient.<anonymous> (/home/homebridge/reactor/config/ext/MQTTController/MQTTController.js:591:38)
                                    at MqttClient.emit (node:events:519:28)
                                    at MqttClient.emit (node:domain:488:12)
                                    at MqttClient._handlePublish (/home/homebridge/reactor/config/ext/MQTTController/node_modules/mqtt/lib/client.js:1551:12)
                                    at MqttClient._handlePacket (/home/homebridge/reactor/config/ext/MQTTController/node_modules/mqtt/lib/client.js:533:12)
                                    at work (/home/homebridge/reactor/config/ext/MQTTController/node_modules/mqtt/lib/client.js:436:12)
                                    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
                                [latest-24152]2024-06-05T20:20:26.063Z <MQTTController:ERR> MQTTController#mosquitto-mqtt event handler failed for zigbee2mqtt/Sovrumsdörr on sovrumsdorr: [ReferenceError] Capability string_sensor not extended (mosquitto-mqtt>sovrumsdörr [-]
                                [latest-24152]2024-06-05T20:20:26.063Z <MQTTController:CRIT> ReferenceError: Capability string_sensor not extended (mosquitto-mqtt>sovrumsdorr [-]
                                [latest-24152]2024-06-05T20:20:26.071Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyuni-C45BBE6C6DE8/online) for poolvarmepump
                                [latest-24152]2024-06-05T20:20:26.072Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyplug-s-80646F811E35/online) for server
                                [latest-24152]2024-06-05T20:20:26.074Z <MQTTController:INFO> MQTTController#mqtt sending inits and going online!
                                [latest-24152]2024-06-05T20:20:26.075Z <Controller:NOTICE> Controller MQTTController#mqtt is now online.
                                reactor.yaml
                                "sovrumsdorr":
                                  topic: "Sovrumsdörr"
                                  include: zigbee2mqtt_tuya_door_sensor
                                  OK, here goes.
                                  [1/2]
                                  reactor.log
                                  reactor.yaml
                                  "sovrumsdorr":
                                  [2/2]
                                  # Requires: "topic".
                                  # Optional: "prefix" (default: zigbee2mqtt).
                                  # mqtt_device.online requires "availability: true" in Zigbee2MQTT config.
                                  # https://www.zigbee2mqtt.io/guide/configuration/device-availability.html
                                  description: "Zigbee2MQTT base templates"
                                  author: "@Crille, Smart Home Community"
                                  license: MIT
                                  repository: "https://github.com/calmen77/MSR-mqtt_templates"
                                  version: 24155
                                  templates:
                                    # Availability with query
                                    zigbee2mqtt_availability:
                                      capabilities: [x_mqtt_device]
                                      requires: [topic]
                                      query:
                                        topic: "%prefix:zigbee2mqtt%/%topic%/get"
                                        payload:
                                          state: ""
                                        type: json
                                      events:
                                        "%prefix:zigbee2mqtt%/%topic%/availability":
                                          "x_mqtt_device.online":
                                            if_expr: '! isnull(payload)'
                                            expr: 'lower(payload) == "online"'
                                    # Availability without query for device not supporting /get
                                    zigbee2mqtt_availability_no_get:
                                      requires: [topic]
                                      events:
                                    # Link quality in lqi
                                    zigbee2mqtt_lqi:
                                      capabilities: [value_sensor]
                                      requires: [topic]
                                      events:
                                        "%prefix:zigbee2mqtt%/%topic%":
                                          "value_sensor.value":
                                            json_payload: true
                                            expr: 'payload.linkquality'
                                          "value_sensor.units": "lqi"
                                  # String sensor for available OTA update for device
                                    zigbee2mqtt_ota:
                                      capabilities: [string_sensor]
                                      requires: [topic]
                                      events:
                                          "string_sensor.value":
                                            json_payload: true
                                            expr: 'payload?.update_available ? "OTA firmware update available!" : "no update available"'
                                    # Power switch capability
                                    zigbee2mqtt_power_switch:
                                      capabilities:
                                        - power_switch
                                        - toggle
                                      requires: [topic]
                                      events:
                                          "power_switch.state":
                                            json_payload: true
                                            expr: 'payload?.state == "ON"'
                                      actions:
                                        power_switch:
                                          "on":
                                            topic: "%prefix:zigbee2mqtt%/%topic%/set"
                                            payload: "ON"
                                          "off":
                                            payload: "OFF"
                                          set:
                                            payload:
                                              expr: "parameters.state ? 'on' : 'off'"
                                              type: raw
                                    # Dimming capability
                                    zigbee2mqtt_dimming:
                                      capabilities: [dimming]
                                      requires: [topic]
                                      events:
                                          "dimming.level":
                                            json_payload: true
                                            expr: 'round(payload?.brightness / 100 / 2.55 , 2)'
                                      actions:
                                        dimming:
                                          set:
                                            payload:
                                              expr: '{"brightness": round(parameters.level * 100 * 2.55 , 2)}'
                                              type: json
                                    # Battery level
                                    zigbee2mqtt_battery_power:
                                      capabilities: [battery_power]
                                      requires: [topic]
                                      events:
                                          "battery_power.level":
                                            json_payload: true
                                            expr: 'payload?.battery / 100'
                                          "battery_power.since":
                                            expr: 'time()'
                                      actions:
                                        x_mqtt_device:
                                          poll: false
                                  # https://www.zigbee2mqtt.io/devices/SNZB-04.html
                                  description: "Zigbee2MQTT template for TuYa Smart Door Sensor."
                                  license: MIT
                                  version: 24155
                                  templates:
                                    zigbee2mqtt_tuya_door_sensor:
                                      #type:
                                      capabilities:
                                        - door_sensor
                                      primary_attribute: door_sensor.state
                                      requires: [topic]
                                      include:
                                        - zigbee2mqtt_availability_no_get
                                        - zigbee2mqtt_lqi
                                        - zigbee2mqtt_battery_power
                                      events:
                                          "door_sensor.state":
                                            json_payload: true
                                            expr: 'payload?.contact'
                                    Turn debug level 5 on for MQTTController. It will show you how it's loading the templates and building the final entity configuration. The message fragment you'll want to look for is merged template for sovrumsdorr... then work backwards in the log from there to configuring entity sovrumsdorr. Everything in between is the setup.
                                    Also examine the debug messages at startup for where it's finding templates and loading them... make sure everything it's loading is what's intended, and you don't have a stray old file sitting around somewhere that it's sucking in.
                                    Edit: your logs are showing a lot of duplicate definitions in the startup messages...
                                      It seems to merge the events: section of string_sensor and power_switch in ...common.yaml and wrap value_sensor.units in string_sensor capability.
                                      I've looked for strange characters that could cause it but found nothing, validated all files OK in yamllint.
                                      [latest-24152]2024-06-06T06:29:11.699Z <MQTTController:5:MQTTController.js:146> MQTTController#mosquitto-mqtt configuring entity sovrumsdorr
                                      [latest-24152]2024-06-06T06:29:11.699Z <MQTTController:5:MQTTController.js:205> MQTTController#mosquitto-mqtt merged template for sovrumsdorr (from /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml/zigbee2mqtt_common.yaml):
                                          "capabilities": [
                                              "door_sensor",
                                              "x_mqtt_device",
                                              "value_sensor",
                                              "battery_power"
                                          "primary_attribute": "door_sensor.state",
                                          "requires": [
                                              "topic"
                                          "include": [
                                              "zigbee2mqtt_availability_no_get",
                                              "zigbee2mqtt_lqi",
                                              "zigbee2mqtt_battery_power",
                                              "zigbee2mqtt_tuya_door_sensor"
                                          "events": {
                                              "%prefix:zigbee2mqtt%/%topic%": {
                                                  "door_sensor.state": {
                                                      "json_payload": true,
                                                      "expr": "payload?.contact"
                                                  "value_sensor.value": {
                                                      "if_expr": "! isnull(payload)",
                                                      "expr": "payload.linkquality",
                                                      "attribute": "value_sensor.value"
                                                  "value_sensor.units": "lqi",
                                                  "string_sensor.value": {
                                                      "expr": "payload?.update_available ? \"OTA firmware update available!\" : \"no update available\"",
                                                      "attribute": "string_sensor.value"
                                                  "power_switch.state": {
                                                      "expr": "payload?.state == \"ON\"",
                                                      "attribute": "power_switch.state"
                                                  "battery_power.level": {
                                                      "expr": "payload?.battery / 100",
                                                      "attribute": "battery_power.level"
                                                  "battery_power.since": {
                                                      "expr": "time()",
                                                      "attribute": "battery_power.since"
                                              "%prefix:zigbee2mqtt%/%topic%/availability": {
                                                  "x_mqtt_device.online": {
                                                      "expr": "lower(payload) == \"online\"",
                                                      "attribute": "x_mqtt_device.online"
                                          "__source": "/home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml/zigbee2mqtt_common.yaml",
                                          "actions": {
                                              "x_mqtt_device": {
                                                  "poll": false
                                          "name": "Sovrumsdörr",
                                          "topic": "Sovrumsdörr"
                                      [latest-24152]2024-06-06T06:29:11.699Z <MQTTController:5:MQTTController.js:264> MQTTController#mosquitto-mqtt set primary attribute of door_sensor.state to Entity#mosquitto-mqtt>sovrumsdorr
                                      [latest-24152]2024-06-06T06:29:11.700Z <MQTTController:5:MQTTController.js:289> MQTTController#mosquitto-mqtt registering event handler %prefix:zigbee2mqtt%/%topic% for sovrumsdorr
                                      [latest-24152]2024-06-06T06:29:11.700Z <MQTTController:5:MQTTController.js:289> MQTTController#mosquitto-mqtt registering event handler %prefix:zigbee2mqtt%/%topic%/availability for sovrumsdorr
                                      [latest-24152]2024-06-06T06:29:11.700Z <MQTTController:5:MQTTController.js:368> MQTTController#mosquitto-mqtt registering action x_mqtt_device.poll for sovrumsdorr
                                      Regarding the duplicates, it could be the templates with different primary_attribute: and it is on my roadmap to bring it up for discussion if attributes also could be parameterized with defaults like %primary_attribute:[temperature / humidity / power_switch / dimming / motion / light]% or %temperature_sensor.units:[C / F]%.
                                      EDIT: Or is caused by the mystery of this issue? e.g. string_sensor and power_switch is somehow included in all templates.
                                        @Crille at some point I had similar problems, I fixed them and I reported here. Now I cannot repro it again, but it seems very similar and related to primary attributes in base templates. It seems like the first one is used and that’s causing troubles along the hierarchy, but, as I said, I’m not able to repro it again.
                                          It also looks like something may be getting a shallow copy when it needs a deep copy, and it's being modified later and polluting the other references. I'm really tied up today, but I'll look at this as soon as I can.
                                          Did you address the template redefinitions that were being logged at startup? That has nothing to do with primary attributes; the entire template is trying to be redefined.
                                            116.3k
