  4. Need assistance: How do I calculate time based upon current time and an ETA
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
9 Posts 2 Posters 1.6k Views 2 Watching
    I apologize if this subject has been covered. I did try the search, but I'm not coming up with any topics on my issue.
    I'm running userauth-24137-57b41335, bare metal installation on Fedora 39 Server.
    I have a rule set up to turn the Eco mode off on my Nest Thermostat when the thermostat is set to Away (Rule State: Away Mode), the user (Driver) presence in my car changes to true, and the destination is set to home.
    This works fine for most days, where I'm headed home from work (commute is about 45 minutes). What I don't want it to do is set change it to Eco mode if my ETA is more than an hour.
    There is a sensor/entity for Time to Arrival when the Destination is set. What it appears to provide is the Time OF arrival/ETA, not time until arrival. If it was Time until Arrival, and it was a numeric value, I could simply test if the value is less than 60 and be done with it.
    I pulled up the history through Home Assistant for my morning commute and this appears to be what it is providing.
    So what I need to do is to do a calculation of the the ETA from the sensor value and subtract the current time, and get a value in minutes that I can determine if it's less than 60.
    I believe I can do this with the local expression, but I don't see anything for the system time, or local time. Also, do the local expressions update themselves if the sensors do?
    • T tamorgen
      @tamorgen said in Need assistance: How do I calculate time based upon current time and an ETA:
      In the docs, Date/Time Handling Functions.
      Absolutely.
        Absolutely.
        @toggledbits said in Need assistance: How do I calculate time based upon current time and an ETA:
        Okay, I missed that. That raises more questions.
        I'm thinking it's easier to convert my ETA sensor to Unix Epic, and then do the math from there, correct? Do you have any examples on how I would go about doing this?
        I went to lunch and pulled up MSR so I could get the actual, real time output of time to a destination.
          I tested using a static unix epoch time, and I pulled the time for one of my other sensor so I can work on testing the conversion.....
          Getting there.
            And I figured it out....
              May have spoke too soon....
              Since the current value is null, it's going to throw a yellow triangle, because it can't be evaluated.
              @toggledbits Is there a way to clear that flag for a local expression that is only periodically filled?
              Correction: the value for the sensor is "unavailable", not null....
              The value for the local expression becomes "null", because of the "unavailable" value for the sensor.
                It also throws an error in the status pane.
                  Try this:
                  D=getEntity( "hass>sensor_spaceball_1_time_to_arrival" ).attributes.string_sensor?.value,
                  if "unavailable" === D
                    then null
                    else do
                      D = time( D ),
                      D = isNaN( D ) ? null : round( ( D - time() ) / 60000 )
                    done
                  endif
                  The first line sets up the attribute value in a temporary local variable (i.e. available only inside the expression) called eta.
                  Line 2 checks to see if it's the string unavailable, and if so, line 3 will cause this expression to produce null as a result.
                  Otherwise, the else block beginning at line 4 starts by converting the string in eta to a time in milliseconds (line 5), and if that result isn't NaN (line 6), then the difference between that time and now in minutes is computed.
                  The test ? true-expr : false-expr form on line 6 is a ternary operator, if you haven't used it before. It's equivalent to IF test THEN true-expr ELSE false-expr ENDIF, just shorter.
                    Try this:
                      then null
                      else do
                        D = time( D ),
                      done
                    endif
                    @toggledbits,
                    Thank you Patrick. It's not throwing an alert now. Very elegant solution.
                    I'll verify that it works once I get in the car after work and marked the thread as solved.
                    • Next Release?
