  4. [Dev] Inheritance in MQTT templates?
40 Posts 4 Posters 14.9k Views 4 Watching
    With debug level 5, that message will have another message that follows it to tell you what file originally defined it.
      This?
      [latest-24152]2024-06-06T19:29:35.079Z <MQTTController:5:MQTTController.js:941> MQTTController#mqtt loading template defs, considering zigbee2mqtt_tuya_door_sensor.yaml
      [latest-24152]2024-06-06T19:29:35.079Z <MQTTController:5:MQTTController.js:987> MQTTController#mqtt loading YAML template data from /home/homebridge/reactor/config/mqtt_templates/zigbee2mqt
      [latest-24152]2024-06-06T19:29:35.080Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_door_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_do
      or_sensor.yaml overrides existing template definition zigbee2mqtt_tuya_door_sensor
      [latest-24152]2024-06-06T19:29:35.080Z <MQTTController:5:MQTTController.js:918> MQTTController#mqtt previously defined in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_doo
      r_sensor.yaml/zigbee2mqtt_tuya_door_sensor.yaml
        Uh yes... 😆
        Digging in now...
          I need the config for all of your zigbee2mqtt-related entities. Just looking at the one sovrumsdorr, I'm not able to reproduce the problem.
            Config as in reactor.yaml?
              Yes, but just the entities that use the zigbee2mqtt templates. I don't need all of it.
                #28
                entities:
                  "zigbee2mqtt_sensor":
                    topic: "zigbee2mqtt"
                    include: my_zigbee2mqtt_sensor
                  "datarummet":
                    topic: "Datarummet"
                    include: zigbee2mqtt_tradfri_light_bulb
                  "sovrummet":
                    topic: "Sovrummet"
                    include: zigbee2mqtt_tradfri_light_bulb_ws
                  "milia":
                    topic: "Milia"
                  "hallen1":
                    topic: "Hallen 1"
                  "hallen2":
                    topic: "Hallen 2"
                  "hallen3":
                    topic: "Hallen 3"
                  "fonster_koket":
                    topic: "Fönster köket"
                  "soffan":
                    topic: "Soffan"
                  "framsida":
                    topic: "Framsida"
                  "skank":
                    topic: "Skänk"
                  "baksida":
                    topic: "Baksida"
                  "lampa_spel":
                    topic: "Lampa spel"
                  "lampa_ella":
                    topic: "Ellas rum"
                  "lampa_gym":
                    topic: "Lampa gym"
                  "lampa_tv":
                    topic: "Lampa TV"
                    include: zigbee2mqtt_tradfri_control_outlet
                  "vitrinskap":
                    topic: "Vitrinskåp"
                  "klimat_sovrum":
                    topic: "Klimat sovrum"
                    include: zigbee2mqtt_aqara_sensor_temperature_humidity
                  "klimat_kaminen":
                    topic: "Klimat kaminen"
                  "klimat_dusch":
                    topic: "Klimat dusch"
                    include: zigbee2mqtt_aqara_sensor_humidity_temperature
                  "klimat_tvattstugan":
                    name: "Klimat tvättstugan"
                    topic: "Klimat tvättstugan"
                  "rorelse_hallen":
                    topic: "Rörelse hallen"
                    include: zigbee2mqtt_aqara_light_motion_sensor
                  "rorelse_kallaren":
                    name: "Rörelse källaren"
                    topic: "Rörelse källaren"
                  "rorelse_forradet":
                    name: "Rörelse förrådet"
                    topic: "Rörelse förrådet"
                    include: zigbee2mqtt_tuya_motion_light_sensor
                  "mini_switch_1":
                    name: "Mini Switch källaren"
                    topic: "Mini Switch källaren"
                    include: zigbee2mqtt_aqara_mini_switch
                  "jul_framsida":
                    name: "Jul Framsida"
                    topic: "Jul Framsida"
                    include: zigbee2mqtt_tuya_smart_plug_pm
                  "jul_koket":
                    topic: "Jul Köket"
                  "jul_sovrummet":
                    name: "Jul Sovrummet"
                    topic: "Jul Sovrummet"
                  "jul_datarummet":
                    name: "Jul Datarummet"
                    topic: "Jul Datarummet"
                  "element_gillestugan":
                    name: "Element gillestugan"
                    topic: "Element gillestugan"
                  "vaxtbelysning_kallare":
                    topic: "Växtbelysning källare"
                  "kompressor":
                    topic: "Kompressor"
                  "luftrenare":
                    topic: "Luftrenare"
                  "uttag_uterummet":
                    name: "Uttag uterummet"
                    topic: "Uttag uterummet"
                  "sovrumsdorr":
                    topic: "Sovrumsdörr"
                    include: zigbee2mqtt_tuya_door_sensor
                  "entrebelysning":
                    topic: "Entrebelysning"
                    include: zigbee2mqtt_tuya_light_bulb_rgbcw
                  "lampa_uterummet":
                    name: "Lampa uterummet"
                    topic: "Lampa uterummet"
                EDIT: unrelated, found entity id "jul_köket" and renamed it to "jul_koket" in post and Reactor.
                  OK. I also need the definitions for zigbee2mqtt_tradfri_light_bulb and all of the other templates not in the common file you previously posted.
                    Wait... are those just available on Github? Are your current versions published in any branch there? If so, I'll just grab them from there.
                      No I haven't published them due to this issue but I can put them in the test branch, hold on.
                        Available in zigbee2mqtt_test.zip
                          Looks like MQTTController 24159 solved it. I don't see any errors or warnings in the log after a restart, except all of these but I quess that's normal?
                          <MQTTController:WARN> MQTTController#mqtt file /home/homebridge/reactor/config/ext/MQTTController/templates/tasmota.yaml overrides existing template definition tasmota_generic_relay from /home/homebridge/reactor/config/ext/MQTTController/templates/tasmota.yaml
                            No not normal, and I don't get those.
                              Strange! I wonder what’s causing that in my setup then as it’s the integrated templates as well.
                                Are you running more than one instance of MQTTController?
                                  Ah yes, one for openLuup and one for Mosquitto
                                    OK. Try 24160
                                      Yep, all warnings gone! Thank you for all your work!
                                      • ? Offline
                                        ? Offline
                                        A Former User
                                          1.0k
                                          157.4k
