  4. [Dev] Inheritance in MQTT templates?
40 Posts 4 Posters 14.9k Views 4 Watching
    OK. I also need the definitions for zigbee2mqtt_tradfri_light_bulb and all of the other templates not in the common file you previously posted.
      Wait... are those just available on Github? Are your current versions published in any branch there? If so, I'll just grab them from there.
        No I haven't published them due to this issue but I can put them in the test branch, hold on.
          Available in zigbee2mqtt_test.zip
            Looks like MQTTController 24159 solved it. I don't see any errors or warnings in the log after a restart, except all of these but I quess that's normal?
            <MQTTController:WARN> MQTTController#mqtt file /home/homebridge/reactor/config/ext/MQTTController/templates/tasmota.yaml overrides existing template definition tasmota_generic_relay from /home/homebridge/reactor/config/ext/MQTTController/templates/tasmota.yaml
              No not normal, and I don't get those.
                Strange! I wonder what’s causing that in my setup then as it’s the integrated templates as well.
                  Are you running more than one instance of MQTTController?
                    Ah yes, one for openLuup and one for Mosquitto
                      OK. Try 24160
                        Yep, all warnings gone! Thank you for all your work!
                        • ? Offline
                          ? Offline
                          A Former User
                            1.0k
                            157.4k
