  4. [ZwaveJS] Problems with endpoints and Fibaro Double Switch 2 (FGS223)
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
8 Posts 3 Posters 1.7k Views 3 Watching
    I'm not sure if it's a bug or something, but I have a lot of Fibaro Double Switch (FGS223) as follows.
    In the example, it's zwavejs>65-2:
    energy_sensor.units="kWh"
    energy_sensor.value=0.21
    power_sensor.units="W"
    power_sensor.value=0
    power_switch.state=false
    x_debug.dt={"entity_class":"Switch","match":"deviceClass.generic.key=16","capabilities":["power_switch","toggle"],"primary_attribute":"power_switch.state"}
    x_zwave_values.Binary_Switch_currentValue=false
    x_zwave_values.Binary_Switch_targetValue=false
    x_zwave_values.Meter_reset=null
    x_zwave_values.Meter_value_65537=0.21
    x_zwave_values.Meter_value_66049=0
    zwave_device.capabilities=[37,50]
    zwave_device.endpoint=2
    zwave_device.failed=null
    zwave_device.impl_sig="23326:1:22315:1"
    zwave_device.manufacturer_info=null
    zwave_device.node_id=65
    When operating endpoint 2, it's triggered endpoint 1. Endpoint 1 is fine. This is causing a lot of troubles, as you may imagine.
    Also, endpoint 0 is not really a switch, and the associated actions are not doing anything at all. Maybe these could be removed. Also, I see battery_maintenance and power_source capabilities, all with null values.
    battery_maintenance.charging=null
    battery_maintenance.rechargeable=false
    battery_maintenance.replace=false
    battery_maintenance.state=null
    heat_detector.state=false
    power_source.source=null
    power_switch.state=null
    x_debug.dt={"entity_class":"Switch","match":"deviceClass.generic.key=16","capabilities":["power_switch","toggle"],"primary_attribute":"power_switch.state","description":"Double Switch 2","model":"FGS223","default_name":"Double Switch 2","manufacturerId":271,"productType":515,"productId":4096}
    x_zwave_values.Central_Scene_scene_001=null
    x_zwave_values.Central_Scene_scene_002=null
    x_zwave_values.Central_Scene_slowRefresh=null
    x_zwave_values.Configuration_First_Channel_Energy_Reports_Threshold=100
    x_zwave_values.Configuration_First_Channel_Operating_Mode=0
    x_zwave_values.Configuration_First_Channel_Power_Reports_Minimum_Time_Between_Reports=10
    x_zwave_values.Configuration_First_Channel_Power_Reports_Threshold=20
    x_zwave_values.Configuration_First_Channel_Pulse_Time_for_Blink_Mode=5
    x_zwave_values.Configuration_First_Channel_Reaction_to_Key_S1_for_Delay_Auto_ON_OFF_Modes=0
    x_zwave_values.Configuration_First_Channel_Time_Parameter_for_Delay_Auto_ON_OFF_Modes=50
    x_zwave_values.Configuration_General_Purpose_Alarm_Response=3
    x_zwave_values.Configuration_Include_Consumption_By_Device_Itself_in_Reports=0
    x_zwave_values.Configuration_Input_Button_Switch_Configuration=2
    x_zwave_values.Configuration_Key_S1_Associations_Double_Click_Value_Sent=99
    x_zwave_values.Configuration_Key_S1_Associations_Send_OFF_With_Single_Click_2=0
    x_zwave_values.Configuration_Key_S1_Associations_Send_ON_With_Single_Click_1=0
    x_zwave_values.Configuration_Key_S1_Associations_Send_When_Double_Clicking_8=0
    x_zwave_values.Configuration_Key_S1_Associations_Send_When_Holding_and_Releasing_4=0
    x_zwave_values.Configuration_Key_S1_Associations_Switch_OFF_Value_Sent=0
    x_zwave_values.Configuration_Key_S1_Associations_Switch_ON_Value_Sent=255
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Held_Down_and_Released_8=1
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Pressed_1_Time_1=1
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Pressed_2_Times_2=1
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Pressed_3_Times_4=1
    x_zwave_values.Configuration_Key_S2_Associations_Double_Click_Value_Sent=99
    x_zwave_values.Configuration_Key_S2_Associations_Send_OFF_With_Single_Click_2=0
    x_zwave_values.Configuration_Key_S2_Associations_Send_ON_With_Single_Click_1=0
    x_zwave_values.Configuration_Key_S2_Associations_Send_When_Double_Clicking_8=0
    x_zwave_values.Configuration_Key_S2_Associations_Send_When_Holding_and_Releasing_4=0
    x_zwave_values.Configuration_Key_S2_Associations_Switch_OFF_Value_Sent=0
    x_zwave_values.Configuration_Key_S2_Associations_Switch_ON_Value_Sent=255
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Held_Down_and_Released_8=1
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Pressed_1_Time_1=1
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Pressed_2_Times_2=1
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Pressed_3_Times_4=1
    x_zwave_values.Configuration_Periodic_Active_Power_Reports=3600
    x_zwave_values.Configuration_Periodic_Energy_Reports=3600
    x_zwave_values.Configuration_Report_During_Blink_Mode=0
    x_zwave_values.Configuration_Second_Channel_Energy_Reports_Threshold=100
    x_zwave_values.Configuration_Second_Channel_Operating_Mode=0
    x_zwave_values.Configuration_Second_Channel_Power_Reports_Minimum_Time_Between_Reports=10
    x_zwave_values.Configuration_Second_Channel_Power_Reports_Threshold=20
    x_zwave_values.Configuration_Second_Channel_Pulse_Time_for_Blink_Mode=5
    x_zwave_values.Configuration_Second_Channel_Reaction_to_Key_S2_for_Delay_Auto_ON_OFF_Modes=0
    x_zwave_values.Configuration_Second_Channel_Time_Parameter_for_Delay_Auto_ON_OFF_Modes=50
    x_zwave_values.Configuration_Send_Secure_Commands_to_2nd_Association_Group_1=1
    x_zwave_values.Configuration_Send_Secure_Commands_to_3rd_Association_Group_2=1
    x_zwave_values.Configuration_Send_Secure_Commands_to_4th_Association_Group_4=1
    x_zwave_values.Configuration_Send_Secure_Commands_to_5th_Association_Group_8=1
    x_zwave_values.Configuration_Smoke_CO_or_CO2_Alarm_Response=3
    x_zwave_values.Configuration_State_After_Power_Failure=1
    x_zwave_values.Configuration_Temperature_Alarm_Response=1
    x_zwave_values.Configuration_Time_of_Alarm_State=600
    x_zwave_values.Configuration_Water_Flood_Alarm_Response=2
    x_zwave_values.Manufacturer_Specific_manufacturerId=271
    x_zwave_values.Manufacturer_Specific_productId=4096
    x_zwave_values.Manufacturer_Specific_productType=515
    x_zwave_values.Notification_Heat_Alarm_Heat_sensor_status=0
    x_zwave_values.Notification_Power_Management_Over_current_status=0
    x_zwave_values.Notification_alarmLevel=null
    x_zwave_values.Notification_alarmType=null
    x_zwave_values.Protection_exclusiveControlNodeId=null
    x_zwave_values.Protection_local=0
    x_zwave_values.Protection_rf=0
    x_zwave_values.Protection_timeout=null
    x_zwave_values.Version_firmwareVersions=["3.2"]
    x_zwave_values.Version_hardwareVersion=3
    x_zwave_values.Version_protocolVersion="4.5"
    zwave_device.capabilities=[91,112,113,114,117,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Binary Switch"
    zwave_device.is_beaming=false
    zwave_device.is_listening=true
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.manufacturer_info=[271,515,4096]
    zwave_device.specific_class="Binary Power Switch"
    zwave_device.status=4
    zwave_device.version_info=[null,"3.2"]
      There's another device (Zooz) with a similar report. I'm looking into this now that I'm back from my trip.
      T therealdbT 2 Replies Last reply
        @toggledbits said in [ZwaveJS] Problems with endpoints and Fibaro Double Switch 2 (FGS223):
        Thanks for the reminder. I haven't gotten you the correct ZWaveJS logs. I got sidetracked. Let me see if I can get those for you on that thread.
          @toggledbits thanks! I've found other quirks, let me know if you want a separate report. Minor things, but differing from Vera's. The most annoying one is position not working and me having to rewrite 100+ rules to use dimming for roller shutters.
            Each issue has to be case by case. Let's hit them one at a time. I just pushed 24232 of ZWaveJSController as an interim build; I'll do an announced build after we've worked through everything. Check 24232 and see if it improves your double-switch behavior first. Let me know here. New thread for the shades, please.
              yup, I'll post a new one. This build seems to be OK with this particular problem, thanks!
                I don't know if it's related to this, because I'm running the controller since 12 hours, but after the update my Fibaro Door Window Sensor 2 (FGDW002) is always reporting as open, even if
                x_zwave_values.Notification_Access_Control_Door_state=23
                x_zwave_values.Notification_Access_Control_Door_state_simple=23
                which means that the door is closed. It was working before and I could downgrade to test, if necessary.
                  Yeah, that's related to recent changes Z-Wave JS made for similar devices. They are now supporting a command class they didn't before. Start a new thread for it, and I'll run it down.
                    127.9k
