  4. [ZwaveJS] Problems with endpoints and Fibaro Double Switch 2 (FGS223)
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
8 Posts 3 Posters 1.9k Views 3 Watching
    I'm not sure if it's a bug or something, but I have a lot of Fibaro Double Switch (FGS223) as follows.
    In the example, it's zwavejs>65-2:
    energy_sensor.units="kWh"
    energy_sensor.value=0.21
    power_sensor.units="W"
    power_sensor.value=0
    power_switch.state=false
    x_debug.dt={"entity_class":"Switch","match":"deviceClass.generic.key=16","capabilities":["power_switch","toggle"],"primary_attribute":"power_switch.state"}
    x_zwave_values.Binary_Switch_currentValue=false
    x_zwave_values.Binary_Switch_targetValue=false
    x_zwave_values.Meter_reset=null
    x_zwave_values.Meter_value_65537=0.21
    x_zwave_values.Meter_value_66049=0
    zwave_device.capabilities=[37,50]
    zwave_device.endpoint=2
    zwave_device.failed=null
    zwave_device.impl_sig="23326:1:22315:1"
    zwave_device.manufacturer_info=null
    zwave_device.node_id=65
    When operating endpoint 2, it's triggered endpoint 1. Endpoint 1 is fine. This is causing a lot of troubles, as you may imagine.
    Also, endpoint 0 is not really a switch, and the associated actions are not doing anything at all. Maybe these could be removed. Also, I see battery_maintenance and power_source capabilities, all with null values.
    battery_maintenance.charging=null
    battery_maintenance.rechargeable=false
    battery_maintenance.replace=false
    battery_maintenance.state=null
    heat_detector.state=false
    power_source.source=null
    power_switch.state=null
    x_debug.dt={"entity_class":"Switch","match":"deviceClass.generic.key=16","capabilities":["power_switch","toggle"],"primary_attribute":"power_switch.state","description":"Double Switch 2","model":"FGS223","default_name":"Double Switch 2","manufacturerId":271,"productType":515,"productId":4096}
    x_zwave_values.Central_Scene_scene_001=null
    x_zwave_values.Central_Scene_scene_002=null
    x_zwave_values.Central_Scene_slowRefresh=null
    x_zwave_values.Configuration_First_Channel_Energy_Reports_Threshold=100
    x_zwave_values.Configuration_First_Channel_Operating_Mode=0
    x_zwave_values.Configuration_First_Channel_Power_Reports_Minimum_Time_Between_Reports=10
    x_zwave_values.Configuration_First_Channel_Power_Reports_Threshold=20
    x_zwave_values.Configuration_First_Channel_Pulse_Time_for_Blink_Mode=5
    x_zwave_values.Configuration_First_Channel_Reaction_to_Key_S1_for_Delay_Auto_ON_OFF_Modes=0
    x_zwave_values.Configuration_First_Channel_Time_Parameter_for_Delay_Auto_ON_OFF_Modes=50
    x_zwave_values.Configuration_General_Purpose_Alarm_Response=3
    x_zwave_values.Configuration_Include_Consumption_By_Device_Itself_in_Reports=0
    x_zwave_values.Configuration_Input_Button_Switch_Configuration=2
    x_zwave_values.Configuration_Key_S1_Associations_Double_Click_Value_Sent=99
    x_zwave_values.Configuration_Key_S1_Associations_Send_OFF_With_Single_Click_2=0
    x_zwave_values.Configuration_Key_S1_Associations_Send_ON_With_Single_Click_1=0
    x_zwave_values.Configuration_Key_S1_Associations_Send_When_Double_Clicking_8=0
    x_zwave_values.Configuration_Key_S1_Associations_Send_When_Holding_and_Releasing_4=0
    x_zwave_values.Configuration_Key_S1_Associations_Switch_OFF_Value_Sent=0
    x_zwave_values.Configuration_Key_S1_Associations_Switch_ON_Value_Sent=255
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Held_Down_and_Released_8=1
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Pressed_1_Time_1=1
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Pressed_2_Times_2=1
    x_zwave_values.Configuration_Key_S1_Send_Scenes_When_Pressed_3_Times_4=1
    x_zwave_values.Configuration_Key_S2_Associations_Double_Click_Value_Sent=99
    x_zwave_values.Configuration_Key_S2_Associations_Send_OFF_With_Single_Click_2=0
    x_zwave_values.Configuration_Key_S2_Associations_Send_ON_With_Single_Click_1=0
    x_zwave_values.Configuration_Key_S2_Associations_Send_When_Double_Clicking_8=0
    x_zwave_values.Configuration_Key_S2_Associations_Send_When_Holding_and_Releasing_4=0
    x_zwave_values.Configuration_Key_S2_Associations_Switch_OFF_Value_Sent=0
    x_zwave_values.Configuration_Key_S2_Associations_Switch_ON_Value_Sent=255
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Held_Down_and_Released_8=1
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Pressed_1_Time_1=1
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Pressed_2_Times_2=1
    x_zwave_values.Configuration_Key_S2_Send_Scenes_When_Pressed_3_Times_4=1
    x_zwave_values.Configuration_Periodic_Active_Power_Reports=3600
    x_zwave_values.Configuration_Periodic_Energy_Reports=3600
    x_zwave_values.Configuration_Report_During_Blink_Mode=0
    x_zwave_values.Configuration_Second_Channel_Energy_Reports_Threshold=100
    x_zwave_values.Configuration_Second_Channel_Operating_Mode=0
    x_zwave_values.Configuration_Second_Channel_Power_Reports_Minimum_Time_Between_Reports=10
    x_zwave_values.Configuration_Second_Channel_Power_Reports_Threshold=20
    x_zwave_values.Configuration_Second_Channel_Pulse_Time_for_Blink_Mode=5
    x_zwave_values.Configuration_Second_Channel_Reaction_to_Key_S2_for_Delay_Auto_ON_OFF_Modes=0
    x_zwave_values.Configuration_Second_Channel_Time_Parameter_for_Delay_Auto_ON_OFF_Modes=50
    x_zwave_values.Configuration_Send_Secure_Commands_to_2nd_Association_Group_1=1
    x_zwave_values.Configuration_Send_Secure_Commands_to_3rd_Association_Group_2=1
    x_zwave_values.Configuration_Send_Secure_Commands_to_4th_Association_Group_4=1
    x_zwave_values.Configuration_Send_Secure_Commands_to_5th_Association_Group_8=1
    x_zwave_values.Configuration_Smoke_CO_or_CO2_Alarm_Response=3
    x_zwave_values.Configuration_State_After_Power_Failure=1
    x_zwave_values.Configuration_Temperature_Alarm_Response=1
    x_zwave_values.Configuration_Time_of_Alarm_State=600
    x_zwave_values.Configuration_Water_Flood_Alarm_Response=2
    x_zwave_values.Manufacturer_Specific_manufacturerId=271
    x_zwave_values.Manufacturer_Specific_productId=4096
    x_zwave_values.Manufacturer_Specific_productType=515
    x_zwave_values.Notification_Heat_Alarm_Heat_sensor_status=0
    x_zwave_values.Notification_Power_Management_Over_current_status=0
    x_zwave_values.Notification_alarmLevel=null
    x_zwave_values.Notification_alarmType=null
    x_zwave_values.Protection_exclusiveControlNodeId=null
    x_zwave_values.Protection_local=0
    x_zwave_values.Protection_rf=0
    x_zwave_values.Protection_timeout=null
    x_zwave_values.Version_firmwareVersions=["3.2"]
    x_zwave_values.Version_hardwareVersion=3
    x_zwave_values.Version_protocolVersion="4.5"
    zwave_device.capabilities=[91,112,113,114,117,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Binary Switch"
    zwave_device.is_beaming=false
    zwave_device.is_listening=true
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.manufacturer_info=[271,515,4096]
    zwave_device.specific_class="Binary Power Switch"
    zwave_device.status=4
    zwave_device.version_info=[null,"3.2"]
      There's another device (Zooz) with a similar report. I'm looking into this now that I'm back from my trip.
      T therealdbT 2 Replies Last reply
        @toggledbits said in [ZwaveJS] Problems with endpoints and Fibaro Double Switch 2 (FGS223):
        Thanks for the reminder. I haven't gotten you the correct ZWaveJS logs. I got sidetracked. Let me see if I can get those for you on that thread.
          @toggledbits thanks! I've found other quirks, let me know if you want a separate report. Minor things, but differing from Vera's. The most annoying one is position not working and me having to rewrite 100+ rules to use dimming for roller shutters.
            Each issue has to be case by case. Let's hit them one at a time. I just pushed 24232 of ZWaveJSController as an interim build; I'll do an announced build after we've worked through everything. Check 24232 and see if it improves your double-switch behavior first. Let me know here. New thread for the shades, please.
              yup, I'll post a new one. This build seems to be OK with this particular problem, thanks!
                I don't know if it's related to this, because I'm running the controller since 12 hours, but after the update my Fibaro Door Window Sensor 2 (FGDW002) is always reporting as open, even if
                x_zwave_values.Notification_Access_Control_Door_state=23
                x_zwave_values.Notification_Access_Control_Door_state_simple=23
                which means that the door is closed. It was working before and I could downgrade to test, if necessary.
                  Yeah, that's related to recent changes Z-Wave JS made for similar devices. They are now supporting a command class they didn't before. Start a new thread for it, and I'll run it down.
                    163.7k
