  4. Is there a way to restart an add-on in HAAS from MSR?
14 Posts 3 Posters 3.3k Views 3 Watching
    I have a service MQTT service that needs a restart occasionally. The add-on (Smartbed MQTT) is for the smart bed base for my bed. It has a "safety light" that I can control from HAAS & MSR as a light entity, and also moves the head of the bed to a preset at bedtime, and then lies it back flat in the morning The problem is, from time to time, the light becomes "unavailable" Restarting from the Add-ons tab in HAAS always fixes it, but I should be able to detect when it happens when "light.tempur_pedic_safety_lights" is not true or false, i.e., unavailable.
    What I don't know how to do is how to restart that service. Does anybody have experience in restarting add-ons from MSR?
    • Reactor (Multi-hub) latest-24212-3ce15e25
    • ZWaveJSController [0.1.24232]
    HAAS:
    • RPi5-64 (8GB)
    • Core 2024.7.3
    • Supervisor 2024.08.0
    • Operating System 13.0
    • Frontend 20240710.0
      yup.
      The hardest part is to get the ID. You have to get it via the browser tab, while reloading from the UI. https://community.home-assistant.io/t/add-service-integration-reload/231940/21?page=2
        @therealdb, thanks for the quick response. I knew it had to be in the haas>system and some sort of system call, but I wasn't sure where. Thanks for the link. I have some reading to do.
          Finding this ID is proving to be a bit of a challenge. You found it on the network tab after you reloaded the page in the Chrome developer tools? This is what I'm seeing:
          • T tamorgen
            @tamorgen just filter for XHR and look for a call to
            /api/config/config_entries/entry/[ID]/reload
            after asking for a reload of the integration.
            Do not refresh the browser.
              I may have to try this at home. I'm going through Cloudflare to access my HA instance. Maybe it's interfering with what I'm trying to find.
                Are we speaking of this?
                  @therealdb ,
                  That's the one.
                    ok, easier. Go to your homeassistant installation directory, look for an hidden .storage folder, and then core.config_entries. entry_id is the key you'll need.
                      @therealdb,
                      Revisiting. I never got this working. I think the issue is that the link provided talks about integrations, not add-ons.
                      I actually was able to create an automation through HAAS to do what I want to do through reactor. It looks like there is a addon_restart action in HAAS.
                      If this is an action, there should be in theory the same action in MSR.
                      @toggledbits, is there a way to call this action?
                      • T tamorgen
                        @therealdb,
                        @tamorgen said in Is there a way to restart an add-on in HAAS from MSR?:
                        Using Hass OS I assume? There's a command line tool you can use, described here. You would have to use that with a Shell action. If Reactor is running on the Hass OS system, that's probably easiest. Otherwise, you're going to have to write a script for the Shell action to execute that ssh's into your HassOS system to run their command line tool.
                          @toggledbits said in Is there a way to restart an add-on in HAAS from MSR?:
                          Yes, I posted that on the first post of the thread.
                          I think I may have figured out how to do it. I just need to see if it works when the add-on goes unresponsive.
                            If it doesn't work, be sure to check the logs for how HASS responded (it will be logged). My guess that data: line in the service data is redundant, and it's going to complain about it, but let's see.
                              I thought it might be as well, but I figured I'd start with the way it was in the YAML code. If it doesn't work, I'll remove that line. The add-on hasn't gone unresponsive since I implemented this, so I can't say if it works or not.
                                148.2k
