  4. Is there a way to restart an add-on in HAAS from MSR?
14 Posts 3 Posters 3.4k Views 3 Watching
    @therealdb, thanks for the quick response. I knew it had to be in the haas>system and some sort of system call, but I wasn't sure where. Thanks for the link. I have some reading to do.
      Finding this ID is proving to be a bit of a challenge. You found it on the network tab after you reloaded the page in the Chrome developer tools? This is what I'm seeing:
      • T tamorgen
        @tamorgen just filter for XHR and look for a call to
        /api/config/config_entries/entry/[ID]/reload
        after asking for a reload of the integration.
        Do not refresh the browser.
          I may have to try this at home. I'm going through Cloudflare to access my HA instance. Maybe it's interfering with what I'm trying to find.
            Are we speaking of this?
              @therealdb ,
              That's the one.
                ok, easier. Go to your homeassistant installation directory, look for an hidden .storage folder, and then core.config_entries. entry_id is the key you'll need.
                  @therealdb,
                  Revisiting. I never got this working. I think the issue is that the link provided talks about integrations, not add-ons.
                  I actually was able to create an automation through HAAS to do what I want to do through reactor. It looks like there is a addon_restart action in HAAS.
                  If this is an action, there should be in theory the same action in MSR.
                  @toggledbits, is there a way to call this action?
                  • T tamorgen
                    @therealdb,
                    @tamorgen said in Is there a way to restart an add-on in HAAS from MSR?:
                    Using Hass OS I assume? There's a command line tool you can use, described here. You would have to use that with a Shell action. If Reactor is running on the Hass OS system, that's probably easiest. Otherwise, you're going to have to write a script for the Shell action to execute that ssh's into your HassOS system to run their command line tool.
                      @toggledbits said in Is there a way to restart an add-on in HAAS from MSR?:
                      Yes, I posted that on the first post of the thread.
                      I think I may have figured out how to do it. I just need to see if it works when the add-on goes unresponsive.
                        If it doesn't work, be sure to check the logs for how HASS responded (it will be logged). My guess that data: line in the service data is redundant, and it's going to complain about it, but let's see.
                          I thought it might be as well, but I figured I'd start with the way it was in the YAML code. If it doesn't work, I'll remove that line. The add-on hasn't gone unresponsive since I implemented this, so I can't say if it works or not.
                            159.7k
