  4. Reactor-Editor / Reactor-ui-Status Errors
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
15 Posts 5 Posters 2.8k Views 6 Watching
  • SnowmanS Offline
    SnowmanS Offline
    Snowman
    @toggledbits I understand that you do not perform testing on Mac computers but thought I'd share the following with you in case something can be done.
    I started seeing these errors with version 24302. I thought that upgrading to 24343 would have fixed the issue but unfortunately not. I either have to close the browser or clear the cache for the errors to stop popping-up but they slowly come back.
    I see these errors on the following browsers:
    • Safari 16.6.1 on macOS Big Sur
    • Safari 18.1.1 on MacOS Sonoma
    • DuckDuckGo 1.118.0 on macOS Big Sur and Sonoma
    • Firefox 133.0.3 on macOS Big Sur
    • Chrome 131.0.6778 on macOS Big Sur
    Here are the errors
    Safari while creating/updating an expression
    @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:543:91
    makeExprMenu@http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:537:28
    @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:92:64
    @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:68
    each@http://192.168.0.13:8111/node_modules/jquery/dist/jquery.min.js:2:3133
    @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:35
    @http://192.168.0.13:8111/client/MessageBus.js:98:44
    forEach@[native code]
    @http://192.168.0.13:8111/client/MessageBus.js:95:54
    @http://192.168.0.13:8111/client/MessageBus.js:106:44
    @http://192.168.0.13:8111/client/Observable.js:78:28
    signalModified@http://192.168.0.13:8111/reactor/en-ca/lib/js/ee.js:146:21
    signalModified@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:40:29
    reindexExpressions@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:71:32
    @http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:608:40
    dispatch@http://192.168.0.13:8111/node_modules/jquery/dist/jquery.min.js:2:40040
    DuckDuckGo while clicking on status
    http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-status.js:789:44
    asyncFunctionResume@[native code]
    saveGridLayout@[native code]
    dispatchEvent@[native code]
    _triggerEvent@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:1401:30
    _triggerAddEvent@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:1383:31
    makeWidget@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:968:30
    addWidget@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:388:24
    placeWidgetAdder@http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-status.js:183:44
    Firefox while updating a rule
    notifySaved@http://192.168.0.13:8111/reactor/en-ca/lib/js/ee.js:82:21
    notifySaved@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:47:26
    @http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-rules.js:1460:39
    @http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-rules.js:1459:58
    Chrome while creating/updating an expression
    TypeError: Cannot read properties of undefined (reading 'getEditor')
        at RuleEditor.makeExprMenu (http://192.168.0.13:8111/reactor/en-ca/lib/js/rule-editor.js:1788:86)
        at Object.handler (http://192.168.0.13:8111/reactor/en-ca/lib/js/rule-editor.js:2174:54)
        at http://192.168.0.13:8111/client/MessageBus.js:98:44
        at MessageBus._sendToBus (http://192.168.0.13:8111/client/MessageBus.js:95:54)
        at MessageBus.send (http://192.168.0.13:8111/client/MessageBus.js:106:44)
        at ExpressionEditor.publish (http://192.168.0.13:8111/client/Observable.js:78:28)
        at ExpressionEditor.signalModified (http://192.168.0.13:8111/reactor/en-ca/lib/js/ee.js:146:14)
        at ExpressionEditor.signalModified (http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:40:15)
        at ExpressionEditor.reindexExpressions (http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:71:18)
      For the Status issue, you might try going to the Tools page and clicking on the Clear Local Storage link.
      Also, in each case, I need to know exactly what you were doing, and when/where/how the error was presented. At least one of these errors could be logged completely harmlessly, so it's not clear to me that you are reporting an actual problem that is preventing you from doing any work, or if you are just reporting something you see going by in the log that you noticed by chance.
        @toggledbits if I'm not mistaken, these are errors on the UI (I'm also seeing similar from time to time, but haven't yet reported any)
        • SnowmanS Offline
          SnowmanS Offline
          Snowman
          @toggledbits These errors are on the UI. Not from the logs. They are not preventing me from doing any work.
          For example, I'll go to Expressions, click the Add Expression, and when I click the Save Changes button, that is when these errors pop-up.
          Same goes with creating or updating a rule.
          I'll post a screenshot next time I see one.
          I'll try the Clear local storage suggestion and will let you know.
          • SnowmanS Snowman
            @Snowman said in Reactor-Editor / Reactor-ui-Status Errors:
            All of the errors you showed are in the context of the Rule Editor being active. Can you show an error message from using just the Expressions tab as in your example?
            So, this is progressive? Does it ever happen on the first use of the tab/function? Is it not resolved temporarily by simply refreshing the page/UI?
            • SnowmanS Offline
              SnowmanS Offline
              Snowman
              @toggledbits Below, the error and a screenshot while creating a new Global Expression, named "test". Hoping this helps answer your questions.
              As soon as I am done typing "test" and clicking in the field to add my formula, the error pops-up and will continue popping-up three times by the time it saved the changes. The error will also pop-up when I delete the expression and will pop-up a second time by the time it saved the changes.
              It did not happen on the first use of the tab/function. It took a few tries before I could re-produce the error. It does resolve itself after a page refresh.
                That's... crazy. You know those things programmers say "should never happen"?
                It's that.
                Digging.
                  I have similar popups, but I was never able to precisely replicate that. I'll keep an eye on the next and I'll report here as well.
                    Just got a runtime error in UI (build 24343) when I deleted a newly created rule. Before deleting this rule, I copied reactions to it from another rule. It also contained local variables (if that matters).
                    TypeError: Cannot read properties of undefined (reading 'getID')
                        at Data.getLongID (http://192.168.**.**:8111/client/Data.js:172:37)
                        at Data.toString (http://192.168.**.**:8111/client/Data.js:164:55)
                        at Data.getBusName (http://192.168.**.**:8111/client/Observable.js:65:32)
                        at RuleEditor.subscribe (http://192.168.**.**2:8111/client/Observer.js:91:200)
                        at RuleEditor.updateCurrentServiceValue (http://192.168.**.**:8111/reactor/fi-FI/lib/js/rule-editor.js:1094:34)
                    (macOS Sequoia & Chrome)
                      @tunnus said in Reactor-Editor / Reactor-ui-Status Errors:
                      I need a detail of every single step taken up the error popping up. Click by click, key by key. Also need to know what conditions were in the rule, and what actions were in the reactions.
                      • V Offline
                        V Offline
                        I do not think that this issue is limited to MAC computers. I also have seen similar errors with Chrome from a PC running Win 11.
                        Using MSR 25139 on Docker, on a Raspberry Pi with Bookworm. Home Assistant 2025.07, Z-Wave JS-UI 10.6.1
                        • V vezinpi
                          @vezinpi said in Reactor-Editor / Reactor-ui-Status Errors:
                          Do you have any more detail? I can't really do much with a "me too" post.
                          • V Offline
                            V Offline
                            @toggledbits Sorry about that. I wrote a second post following that one but probably never hit submit. My bad
                            MSR Version 24302
                            I simply push the play button for the "Set reaction" of a rule. The action performed as expected even with the error message. (since this happened yesterday, I am just re-typing the error from the screen capture for easy reading)
                            EDIT 1: I noticed that the error message was showing 15 second after I push the play button. Since I have a delay in the "Set reaction", I try to remove it and this error is gone. Somehow the delay I am using prior to the "Entity Action" is causing this timeout error.
                            Error: Command timeout (195 start_reaction) at _ClientAPI._commandTimeout (http://192.168.2.163:8111/client/clientAPI.js:552:136)
                            Here is a different one, more inline with this post, that I just did by editing a "Date/Time" trigger from 8:05h to 8:10h and save. The error message occured when I pushed the save button. The action (save) actually work despite the error message.
                            at RuleEditor.makeExprMenu (http://192.168.2.163:8111/reactor/en-US/lib/js/rule-editor.js:1788:86)
                            at Object.handler (http://192.168.2.163:8111/reactor/en-US/lib/js/rule-editor.js:2174:54)
                            at http://192.168.2.163:8111/client/MessageBus.js:49:44
                            at MessageBus._sendToBus (http://192.168.2.163:8111/client/MessageBus.js:46:54)
                            at MessageBus.send (http://192.168.2.163:8111/client/MessageBus.js:57:44)
                            at ExpressionEditor.publish (http://192.168.2.163:8111/client/Observable.js:51:37)
                            at ExpressionEditor.notifySaved (http://192.168.2.163:8111/reactor/en-US/lib/js/ee.js:82:14)
                            at ExpressionEditor.notifySaved (http://192.168.2.163:8111/reactor/en-US/lib/js/expression-editor.js:47:15)
                            at http://192.168.2.163:8111/reactor/en-US/lib/js/reactor-ui-rules.js:1459:28
                            • V vezinpi
                              MSR Version 24302
                              That issue was known and handled in 24343.
                              For the other message, can you show all the conditions and reactions in the rule?
                              • V Offline
                                V Offline
                                Thanks for the update and sorry about the timeout issue, I was not aware of it.
                                Here is the requested rule:
                                • Next Release?
