  4. Reactor-Editor / Reactor-ui-Status Errors
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
15 Posts 5 Posters 4.3k Views 6 Watching
  • toggledbitsT Online
    toggledbitsT Online
    For the Status issue, you might try going to the Tools page and clicking on the Clear Local Storage link.
    Also, in each case, I need to know exactly what you were doing, and when/where/how the error was presented. At least one of these errors could be logged completely harmlessly, so it's not clear to me that you are reporting an actual problem that is preventing you from doing any work, or if you are just reporting something you see going by in the log that you noticed by chance.
      @toggledbits if I'm not mistaken, these are errors on the UI (I'm also seeing similar from time to time, but haven't yet reported any)
      • SnowmanS Offline
        SnowmanS Offline
        Snowman
        @toggledbits These errors are on the UI. Not from the logs. They are not preventing me from doing any work.
        For example, I'll go to Expressions, click the Add Expression, and when I click the Save Changes button, that is when these errors pop-up.
        Same goes with creating or updating a rule.
        I'll post a screenshot next time I see one.
        I'll try the Clear local storage suggestion and will let you know.
        • SnowmanS Snowman
          toggledbitsT Online
          toggledbitsT Online
          @Snowman said in Reactor-Editor / Reactor-ui-Status Errors:
          All of the errors you showed are in the context of the Rule Editor being active. Can you show an error message from using just the Expressions tab as in your example?
          I either have to close the browser or clear the cache for the errors to stop popping-up but they slowly come back.
          So, this is progressive? Does it ever happen on the first use of the tab/function? Is it not resolved temporarily by simply refreshing the page/UI?
          • SnowmanS Offline
            SnowmanS Offline
            Snowman
            @toggledbits Below, the error and a screenshot while creating a new Global Expression, named "test". Hoping this helps answer your questions.
            As soon as I am done typing "test" and clicking in the field to add my formula, the error pops-up and will continue popping-up three times by the time it saved the changes. The error will also pop-up when I delete the expression and will pop-up a second time by the time it saved the changes.
            It did not happen on the first use of the tab/function. It took a few tries before I could re-produce the error. It does resolve itself after a page refresh.
            @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:543:91
            makeExprMenu@http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:537:28
            @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:92:64
            @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:68
            each@http://192.168.0.13:8111/node_modules/jquery/dist/jquery.min.js:2:3133
            @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:35
            @http://192.168.0.13:8111/client/MessageBus.js:98:44
            forEach@[native code]
            @http://192.168.0.13:8111/client/MessageBus.js:95:54
            @http://192.168.0.13:8111/client/MessageBus.js:106:44
            @http://192.168.0.13:8111/client/Observable.js:78:28
            signalModified@http://192.168.0.13:8111/reactor/en-ca/lib/js/ee.js:146:21
            signalModified@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:40:29
            reindexExpressions@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:71:32
            @http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:608:40
            dispatch@http://192.168.0.13:8111/node_modules/jquery/dist/jquery.min.js:2:40040
              toggledbitsT Online
              That's... crazy. You know those things programmers say "should never happen"?
              It's that.
              Digging.
                I have similar popups, but I was never able to precisely replicate that. I'll keep an eye on the next and I'll report here as well.
                  Just got a runtime error in UI (build 24343) when I deleted a newly created rule. Before deleting this rule, I copied reactions to it from another rule. It also contained local variables (if that matters).
                  TypeError: Cannot read properties of undefined (reading 'getID')
                      at Data.getLongID (http://192.168.**.**:8111/client/Data.js:172:37)
                      at Data.toString (http://192.168.**.**:8111/client/Data.js:164:55)
                      at Data.getBusName (http://192.168.**.**:8111/client/Observable.js:65:32)
                      at RuleEditor.subscribe (http://192.168.**.**2:8111/client/Observer.js:91:200)
                      at RuleEditor.updateCurrentServiceValue (http://192.168.**.**:8111/reactor/fi-FI/lib/js/rule-editor.js:1094:34)
                  (macOS Sequoia & Chrome)
                    toggledbitsT Online
                    toggledbitsT Online
                    @tunnus said in Reactor-Editor / Reactor-ui-Status Errors:
                    I need a detail of every single step taken up the error popping up. Click by click, key by key. Also need to know what conditions were in the rule, and what actions were in the reactions.
                    • V Offline
                      V Offline
                      I do not think that this issue is limited to MAC computers. I also have seen similar errors with Chrome from a PC running Win 11.
                      • V vezinpi
                        toggledbitsT Online
                        toggledbitsT Online
                        @vezinpi said in Reactor-Editor / Reactor-ui-Status Errors:
                        Do you have any more detail? I can't really do much with a "me too" post.
                        • V Offline
                          V Offline
                          @toggledbits Sorry about that. I wrote a second post following that one but probably never hit submit. My bad
                          MSR Version 24302
                          I simply push the play button for the "Set reaction" of a rule. The action performed as expected even with the error message. (since this happened yesterday, I am just re-typing the error from the screen capture for easy reading)
                          EDIT 1: I noticed that the error message was showing 15 second after I push the play button. Since I have a delay in the "Set reaction", I try to remove it and this error is gone. Somehow the delay I am using prior to the "Entity Action" is causing this timeout error.
                          Error: Command timeout (195 start_reaction) at _ClientAPI._commandTimeout (http://192.168.2.163:8111/client/clientAPI.js:552:136)
                          Here is a different one, more inline with this post, that I just did by editing a "Date/Time" trigger from 8:05h to 8:10h and save. The error message occured when I pushed the save button. The action (save) actually work despite the error message.
                          TypeError: Cannot read properties of undefined (reading 'getEditor')
                          at RuleEditor.makeExprMenu (http://192.168.2.163:8111/reactor/en-US/lib/js/rule-editor.js:1788:86)
                          at Object.handler (http://192.168.2.163:8111/reactor/en-US/lib/js/rule-editor.js:2174:54)
                          at http://192.168.2.163:8111/client/MessageBus.js:49:44
                          at MessageBus._sendToBus (http://192.168.2.163:8111/client/MessageBus.js:46:54)
                          at MessageBus.send (http://192.168.2.163:8111/client/MessageBus.js:57:44)
                          at ExpressionEditor.publish (http://192.168.2.163:8111/client/Observable.js:51:37)
                          at ExpressionEditor.notifySaved (http://192.168.2.163:8111/reactor/en-US/lib/js/ee.js:82:14)
                          at ExpressionEditor.notifySaved (http://192.168.2.163:8111/reactor/en-US/lib/js/expression-editor.js:47:15)
                          at http://192.168.2.163:8111/reactor/en-US/lib/js/reactor-ui-rules.js:1459:28
                          • V vezinpi
                            MSR Version 24302
                            toggledbitsT Online
                            toggledbitsT Online
                            That issue was known and handled in 24343.
                            For the other message, can you show all the conditions and reactions in the rule?
                            • V Offline
                              V Offline
                              Thanks for the update and sorry about the timeout issue, I was not aware of it.
                              Here is the requested rule:
                                165.6k
