  4. [SOLVED] reactor_inet_check script... and containers
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
9 Posts 3 Posters 2.2k Views 3 Watching
    When on my bare metal RPi with MSR I had a rule that ran every minute to check Internet status via a script in MSR called reactor_inet_check.sh
    I've moved to containerized MSR and see in the instructions that this cannot be run from the container.
    The script cannot run within the Reactor docker container. If you are using Reactor in a docker container, the script needs to be run by cron or an equivalent facility on the host system (e.g. some systems, like Synology NAS, have separate task managers that may be used to schedule the repeated execution of tasks such as this).
    I've put a script on my container host that calls the reator_inet_check.sh script and it isn't erroring... but I still see the internet status within MSR as null.
    Before I go diving down the rabbit hole... should this work?
    My cronjob on the proxmox host:
    The contents of msr_internet_check_caller.sh
    *Hubitat C-7 2.5.0.143
    Core 2026.5.3
    MSR: latest-26143-a81ae8ba
      OK, first, please don't screen shot text, especially code, logs, and scripts. Learn to use fenced code blocks: put three back-ticks ``` on a line by itself, then follow with the text, the close with another three back-ticks ``` on a line by itself. When formatted, it will look like this:
      #!/bin/bash
      # Execute the script inside the container
      pct exec 101 -- bash -c "cd /home/reactor/reactor;./reactor_inet_check.sh"
      The path for the script is suspicious and likely wrong. The reactor_inet_check.sh script has to be run from the Reactor install directory, and doing so would give you a script run path of ./tools/reactor_inet_check.sh. The script is built to run only this way. That's in the script header's instructions.
      But also, you are trying to run the script from the Proxmox host, which I guess you can do, but it's unnecessarily hard and makes the configuration dependent on the VMID. I recommend that you run it from Ubuntu. All that's required is this in your Ubuntu root crontab:
          * * * * cd /home/reactor && ./tools/reactor_inet_check.sh
      The Ubuntu /var/log/syslog should have information about the success of those runs.
      If you're using Reactor access control (i.e. you are configured to required login to access Reactor), you probably will also need to add an ACL to permit the script to use the API.
        #!/bin/bash
        @toggledbits I know how to tick code - I just didn't think at that hour it would be necessary. Apologies.
        Because, YES, trying to configure this from the Proxmox host is devilish, I've added this now to Unbuntu root crontab with:
        sudo crontab -e
        # MSR script to perform internet check every minute
        * * * * * cd /home/reactor/reactor && tools/reactor_inet_check.sh
        Looking into the ACL now as I do have Access Control enabled.
        EDIT
        Taking things in smaller bites... I've renamed users.yaml so Access Control is disabled. Let's start easy 🙂
        Cron is running. To me, this reads like it's running just fine.
        2025-01-18T13:08:01.129250-05:00 msr CRON[21717]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:09:01.161220-05:00 msr CRON[21737]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:10:01.223057-05:00 msr CRON[21769]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:10:18.126046-05:00 msr systemd[1]: Starting sysstat-collect.service - system activity accounting tool...
        2025-01-18T13:10:18.131608-05:00 msr systemd[1]: sysstat-collect.service: Deactivated successfully.
        2025-01-18T13:10:18.131786-05:00 msr systemd[1]: Finished sysstat-collect.service - system activity accounting tool.
        2025-01-18T13:11:01.254645-05:00 msr CRON[21797]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:12:01.315036-05:00 msr CRON[21821]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:13:01.347216-05:00 msr CRON[21844]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        Looking at the Reactor System Entity, however, I still see
        reactor_system.internet_ok=null
        Core 2026.5.3
          sudo crontab -e
          EDIT
          @toggledbits Most days I'm not very smart... but I'm stubborn.
          This is working.
          It has kept working thru multiple MSR restarts. (I have not yet tested a container restart.)
          I'm not 100% sure why it's working, tbh. I think one more MSR restart cleared the cobwebs and it was suddenly fine. I then added an ACL before putting back Access Control which brings me to...
          I also have Access Control back in place and using a hashed pwd (which for some reason eluded me when I tried to enable it previously.)
          On this day we're calling it "Two steps back, three forward."
          Thanks for your help as always.
          Core 2026.5.3
            This is working.
            @gwp1 said in [SOLVED] reactor_inet_check script... and containers:
            It's good to know I'm in good company.
              A worthy quality
                @gwp1 any chance you could share the script?
                TIA
                  TIA
                  @CatmanV2 reactor_inet_check.sh and it's in your Reactor /tools directory. You don't touch it, just call it.
                  Then pull the output into a rule
                  13d46371-bc40-4cf9-a481-83ca28d1025d-image.png and trigger whatever alerting you'd like.
                  Core 2026.5.3
                    Oooh thanks!
                      120.3k
