  4. [SOLVED] reactor_inet_check script... and containers
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
9 Posts 3 Posters 1.9k Views 3 Watching
    When on my bare metal RPi with MSR I had a rule that ran every minute to check Internet status via a script in MSR called reactor_inet_check.sh
    I've moved to containerized MSR and see in the instructions that this cannot be run from the container.
    The script cannot run within the Reactor docker container. If you are using Reactor in a docker container, the script needs to be run by cron or an equivalent facility on the host system (e.g. some systems, like Synology NAS, have separate task managers that may be used to schedule the repeated execution of tasks such as this).
    I've put a script on my container host that calls the reator_inet_check.sh script and it isn't erroring... but I still see the internet status within MSR as null.
    Before I go diving down the rabbit hole... should this work?
    My cronjob on the proxmox host:
    The contents of msr_internet_check_caller.sh
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
      OK, first, please don't screen shot text, especially code, logs, and scripts. Learn to use fenced code blocks: put three back-ticks ``` on a line by itself, then follow with the text, the close with another three back-ticks ``` on a line by itself. When formatted, it will look like this:
      #!/bin/bash
      # Execute the script inside the container
      pct exec 101 -- bash -c "cd /home/reactor/reactor;./reactor_inet_check.sh"
      The path for the script is suspicious and likely wrong. The reactor_inet_check.sh script has to be run from the Reactor install directory, and doing so would give you a script run path of ./tools/reactor_inet_check.sh. The script is built to run only this way. That's in the script header's instructions.
      But also, you are trying to run the script from the Proxmox host, which I guess you can do, but it's unnecessarily hard and makes the configuration dependent on the VMID. I recommend that you run it from Ubuntu. All that's required is this in your Ubuntu root crontab:
          * * * * cd /home/reactor && ./tools/reactor_inet_check.sh
      The Ubuntu /var/log/syslog should have information about the success of those runs.
      If you're using Reactor access control (i.e. you are configured to required login to access Reactor), you probably will also need to add an ACL to permit the script to use the API.
        #!/bin/bash
        @toggledbits I know how to tick code - I just didn't think at that hour it would be necessary. Apologies.
        Because, YES, trying to configure this from the Proxmox host is devilish, I've added this now to Unbuntu root crontab with:
        sudo crontab -e
        # MSR script to perform internet check every minute
        * * * * * cd /home/reactor/reactor && tools/reactor_inet_check.sh
        Looking into the ACL now as I do have Access Control enabled.
        EDIT
        Taking things in smaller bites... I've renamed users.yaml so Access Control is disabled. Let's start easy 🙂
        Cron is running. To me, this reads like it's running just fine.
        2025-01-18T13:08:01.129250-05:00 msr CRON[21717]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:09:01.161220-05:00 msr CRON[21737]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:10:01.223057-05:00 msr CRON[21769]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:10:18.126046-05:00 msr systemd[1]: Starting sysstat-collect.service - system activity accounting tool...
        2025-01-18T13:10:18.131608-05:00 msr systemd[1]: sysstat-collect.service: Deactivated successfully.
        2025-01-18T13:10:18.131786-05:00 msr systemd[1]: Finished sysstat-collect.service - system activity accounting tool.
        2025-01-18T13:11:01.254645-05:00 msr CRON[21797]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:12:01.315036-05:00 msr CRON[21821]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:13:01.347216-05:00 msr CRON[21844]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        Looking at the Reactor System Entity, however, I still see
        reactor_system.internet_ok=null
        Core 2026.1.1
          sudo crontab -e
          EDIT
          @toggledbits Most days I'm not very smart... but I'm stubborn.
          This is working.
          It has kept working thru multiple MSR restarts. (I have not yet tested a container restart.)
          I'm not 100% sure why it's working, tbh. I think one more MSR restart cleared the cobwebs and it was suddenly fine. I then added an ACL before putting back Access Control which brings me to...
          I also have Access Control back in place and using a hashed pwd (which for some reason eluded me when I tried to enable it previously.)
          On this day we're calling it "Two steps back, three forward."
          Thanks for your help as always.
          Core 2026.1.1
            This is working.
            @gwp1 said in [SOLVED] reactor_inet_check script... and containers:
            It's good to know I'm in good company.
              A worthy quality
                @gwp1 any chance you could share the script?
                TIA
                  TIA
                  @CatmanV2 reactor_inet_check.sh and it's in your Reactor /tools directory. You don't touch it, just call it.
                  Then pull the output into a rule
                  13d46371-bc40-4cf9-a481-83ca28d1025d-image.png and trigger whatever alerting you'd like.
                  Core 2026.1.1
                    Oooh thanks!
                      97.6k
                    • Next Release?
