  4. ZwaveJSUI - RGBWW BULB - Warm/Cold White interfered with RGB settings - Bulb doesn't change color if in WarmWhite state.
9 Posts 2 Posters 2.5k Views 2 Watching
  • N Offline
    N Offline
    wrote on last edited by noelab
    Hi ,
    I'm on
    -Reactor (Multi-hub) latest-25067-62e21a2d
    -Docker on Synology NAS
    -ZWaveJSUI 9.31.0.6c80945
    Problem with ZwaveJSUI:
    When I try to change color to a bulb RGBWW, it doesn't change to the RGB color and the bulb remains warm or cold white.
    I tryed with Zipato RGBW Bulb V2 RGBWE2, Hank Bulb HKZW-RGB01, Aentec 6 A-ZWA002, so seems that it happens with all RGBWW bulb with reactor/zwavejsui.
    I'm using from reator the entity action: "rgb_color.set" and "rgb_color.set_rgb".
    After I send the reactor command, It changes in zwavejsui the rgb settings but doesn't put the white channel to "0", so the prevalent channel remains warm/cold White and the bulb doesn't change into the rgb color.
    This is the status of the bulb in zwavejsui after "rgb_color.set" (235,33,33,) and the bulb is still warmWhite.
    x_zwave_values.Color_Switch_currentColor={"warmWhite":204,"coldWhite":0,"red":235,"green":33,"blue":33}
    The "cold white" and "warm white" settings interfer with the rgb color settings.
    Reactor can change bulb colors with rgb_color set — (value, ui8, 0x000000 to 0xffffff) or rgb_color set_rgb — (red, green, blue, all ui1, 0 to 255) but if warm or cold white
    are not to "0", zwavejsui doesn't change them and I can't find a way to change into rgb or from rgb back to warm white.
    So if I use from reactor: rgb_color set_rgb — (235,33,33) in zwavejsui I have
    x_zwave_values.Color_Switch_targetColor={"red":235,"green":33,"blue":33}
    14/03/2025, 16:43:57 - value updated
    Arg 0:
    └─commandClassName: Color Switch
    └─commandClass: 51
    └─property: targetColor
    └─endpoint: 0
    └─newValue
    └──red: 235
    └──green: 33
    └──blue: 33
    └─prevValue
    └──red: 235
    └──green: 33
    └──blue: 33
    └─propertyName: targetColor
    Arg 0:
    └─commandClass: 51
    └─property: currentColor
    └─endpoint: 0
    └─newValue
    └──warmWhite: 204
    └──coldWhite: 0
    └──red: 235
    └──green: 33
    └──blue: 33
    └─prevValue
    └──warmWhite: 204
    └──coldWhite: 0
    └──red: 235
    └──green: 33
    └──blue: 33
    └─propertyName: currentColor
    In zwavejsui, the bulb changes rgb set but warm White remains to "204" and the bulb remais on warm White channel bacause is prevalent on rgb set.
    x_zwave_values.Color_Switch_currentColor_0=204
    x_zwave_values.Color_Switch_currentColor_1=0
    x_zwave_values.Color_Switch_currentColor_2=235
    x_zwave_values.Color_Switch_currentColor_3=33
    x_zwave_values.Color_Switch_currentColor_4=33
    Is it possible to targetColor also for "warmWhite" and "coldWhite" and have something similar to this?
    x_zwave_values.Color_Switch_targetColor={"warmWhite":0,"coldWhite":0,"red":235,"green":33,"blue":33}
    Thanks in advance.
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
      Please update this report with more details and specifics. Honestly, I can't parse what is working and what is not from your submission so far. I have no idea what a "scope" is. I don't have this device, so if it's something specific to the device, you'll need to include information about that. Please edit t he head post rather than adding a reply here, preferably.
        Thanks for the update. When I read this, I'm reading that Reactor is operating correctly, doing the same thing that ZWaveJS UI is doing when you change the RGB color, you just want an additional function to be able to change both the RGB and white (one or two channels) at the same time?
        If that's not correct, bring me up to speed, and also copy and paste the full attributes for a representative entity (there's a button in the entity detail pane to copy all attributes shown).
        • N Offline
          N Offline
          Correct! Without this function, I don't know how to make the bulb RGBWW work properly.
          Thanks to you!
          -ZWaveJS-UI 11.22.3
          -Update 16/08/2026
            What's the node ID of the bulb (node number)?
            • N Offline
              N Offline
              040 = L Bulb Ball 1 Z-RGBW2
              036 = R3 Bulb Roof 1 HKZW-RGB01
              033 = R3 Bulb Wall 1 A-ZWA002
              -ZWaveJS-UI 11.22.3
              -Update 16/08/2026
                You will not be able to set these in one action. You will need to set x_zwave_values.Color_Switch_targetColor_0 to 0 in another action to turn the warm white channel off, and likewise x_zwave_values.Color_Switch_targetColor_1 to 0 to turn off the cold white channel. The intensity of these channels can be set by setting other values up to 255.
                It should be possible to set x_zwave_values.Color_Switch_targetColor with a JSON string, but that is not currently supported in ZWaveJSController. That would allow you to set everything at once. I will work on it.
                • N Offline
                  N Offline
                  Hi, thank you for the new update and I'm testing it under:
                  Reactor build 25082
                  ZWaveJSController build 25082
                  -ZWaveJSUI 10.1.3
                  Trying with these values but nothing happens (in zwavejs events and in reactor logs). Am I doing something wrong with JSON string value fields?
                  in zwavejsui
                  -ZWaveJS-UI 11.22.3
                  -Update 16/08/2026
                    First, always look at the logs. I'm 100% certain that "nothing happens" isn't what's in the logs.
                    It looks like the device has separate targetValue values for the white channels, so you may just need to use those. That means for red, green, and blue, you'll use targetValue for the property with a JSON object, but leave the propertyKey blank. For warm white, you use property targetValue with propertyKey zero (0), and for cold white you'll use propertyKey one (1).
                    Edit: look at the logs
                      161.8k
