  4. Can't customize home page
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
15 Posts 2 Posters 1.9k Views 2 Watching
    I foolishly let my system wipe all cookies this morning and with it my settings for my MSR home page.
    Once logged back in I can no longer remove errant panes nor is the + available to add new ones.
    Brave Browser v1.80.122 (Jul 16, 2025)
    What have I done?!
    Will check other browsers on my M1.
    UPDATE: Safari exhibits same behaviour.
    I've tried both sans last-four public key entry and with - no change.
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
      What have I done?!
      Interestingly, this is still fine on my Intel Mac (though I've not cleared the cookies there and won't at this point).
      Core 2026.1.1
        First, try just a hard refresh of the browser and go back to the Status page.
        If that doesn't do it, there's a somewhat hidden "Clear Local Storage" link on the Tools page... hit that and then hard refresh and go back to Status.
          @toggledbits I'd just now finished doing first a hard refresh and then just killing the browser completely and restarting.
          Nada.
          Did the "Clear Local Storage" and hard refresh and saw the one change I'd made was gone. The issue, however, persists.
          I know Brave just updated in the last day or two...
          Core 2026.1.1
            Hit F12 for the developer window, then click the Console tab. Any errors?
              @toggledbits the only thing it calls out is:
              No label associated with a form field
              A <label> isn't associated with a form field.
              To fix this issue, nest the <input> in the <label> or provide a for attribute on the <label> that matches a form field id.
              1 resource
              Violating node
              Clicking the "Affected resource/violating node" nets me:
              <label id="ep-filter-label" class="form-label mt-1 pe-1">Filters:</label>
              Core 2026.1.1
                Yeah, that won't do it. Do you see a line that reads "Placing widget at" or "Moving widget-adder to" anywhere?
                  @toggledbits I see the "Placing widget at"
                  UI TIME CHECK: Browser 2025-07-20T22:50:33.935Z offset -240 ; host 2025-07-20T22:50:33.933Z offset(mins) -240 ; diff(ms) 2
                  reactor-ui-status.js:226 Placing widget-adder at 8
                  reactor-ui-status.js:913 saveGridLayout()
                  reactor-ui-status.js:924 SAVE DATA Array(4)
                  reactor-ui-status.js:928 Fixup widget widget3 at x/y 0 0 w/h 8 2
                  reactor-ui-status.js:928 Fixup widget widget0 at x/y 8 0 w/h 3 2
                  reactor-ui-status.js:928 Fixup widget widget1 at x/y 0 2 w/h 6 2
                  reactor-ui-status.js:928 Fixup widget widget2 at x/y 6 2 w/h 6 2
                  Would a .har contain all of this?
                  Just to show I'm not entirely crazy here...
                  Core 2026.1.1
                    Is your VM Intel/AMD?
                      @toggledbits hosting in Portainer. Says 90f92c5b-34c0-4a96-a22c-ece61282e5b2-image.png
                      Core 2026.1.1
                        Great. Update to the latest container image and try again.
                        G 2 Replies Last reply
                          @toggledbits missed this last night - will do so this afternoon and advise.
                          Core 2026.1.1
                            @toggledbits Yahtzee! That did it.
                            So I... wasn't... crazy?
                            Core 2026.1.1
                              @gwp1 said in Can't customize home page:
                              Absolutely not. That's my role. 😉
                                @toggledbits appreciate the quick turnaround on this. It def caught me off-guard.
                                Core 2026.1.1
                                • Next Release?
                                  1.0k
