  4. Can't customize home page
15 Posts 2 Posters 3.0k Views 2 Watching
    I foolishly let my system wipe all cookies this morning and with it my settings for my MSR home page.
    Once logged back in I can no longer remove errant panes nor is the + available to add new ones.
    Brave Browser v1.80.122 (Jul 16, 2025)
    What have I done?!
    Will check other browsers on my M1.
    UPDATE: Safari exhibits same behaviour.
    I've tried both sans last-four public key entry and with - no change.
      What have I done?!
      Interestingly, this is still fine on my Intel Mac (though I've not cleared the cookies there and won't at this point).
        First, try just a hard refresh of the browser and go back to the Status page.
        If that doesn't do it, there's a somewhat hidden "Clear Local Storage" link on the Tools page... hit that and then hard refresh and go back to Status.
          @toggledbits I'd just now finished doing first a hard refresh and then just killing the browser completely and restarting.
          Nada.
          Did the "Clear Local Storage" and hard refresh and saw the one change I'd made was gone. The issue, however, persists.
          I know Brave just updated in the last day or two...
            Hit F12 for the developer window, then click the Console tab. Any errors?
              @toggledbits the only thing it calls out is:
              No label associated with a form field
              A <label> isn't associated with a form field.
              To fix this issue, nest the <input> in the <label> or provide a for attribute on the <label> that matches a form field id.
              1 resource
              Violating node
              Clicking the "Affected resource/violating node" nets me:
              <label id="ep-filter-label" class="form-label mt-1 pe-1">Filters:</label>
                Yeah, that won't do it. Do you see a line that reads "Placing widget at" or "Moving widget-adder to" anywhere?
                  @toggledbits I see the "Placing widget at"
                  UI TIME CHECK: Browser 2025-07-20T22:50:33.935Z offset -240 ; host 2025-07-20T22:50:33.933Z offset(mins) -240 ; diff(ms) 2
                  reactor-ui-status.js:226 Placing widget-adder at 8
                  reactor-ui-status.js:913 saveGridLayout()
                  reactor-ui-status.js:924 SAVE DATA Array(4)
                  reactor-ui-status.js:928 Fixup widget widget3 at x/y 0 0 w/h 8 2
                  reactor-ui-status.js:928 Fixup widget widget0 at x/y 8 0 w/h 3 2
                  reactor-ui-status.js:928 Fixup widget widget1 at x/y 0 2 w/h 6 2
                  reactor-ui-status.js:928 Fixup widget widget2 at x/y 6 2 w/h 6 2
                  Would a .har contain all of this?
                  Just to show I'm not entirely crazy here...
                    Is your VM Intel/AMD?
                      @toggledbits hosting in Portainer. Says 90f92c5b-34c0-4a96-a22c-ece61282e5b2-image.png
                        Great. Update to the latest container image and try again.
                        G 2 Replies Last reply
                          @toggledbits missed this last night - will do so this afternoon and advise.
                            @toggledbits Yahtzee! That did it.
                            So I... wasn't... crazy?
                              @gwp1 said in Can't customize home page:
                              Absolutely not. That's my role. 😉
                                @toggledbits appreciate the quick turnaround on this. It def caught me off-guard.
                                  158.4k
