  4. The reaction stopped working (Google Nest max playing a video)
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
9 Posts 3 Posters 1.3k Views 4 Watching
  • F Offline
    Hi!
    I've have had a mp4 (video) file playing on my Google Nest Max at specific times. A few weeks ago it stopped working. I´ve tried everything but the correct way...
    fad3f664-456d-491e-acb6-c145ef76e925-image.png I've changed the boxes above countless times. What is the correct info in each box?
    I can do it within Home Assistant, but not in MSR.
    My MSR installation is on version 25208-c53e8513, my HA is 2025.9.4.
    I´m grateful for any pointers and help.
    /Fanan
    • F Fanan
      Hi!
      /Fanan
      @Fanan Build 25304 has the necessary changes to support what has changed in Home Assistant. The following is an example action to play media in the new model:
      The first example in the screen shot below shows how to format the object field that Home Assistant needs as JSON. The second example shows how to use YAML for the field.
        The action you are using is created from data passed from Home Assistant for that service. It looks like they changed the definition of that service since you created the Reaction. When did you upgrade your Home Assistant install, and what revision was running before? It looks like they haven't even yet updated their documentation to coincide with the revised service data, either.
        Edit/update:
        The fields that have (extension) in the value are Reactor telling you that it has parameter data for the action in this reaction that the action definition now doesn't define. It preserves that data so you can copy it to the correct fields in HA's expected (new) format. Based on what I see in my installation (HA 2025.9.3), it looks like they moved the media_content_... fields into an object supplied by a new media field. Using your preserved data, the media field should now contain:
        { "media_scontent_id": "http://192.../fredag.mp4", "media_content_type": "video" }
        Once you make that change, clear out the extension fields and exit the editor, and they will go away (not appear next time you edit this reaction).
        That's a pretty nasty breaking change. And I'm still trying to find where HA documented it. So far, no luck. This is why I track HA version numbers and have the UI complain when it sees something unexpected, but in this case, there's so far no telling when this change happened.
        They also introduced a new data type in their service definition data for that media field, so I'll make sure the next version of HassController supports it and gives you a more appropriate field size for entering/editing that data.
        Edit 2: FOUND IT! It's listed only as "Use media_selector for media_player.play_media" on this pull request, marked as a breaking change, but... not called out as such in their general release notes. My biggest issue with HA has always been the frequency of breaking changes, and like this, that they often miss spelling them out. Sometimes, we're just going to discover these things by accidents like this.
        By the way, if you recently upgraded your HA install and something stops working, it's probably a good idea to mention that upgrade in your post.
        F 1 Reply Last reply
          Edit/update:
          @toggledbits Thank you for the hard work! 🙏
          I can´t get it to work just yet, but maybe it get easier after the next update.
          Right now I only get the Runtime error: "[object Object]", no matter what I do. I´ll keep on trying.
          /Fanan
          • F Fanan
            /Fanan
            @Fanan Ok, I'm gonna jump in here now. I just added a Switchbot Tilt Blind to my system and it is giving me the same
            [object Object]
            response when I go to Entities > Perform to test position.set.
            Wasn't gonna say anything as @toggledbits is focused on the above items and it seemed a distraction.
            I am on HA 2025.9.4 but installed the Switchbot just in the last 48 hours so didn't draw the line between them connecting the dots.
            *Hubitat C-7 2.4.3.177
            Core 2026.1.1
            MSR: latest-26011-c621bbc7
              Odds are there's something logged. This is why I always say, go look at the log files when something isn't working. When you find it, post with context, don't just post the one or two line error message.
              @gwp1 in your case I would also like to see posted the attributes of the new device (using the Copy Attributes button, not a screen shot).
              I'll be away all weekend, unfortunately, so this won't get more attention until Monday.
                cover.state=true
                position.step=0.1
                position.value=1
                x_hass.domain="cover"
                x_hass.entity_id="cover.living_room_right_blind"
                x_hass.services=["cover","switchbot_cloud"]
                x_hass.source="switchbot_cloud"
                x_hass.state="open"
                x_hass_attr.current_position=100
                x_hass_attr.current_tilt_position=100
                x_hass_attr.device_class="blind"
                x_hass_attr.friendly_name="Living Room Right Blind"
                x_hass_attr.supported_features=176
                And there's absolutely no rush on this specific item. The blind is opening and closing, just opposite of what I want it to and I'm fighting with learning HA templates to try and achieve this. Switchbot approaches tilting in a unique way.
                Core 2026.1.1
                  Logs will definitely be your friend right now. If HA is returning an error on a request, the detail of that error is logged, along with the request that was sent to HA and the full response from HA. There are rules for fields that HA doesn't publish in its service data APIs, and that can vary by device and even firmware, so sometimes, you just have to "go low" to figure out how to talk to them.
                  • F Offline
                    I finally got the time to dive deeper into my issue. I ended up creating scripts within HA, which I triggered from MSR. Tried to do everything with only MSR, but I couldn´t in the end. So for now, this was my solution - creating and triggering scripts.
                    Thanks as always for all help!!
                    • F Fanan
                      Hi!
                      /Fanan
                      • toggledbitsT toggledbits has marked this topic as solved on
                        229
                        3.6k
                        3.2k
                        757
