  4. Reactor Loading Screen Safari
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
Reset a delay
10 Posts 5 Posters 465 Views 5 Watching
    When starting MSR, I started getting “Loading Reactor” Screen everytime. Pressing refresh multiple times the page will load or click on any of the menu links and the status page will then display and everything will work normally. It appears to be a safari only issue as it loads fine in chrome. I don’t know exactly when it stared, if it was updating to one of the newer builds or updating the Mac to 26.1. This is probably not a MSR problem but I thought I would share in case. Cleared cache, hard reset browser, private window and restarted MSR. Below is a screenshot of the web console while stuck. The error that says Object does not exist, the rule is there and functioning.
    Thanks,
    Synology Docker
    latest-25325-2c235fbb
    Mac Safari 26.1
      Those errors are benign -- they just say that there's a Rule or Reaction in the Rule or Reaction history that no longer exists (or it's a sub-reaction, like a Group or Repeat/While action in a Reaction). Everything else is as expected. There are probably a dozen or so lines preceding this screen shot that could have other errors, but since it got this far, I doubt it. Confirming... this is while "Loading Reactor..." is still the only thing displayed on the screen?
      Also what was the prior build of Reactor you were using? Were you far behind, or just a build or three?
      Since I don't have any Apple products, I don't really support Safari. That's stated in the docs. I'm happy to chase this a bit to see if we can figure it out, but only to a point.
      S 1 Reply Last reply
        FWIW I'm Apple only, happy to test where I can.
        Certainly no issues with Chrome on various versions of iOS
          @toggledbits Confirming that is while the Loading Reactor screen. See Screenshot:
          Screenshot 2025-12-10 at 6.27.38 AM.png And two more screenshots of the web inspector.
          Screenshot 2025-12-10 at 6.28.53 AM.png Understand you not having apple products, So Thank You!
            @CatmanV2 Can you try Safari on a Mac Desktop or the IOS. It does it on both on my setup.
              I had about 0.5s glimpse of 'Loading reactor'
              OSX 15.7.2
              Safari 26.1
              MSR latest-25325-2c235fbb
              Similar on OSX 26.1
              Safari 26.1
              Also fine on IOS 26.1
                OSX 15.7.2
                Safari 26.1
                Similar on OSX 26.1
                Safari 26.1
                yes, fine on my Mac and on iOS 26 as well.
                  OK. First suggestion here, go to the Tools tab, and in very small print in the footer of the page area, you will see a link that says Clear Local Storage. Hit that link, answer the confirmation question, and then hard-refresh the browser.
                  • S SweetGenius
                    @SweetGenius Just catching up here - I've had this with Safari on iOS for ages. Just stalls loading, takes a few refreshes, etc.
                    In Brave Mobile browser it loads finger snap fast. I don't remember why I was doing it with Safari, to be honest.... perhaps that's the only browser that would let me save a link on my browser homepage? Dunno.
                    I use Brave on the Mac, also. And Windows... and... Linux...
                    *Hubitat C-7 2.4.3.177
                    Core 2026.1.1
                    MSR: latest-26011-c621bbc7
                      @toggledbits I tried the Clear Local Storage and a hard-refresh and still have the same result. I am attaching a new screenshot of the web inspector where I saw some errors just in case it means something to you. Screenshot 2025-12-10 at 5.47.00 PM.png
                      I don't know why it works for some on Safari but seems work for all with other browsers. Is there anything else you can think of for me to check?
                      Thank you for responding with your experiences @CatmanV2 @therealdb and @gwp1 !
                      • Self test
                      • Possible feature request 2?
                        82.5k
