  4. [Solved] function isRuleEnabled() issue
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 2 Posters 994 Views 2 Watching
    Edit: Rule id needs to be quoted, e.g. isRuleEnabled( 'rule_id' )
    Bare metal 25325.
    I'm getting null in both global and local expressions for the function isRuleEnabled(). It doesn't matter if the rule is enabled or disabled. Let me know if you can't replicate and need logs at higher level or I'm doing something wrong.
    [latest-25325]2026-01-12T14:15:04.773Z <Rule:INFO> Laddning - Lastbalansering (rule-lj5kfvi6 in Funktioner) starting rule state evaluation; because timer-trigger Timer#rule-lj5kfvi6
    [latest-25325]2026-01-12T14:15:07.348Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) configuration changed; reloading
    [latest-25325]2026-01-12T14:15:07.349Z <Engine:INFO> Engine#1 rule Rule#rule-mkb8uytt changed; reloading and restarting it
    [latest-25325]2026-01-12T14:15:07.349Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) stopping
    [latest-25325]2026-01-12T14:15:07.350Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) stopped
    [latest-25325]2026-01-12T14:15:07.350Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) starting
    [latest-25325]2026-01-12T14:15:07.350Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) can't start -- rule is disabled
    [latest-25325]2026-01-12T14:15:09.589Z <Rule:INFO> Ljusstyrka - Baksida (rule-kz3ygi32 in Ljusstyrka) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>baksida
    [latest-25325]2026-01-12T14:15:09.772Z <Rule:INFO> Laddning - Lastbalansering (rule-lj5kfvi6 in Funktioner) starting rule state evaluation; because expression-state-changed GlobalExpression#chargeAmps
    [latest-25325]2026-01-12T14:15:09.773Z <Rule:INFO> Laddning - Återstarta om stoppad av lastbalansering (rule-m3yhrbvs in Funktioner) starting rule state evaluation; because expression-state-changed GlobalExpression#chargeAmps
    [latest-25325]2026-01-12T14:15:09.787Z <Rule:INFO> Laddning - Lastbalansering (rule-lj5kfvi6 in Funktioner) starting rule state evaluation; because timer-trigger Timer#rule-lj5kfvi6
    [latest-25325]2026-01-12T14:15:10.024Z <Rule:INFO> Laddning - Ladda bil (rule-mgb4e7bl in Funktioner) starting rule state evaluation; because timer-trigger Timer#rule-mgb4e7bl
    [latest-25325]2026-01-12T14:15:10.025Z <Rule:INFO> Rule#rule-mgb4e7bl local values has_local_deps false has_object_deps true need_eval false
    [latest-25325]2026-01-12T14:15:10.025Z <Rule:INFO> Rule#rule-mgb4e7bl local title has_local_deps false has_object_deps true need_eval false
    [latest-25325]2026-01-12T14:15:10.025Z <Rule:INFO> Rule#rule-mgb4e7bl local text has_local_deps false has_object_deps true need_eval false
    [latest-25325]2026-01-12T14:15:10.025Z <Rule:INFO> Rule#rule-mgb4e7bl local chargingTime has_local_deps true has_object_deps false need_eval true
    [latest-25325]2026-01-12T14:15:10.025Z <Rule:INFO> Rule#rule-mgb4e7bl evaluating eligible local chargingTime
    [latest-25325]2026-01-12T14:15:10.025Z <Rule:INFO> Rule#rule-mgb4e7bl local currentValues has_local_deps true has_object_deps false need_eval true
    [latest-25325]2026-01-12T14:15:10.025Z <Rule:INFO> Rule#rule-mgb4e7bl evaluating eligible local currentValues
    [latest-25325]2026-01-12T14:15:10.746Z <Rule:INFO> Ljusstyrka - Badrummet (rule-m23jno54 in Ljusstyrka) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>badrummet
    [latest-25325]2026-01-12T14:15:10.983Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) configuration changed; reloading
    [latest-25325]2026-01-12T14:15:10.984Z <Engine:INFO> Engine#1 rule Rule#rule-mkb8uytt changed; reloading and restarting it
    [latest-25325]2026-01-12T14:15:10.984Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) stopping
    [latest-25325]2026-01-12T14:15:10.985Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) stopped
    [latest-25325]2026-01-12T14:15:10.985Z <Rule:NOTICE> rule-mkb8uytt (rule-mkb8uytt in Funktioner) starting
    [latest-25325]2026-01-12T14:15:10.986Z <Rule:INFO> rule-mkb8uytt (rule-mkb8uytt in Funktioner) starting rule state evaluation; because startup
    [latest-25325]2026-01-12T14:15:10.986Z <Rule:INFO> Rule#rule-mkb8uytt initializing expressions: stage one - compile and dependency scan
    [latest-25325]2026-01-12T14:15:10.987Z <Rule:INFO> Rule#rule-mkb8uytt initializing expressions: stage two - topological sort
    [latest-25325]2026-01-12T14:15:10.987Z <Rule:INFO> Rule#rule-mkb8uytt initializing expressions: stage three - startup evaluation
    [latest-25325]2026-01-12T14:15:10.987Z <Rule:INFO> Rule#rule-mkb8uytt evaluating eligible local test
    [latest-25325]2026-01-12T14:15:10.989Z <Rule:INFO> rule-mkb8uytt (rule-mkb8uytt in Funktioner) started
    [latest-25325]2026-01-12T14:15:14.787Z <Rule:INFO> Laddning - Lastbalansering (rule-lj5kfvi6 in Funktioner) starting rule state evaluation; because timer-trigger Timer#rule-lj5kfvi6
    [latest-25325]2026-01-12T14:15:15.026Z <Rule:INFO> Varmvattenberedare (rule-mgffrozr in Funktioner) starting rule state evaluation; because timer-trigger Timer#rule-mgffrozr
    • toggledbitsT Online
      toggledbitsT Online
      Please post a readable screen shot. I don't know what or how this one got posted, but it's tiny and low resolution and I can't see clearly what's in it.
        Wow, those were in fact really bad! Sorry for that.
        Rule id rule-mj4xiyr8 is in this case Enabled
        Rule expression:
        rule_expr.PNG Global expression:
          Never mind. I found the issue, this works as expected isRuleEnabled('rule-mj4xiyr8') where the rule id needs to be quoted with ' or ".
          Not obvious in the docs, my bad for not testing that first.
            165.6k
