  4. Condition for trend
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
12 Posts 2 Posters 1.9k Views 2 Watching
    Is there a way to set a condition for a trending number? I just installed a Zooz ZSE44 Temp/Humidity sensor in one of my bathrooms. I wanted to set a condition based upon how quickly the Humidity sensor reports the humidity level trending down (say after a shower).
    If you look at the graph below from the device, you can see the humidity spiking at 5 am, then dropping, then spiking again, then dropping. I'm trying to set up a condition when the level trends up or down quickly.
      I think I may have figured out a way...
      If I use a Latch condition when the Humidity goes above 60, and then another condition when it goes below 45 (dependent on the first condition being true first), that should give me the result I'm looking for; that being the shower isn't being used anymore, and the shower light can be turned off. Am I correct in my understanding of how Latch works, in that that condition will stay true until the Set Reaction triggers?
        VirtualEntityController can sample another entity's data and do time-series aggregation (moving average, rate of change, etc.).
        Refer to the documentation for VirtualEntityController
          @toggledbits said in Condition for trend:
          Thanks for that. I wasn't familiar with that, and it sounds like what I was initially looking for.
            So, for some reason, my Latch method isn't working. I see the humidity go above 70, and I see the first condition go true. When I'm done showering, and fan evacuates the excess humidity, it drops back down and goes below 65, and that condition becomes true.
            The second condition has the restriction that it must occur after the first condition is met.
            I guess the second condition resets the Latched condition, so both conditions aren't true at the same time?
            Is there another way to do a first condition, then the second condition that I'm missing?
            • T tamorgen
              @tamorgen said in Condition for trend:
              Correct. Both conditions cannot be true at the same time.
              Your relatively simple logic here doesn't need a latch. Just use two rules, one to turn the fan on at humidity >= 70, and the other to turn it off when humidity <= 65.
              If you insist on a latch in one rule, then you need to pair the latching condition with a condition that stays true until it's time to reset it. Really, all you need to do is reverse the operand in your second condition: it should be humidity >= 65 (and this second condition not latching). When humidity rises, the second condition will go true before the first (latching) condition, but won't Set the rule because both must be true. When the humidity gets to 70, the first will go true, so both will then be true, and the Set Reaction then runs to turn the fan on. As humidity comes down below 70, the first condition will become logically false, but remain in true state because it is latched while the second condition also remains true (i.e. humidity hasn't yet reached the low cutoff). When the humidity drops below 65, the second condition will go false, causing the reset of the latch on the first condition. The Reset Reaction then runs (it turns the fan off).
              That said, seasonally and with local changes in weather, your indoor humidity varies, and using fixed values like this may not work out very well over the course of a year. I've tried. That's why I added aggregates/trending to VirtualEntityController. You can have VEC create a rate aggregate over 5 minutes. You'd need to "tune" the condition's rate value test, but as a starting point for the conditions, let's say if the rate of change exceeds 2.0 (which is % humidity per minute, the unit VEC will report for rate, equating to about 10% (positive) change in the five minute sampling period), your rule turns the fan on. It may be a little trickier figuring out when to turn the fan off. As a practical matter, I've found that having the fan run on a timed basis for 30 minutes once triggered is a simplifying assumption that works out perfectly in my bathroom, but you could also look at rate (e.g. rate of change is <0.0167 sustained for 15 minutes, for example). I would always add a time component to the run of exhaust fans in any case, because these simple fans aren't built for long runtimes (bathroom exhaust fans have started fires from running too long).
              controllers:
              - id: virtual
                enabled: true
                implementation: VirtualEntityController
                name: Virtual Entity Controller
                  entities:
                    - id: "master_bath_rh_rate"
                      name: "Master Bath Humidity Change Rate"
                      type: ValueSensor
                      capabilities:
                        value_sensor:
                            value:
                              model: time series
                              aggregate: rate
                              entity: "mqtt>shelly_handt3"
                              attribute: "humidity_sensor.value"
                              interval: 150
                              retention: 300
                              precision: 3
                      primary_attribute: "value_sensor.value"
                Okay, so maybe I'm missing something or not explaining my train of though here....
                First, I'm not trying to control an exhaust fan, I'm trying to control the shower light. The exhaust fan has it's own built in sensor and . I'm using the humidity to determine that someone is taking a shower, so the light should remain on. When someone stops taking a shower, the humidity will drop (due to the automatic exhaust fan), and then the light can be turned off. I can't easily put a motion sensor in the shower, so the humidity sensor is the logical sensor. I've observed the values before, during, and after taking a shower, and generally, the humidity in that room is 30's or 40's, and when a shower is in play, it jumps up to the 70's or 80's.
                I tried doing it with just one rule, but there really isn't a operand to change below a number. There is Changes from x to y, and then < or <=. If I just have a simple rule to say below 65%, then the light will go off before the humidity level rises. This is why I was trying to latch aspect, because generally when I step into the bathroom, I manually turn on the shower light, turn on the shower, finish, and inevitably the shower light get's left on, whether it's me or my wife.
                I initially thought about the trend/time aspect, but I thought that for this purpose, that is actually over complicating things. All I really need to know is a) did the humidity level rise above point A, and b) did it drop below point B, in that sequence.
                So, from my understanding, you are saying I just need to change the value fo the first condition to >= 65, and the second condition can stay at <= 65?
                • T tamorgen
                  Important detail.
                  No. Both conditions >=, and you should have a deadband between them. And since you turn the light on manually, the Set Reaction in that rule can do nothing, and the Reset Reaction turns the light off.
                  Your image is now mixing concepts and adding condition options not discussed, not needed. Based on your graph and descriptions, I would go with exactly this (do not add any other features) and see how it goes:
                  1. Condition #1: humidity >= 65, latching output
                  2. Condition #2: humidity >= 50, default (follow) output
                  3. Set Reaction: empty
                  4. Reset Reaction: turn light off.
                  Note that both conditions are >=. This is the way.
                    Okay, thank you. That makes sense…. Other than deadband. What do you mean by that?
                      Deadband... a range of the measurement where nothing happens; but there is usually action at the extremes of the deadband (the low and high values).
                      With the configuration I gave you, it's the range of humidity between 50% and 65%... if the humidity goes only from 40% to 55%, that 55% is in the "deadband" and the rule won't turn the light off if the humidity then falls below 50% (the low end of the deadband) because the humidity never exceeded the high end (65%) of the deadband. But the way the rule is set up, if the humidity does reach 65%, then the rule becomes "sensitive" and watches for the humidity to drop below 50%, and then it will turn the light off.
                      Deadband is also commonly used to refer to thermostats, for example, where it's commonly the small differential enforced between a heating setpoint and a cooling setpoint so that the thermostat won't try to do both at the same time, or bang back and forth between the two rapidly when the temperature is in a small range between those setpoints.
                        Okay, I understand. For a minute I thought it there was a setting I needed to enable. I've set it up and I'll know if it works in the morning. Thanks for all the help.
                        • T tamorgen
                          Update. Worked perfectly. Thanks for setting me striaght!
                            165.2k
