  4. [Solved] DynamicGroupController updating members issue
5 Posts 2 Posters 469 Views 2 Watching
    Edit: Solved in latest-26221.
    Bare-metal latest-26193
    I have this group:
    "OKforLarm":
      name: OK för Larm
        - include_controller: vera
      I'll add logs when I reduced the length to an acceptable size to post.
        Log level 5:
        [latest-26193]2026-08-08T14:48:43.605Z <Rule:INFO> MONITOR - Rörelse hallen (rule-krnbos9q in Larm) starting rule state evaluation; because predicate-state-changed Predicate#rule-krnbos9q/trig
        [latest-26193]2026-08-08T14:48:45.300Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from SecuritySensor#vera>device_10095 by SecuritySensor#vera>device_10095
        [latest-26193]2026-08-08T14:48:45.500Z <DynamicGroupController:INFO> DynamicGroupController#groups processing pending updates for Array(1) ["OKforLarm"]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:519> DynamicGroupController#groups _update acquiring mutex for updates to Array(1) ["OKforLarm"]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:522> DynamicGroupController#groups mutex acquired; going to work
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating OKforLarm
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:399> DynamicGroupController#groups selecting entities for Group#groups>OKforLarm with Array(2) [{ "include_controller": "vera" }, { "include_capability": "door_sensor" }]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:558> DynamicGroupController#groups _select group OKforLarm criteria Array(2) [{ "include_controller": "vera" }, { "include_capability": "door_sensor" }]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups handling group OKforLarm selector include_controller, val=Array(1) ["vera"], first=true, set has 0
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups set=Map(0) { }
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:593> DynamicGroupController#groups group OKforLarm include_controller vera
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:754> DynamicGroupController#groups group OKforLarm after criterion include_controller, set contains 91
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups handling group OKforLarm selector include_capability, val=Array(1) ["door_sensor"], first=false, set has 91
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups set=Map(91) {"vera>controller_all": Group(Group#vera>controller_all), "vera>system": System(System#vera>system), "vera>device_1": Entity(Entity#vera>device_1), "vera>device_10004": Entity(Entity#vera>device_10004), "vera>device_10006": Entity(Entity#vera>device_10006), "vera>device_10016": Entity(Lock#vera>device_10016), "vera>device_10027": Entity(Entity#vera>device_10027), "vera>device_10028": Entity(Entity#vera>device_10028), "vera>device_10032": Entity(Lock#vera>device_10032), "vera>device_10048": Entity(Switch#vera>device_10048), "vera>device_10050": Entity(Entity#vera>device_10050), "vera>device_10064": Entity(Switch#vera>device_10064), "vera>device_10065": Entity(Switch#vera>device_10065), "vera>device_10068": Entity(Entity#vera>device_10068), "vera>device_10069": Entity(Entity#vera>device_10069), "vera>device_10070": Entity(Entity#vera>device_10070), "vera>device_10071": Entity(Entity#vera>device_10071), "vera>device_10076": Entity(Entity#vera>device_10076), "vera>device_10086": Entity(ValueSensor#vera>device_10086), "vera>device_10094": Entity(Entity#vera>device_10094), "vera>device_10095": Entity(SecuritySensor#vera>device_10095), "vera>device_10096": Entity(Entity#vera>device_10096), "vera>device_10097": Entity(SecuritySensor#vera>device_10097), "vera>device_10098": Entity(Entity#vera>device_10098), "vera>device_10099": Entity(SecuritySensor#vera>device_10099), "vera>device_10104": Entity(Entity#vera>device_10104), "vera>device_10105": Entity(SecuritySensor#vera>device_10105), "vera>device_10106": Entity(Entity#vera>device_10106), "vera>device_10107": Entity(SecuritySensor#vera>device_10107), "vera>device_10109": Entity(Entity#vera>device_10109), "vera>device_10110": Entity(SecuritySensor#vera>device_10110), "vera>device_10111": Entity(Switch#vera>device_10111), "vera>device_10112": Entity(Entity#vera>device_10112), "vera>device_10113": Entity(Switch#vera>device_10113), "vera>device_10115": Entity(Entity#vera>device_10115), "vera>device_10116": Entity(ValueSensor#vera>device_10116), "vera>device_10127": Entity(Entity#vera>device_10127), "vera>device_10129": Entity(ValueSensor#vera>device_10129), "vera>device_10130": Entity(Switch#vera>device_10130), "vera>device_10131": Entity(SecuritySensor#vera>device_10131), "vera>device_10132": Entity(SecuritySensor#vera>device_10132), "vera>device_10133": Entity(SecuritySensor#vera>device_10133), "vera>device_10149": Entity(Switch#vera>device_10149), "vera>device_10162": Entity(Entity#vera>device_10162), "vera>device_10163": Entity(ValueSensor#vera>device_10163), "vera>device_10167": Entity(Light#vera>device_10167), "vera>device_10168": Entity(Light#vera>device_10168), "vera>device_10187": Entity(Entity#vera>device_10187), "vera>device_10188": Entity(Entity#vera>device_10188), "vera>device_10189": Entity(ValueSensor#vera>device_10189), "vera>device_10190": Entity(ValueSensor#vera>device_10190), "vera>device_10191": Entity(Entity#vera>device_10191), "vera>device_10192": Entity(Entity#vera>device_10192), "vera>device_10200": Entity(Light#vera>device_10200), "vera>device_10217": Entity(Entity#vera>device_10217), "vera>device_10229": Entity(Entity#vera>device_10229), "vera>device_10230": Entity(Entity#vera>device_10230), "vera>device_10231": Entity(SecuritySensor#vera>device_10231), "vera>device_10232": Entity(ValueSensor#vera>device_10232), "vera>device_10234": Entity(Entity#vera>device_10234), "vera>device_10235": Entity(Switch#vera>device_10235), "vera>device_10236": Entity(Switch#vera>device_10236), "vera>device_10258": Entity(Entity#vera>device_10258), "vera>device_2": Entity(Entity#vera>device_2), "vera>device_3": Entity(Entity#vera>device_3), "vera>device_30001": Entity(Entity#vera>device_30001), "vera>device_30005": Entity(Entity#vera>device_30005), "vera>device_30006": Entity(Entity#vera>device_30006), "vera>device_30014": Entity(Entity#vera>device_30014), "vera>device_30015": Entity(Entity#vera>device_30015), "vera>device_35": Entity(Entity#vera>device_35), "vera>device_4": Entity(Entity#vera>device_4), "vera>device_40001": Entity(Entity#vera>device_40001), "vera>device_40002": Entity(Light#vera>device_40002), "vera>device_5": Entity(Entity#vera>device_5), "vera>device_56": Entity(Entity#vera>device_56), "vera>device_59": Entity(Entity#vera>device_59), "vera>device_63": Entity(ValueSensor#vera>device_63), "vera>device_64": Entity(ValueSensor#vera>device_64), "vera>device_67": Entity(Entity#vera>device_67), "vera>device_68": Entity(ValueSensor#vera>device_68), "vera>device_69": Entity(ValueSensor#vera>device_69), "vera>device_76": Entity(Entity#vera>device_76), "vera>device_77": Entity(Entity#vera>device_77), "vera>housemode": Entity(Entity#vera>housemode), "vera>scene_10": Entity(Script#vera>scene_10), "vera>scene_11": Entity(Script#vera>scene_11), "vera>scene_9": Entity(Script#vera>scene_9), "vera>user_13775022": Entity(Entity#vera>user_13775022), "vera>user_2116531": Entity(Entity#vera>user_2116531), "vera>user_2975462": Entity(Entity#vera>user_2975462) }
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:651> DynamicGroupController#groups group OKforLarm include_capability door_sensor
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:661> DynamicGroupController#groups removing vera>controller_all from set, no matching capability
        ... *removed due to post length, lists all devices that don't match the filter*
        [latest-26193]2026-08-08T14:48:45.519Z <DynamicGroupController:5:DynamicGroupController.js:754> DynamicGroupController#groups group OKforLarm after criterion include_capability, set contains 6
        [latest-26193]2026-08-08T14:48:45.520Z <DynamicGroupController:5:DynamicGroupController.js:481> DynamicGroupController#groups members=Map(1) {"vera>device_10097": Entity(SecuritySensor#vera>device_10097) } newMembers=Set(1) ["vera>device_10097"] current=Set(0) []
        [latest-26193]2026-08-08T14:48:45.520Z <DynamicGroupController:5:DynamicGroupController.js:493> DynamicGroupController#groups group Group#groups>OKforLarm has 0 adds 1 removes 0
        [latest-26193]2026-08-08T14:48:45.520Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Group#groups>OKforLarm by Group#groups>OKforLarm
        [latest-26193]2026-08-08T14:48:45.524Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group OKforLarm done 23ms
        [latest-26193]2026-08-08T14:48:45.524Z <DynamicGroupController:5:DynamicGroupController.js:549> DynamicGroupController#groups _update releasing mutex
        [latest-26193]2026-08-08T14:48:45.956Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Entity#vera>device_10094 by Entity#vera>device_10094
        [latest-26193]2026-08-08T14:48:45.958Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from SecuritySensor#vera>device_10095 by SecuritySensor#vera>device_10095
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:INFO> DynamicGroupController#groups processing pending updates for Array(3) ["UnreachableVeraDevices", "LowBatteryDevices", "OKforLarm"]
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:5:DynamicGroupController.js:519> DynamicGroupController#groups _update acquiring mutex for updates to Array(3) ["UnreachableVeraDevices", "LowBatteryDevices", "OKforLarm"]
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:5:DynamicGroupController.js:522> DynamicGroupController#groups mutex acquired; going to work
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating UnreachableVeraDevices
        [latest-26193]2026-08-08T14:48:46.158Z <DynamicGroupController:5:DynamicGroupController.js:475> DynamicGroupController#groups group Group#groups>UnreachableVeraDevices removes all members
        [latest-26193]2026-08-08T14:48:46.159Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group UnreachableVeraDevices done 1ms
        [latest-26193]2026-08-08T14:48:46.159Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating LowBatteryDevices
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:475> DynamicGroupController#groups group Group#groups>LowBatteryDevices removes all members
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group LowBatteryDevices done 1ms
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating OKforLarm
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:481> DynamicGroupController#groups members=Map(2) {"vera>device_10095": Entity(SecuritySensor#vera>device_10095), "vera>device_10097": Entity(SecuritySensor#vera>device_10097) } newMembers=Set(2) ["vera>device_10095", "vera>device_10097"] current=Set(1) ["vera>device_10097"]
        [latest-26193]2026-08-08T14:48:46.161Z <DynamicGroupController:5:DynamicGroupController.js:493> DynamicGroupController#groups group Group#groups>OKforLarm has 1 adds 1 removes 0
        [latest-26193]2026-08-08T14:48:46.161Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Group#groups>OKforLarm by Group#groups>OKforLarm
        [latest-26193]2026-08-08T14:48:46.164Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group OKforLarm done 4ms
        [latest-26193]2026-08-08T14:48:46.164Z <DynamicGroupController:5:DynamicGroupController.js:549> DynamicGroupController#groups _update releasing mutex
        [latest-26193]2026-08-08T14:48:47.828Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from SecuritySensor#vera>device_10095 by SecuritySensor#vera>device_10095
        [latest-26193]2026-08-08T14:48:47.963Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Entity#vera>device_10094 by Entity#vera>device_10094
        [latest-26193]2026-08-08T14:48:48.028Z <DynamicGroupController:INFO> DynamicGroupController#groups processing pending updates for Array(3) ["OKforLarm", "UnreachableVeraDevices", "LowBatteryDevices"]
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:519> DynamicGroupController#groups _update acquiring mutex for updates to Array(3) ["OKforLarm", "UnreachableVeraDevices", "LowBatteryDevices"]
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:522> DynamicGroupController#groups mutex acquired; going to work
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating OKforLarm
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:481> DynamicGroupController#groups members=Map(1) {"vera>device_10097": Entity(SecuritySensor#vera>device_10097) } newMembers=Set(1) ["vera>device_10097"] current=Set(2) ["vera>device_10097", "vera>device_10095"]
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:493> DynamicGroupController#groups group Group#groups>OKforLarm has 2 adds 0 removes 1
        [latest-26193]2026-08-08T14:48:48.030Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Group#groups>OKforLarm by Group#groups>OKforLarm
        [latest-26193]2026-08-08T14:48:48.033Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group OKforLarm done 4ms
          Yes, I found this as well. I have a fix that I've been running/testing, not yet into a build. I will get it done before the end of the weekend.
            Thank you for the quick fix!
              314
              150.9k
