  4. [Solved] DynamicGroupController updating members issue
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 2 Posters 562 Views 2 Watching
    Edit: Solved in latest-26221.
    Bare-metal latest-26193
    I have this group:
    "OKforLarm":
      name: OK för Larm
        - include_controller: vera
      I'll add logs when I reduced the length to an acceptable size to post.
        Log level 5:
        [latest-26193]2026-08-08T14:48:43.605Z <Rule:INFO> MONITOR - Rörelse hallen (rule-krnbos9q in Larm) starting rule state evaluation; because predicate-state-changed Predicate#rule-krnbos9q/trig
        [latest-26193]2026-08-08T14:48:45.300Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from SecuritySensor#vera>device_10095 by SecuritySensor#vera>device_10095
        [latest-26193]2026-08-08T14:48:45.500Z <DynamicGroupController:INFO> DynamicGroupController#groups processing pending updates for Array(1) ["OKforLarm"]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:519> DynamicGroupController#groups _update acquiring mutex for updates to Array(1) ["OKforLarm"]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:522> DynamicGroupController#groups mutex acquired; going to work
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating OKforLarm
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:399> DynamicGroupController#groups selecting entities for Group#groups>OKforLarm with Array(2) [{ "include_controller": "vera" }, { "include_capability": "door_sensor" }]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:558> DynamicGroupController#groups _select group OKforLarm criteria Array(2) [{ "include_controller": "vera" }, { "include_capability": "door_sensor" }]
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups handling group OKforLarm selector include_controller, val=Array(1) ["vera"], first=true, set has 0
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups set=Map(0) { }
        [latest-26193]2026-08-08T14:48:45.501Z <DynamicGroupController:5:DynamicGroupController.js:593> DynamicGroupController#groups group OKforLarm include_controller vera
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:754> DynamicGroupController#groups group OKforLarm after criterion include_controller, set contains 91
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups handling group OKforLarm selector include_capability, val=Array(1) ["door_sensor"], first=false, set has 91
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:589> DynamicGroupController#groups set=Map(91) {"vera>controller_all": Group(Group#vera>controller_all), "vera>system": System(System#vera>system), "vera>device_1": Entity(Entity#vera>device_1), "vera>device_10004": Entity(Entity#vera>device_10004), "vera>device_10006": Entity(Entity#vera>device_10006), "vera>device_10016": Entity(Lock#vera>device_10016), "vera>device_10027": Entity(Entity#vera>device_10027), "vera>device_10028": Entity(Entity#vera>device_10028), "vera>device_10032": Entity(Lock#vera>device_10032), "vera>device_10048": Entity(Switch#vera>device_10048), "vera>device_10050": Entity(Entity#vera>device_10050), "vera>device_10064": Entity(Switch#vera>device_10064), "vera>device_10065": Entity(Switch#vera>device_10065), "vera>device_10068": Entity(Entity#vera>device_10068), "vera>device_10069": Entity(Entity#vera>device_10069), "vera>device_10070": Entity(Entity#vera>device_10070), "vera>device_10071": Entity(Entity#vera>device_10071), "vera>device_10076": Entity(Entity#vera>device_10076), "vera>device_10086": Entity(ValueSensor#vera>device_10086), "vera>device_10094": Entity(Entity#vera>device_10094), "vera>device_10095": Entity(SecuritySensor#vera>device_10095), "vera>device_10096": Entity(Entity#vera>device_10096), "vera>device_10097": Entity(SecuritySensor#vera>device_10097), "vera>device_10098": Entity(Entity#vera>device_10098), "vera>device_10099": Entity(SecuritySensor#vera>device_10099), "vera>device_10104": Entity(Entity#vera>device_10104), "vera>device_10105": Entity(SecuritySensor#vera>device_10105), "vera>device_10106": Entity(Entity#vera>device_10106), "vera>device_10107": Entity(SecuritySensor#vera>device_10107), "vera>device_10109": Entity(Entity#vera>device_10109), "vera>device_10110": Entity(SecuritySensor#vera>device_10110), "vera>device_10111": Entity(Switch#vera>device_10111), "vera>device_10112": Entity(Entity#vera>device_10112), "vera>device_10113": Entity(Switch#vera>device_10113), "vera>device_10115": Entity(Entity#vera>device_10115), "vera>device_10116": Entity(ValueSensor#vera>device_10116), "vera>device_10127": Entity(Entity#vera>device_10127), "vera>device_10129": Entity(ValueSensor#vera>device_10129), "vera>device_10130": Entity(Switch#vera>device_10130), "vera>device_10131": Entity(SecuritySensor#vera>device_10131), "vera>device_10132": Entity(SecuritySensor#vera>device_10132), "vera>device_10133": Entity(SecuritySensor#vera>device_10133), "vera>device_10149": Entity(Switch#vera>device_10149), "vera>device_10162": Entity(Entity#vera>device_10162), "vera>device_10163": Entity(ValueSensor#vera>device_10163), "vera>device_10167": Entity(Light#vera>device_10167), "vera>device_10168": Entity(Light#vera>device_10168), "vera>device_10187": Entity(Entity#vera>device_10187), "vera>device_10188": Entity(Entity#vera>device_10188), "vera>device_10189": Entity(ValueSensor#vera>device_10189), "vera>device_10190": Entity(ValueSensor#vera>device_10190), "vera>device_10191": Entity(Entity#vera>device_10191), "vera>device_10192": Entity(Entity#vera>device_10192), "vera>device_10200": Entity(Light#vera>device_10200), "vera>device_10217": Entity(Entity#vera>device_10217), "vera>device_10229": Entity(Entity#vera>device_10229), "vera>device_10230": Entity(Entity#vera>device_10230), "vera>device_10231": Entity(SecuritySensor#vera>device_10231), "vera>device_10232": Entity(ValueSensor#vera>device_10232), "vera>device_10234": Entity(Entity#vera>device_10234), "vera>device_10235": Entity(Switch#vera>device_10235), "vera>device_10236": Entity(Switch#vera>device_10236), "vera>device_10258": Entity(Entity#vera>device_10258), "vera>device_2": Entity(Entity#vera>device_2), "vera>device_3": Entity(Entity#vera>device_3), "vera>device_30001": Entity(Entity#vera>device_30001), "vera>device_30005": Entity(Entity#vera>device_30005), "vera>device_30006": Entity(Entity#vera>device_30006), "vera>device_30014": Entity(Entity#vera>device_30014), "vera>device_30015": Entity(Entity#vera>device_30015), "vera>device_35": Entity(Entity#vera>device_35), "vera>device_4": Entity(Entity#vera>device_4), "vera>device_40001": Entity(Entity#vera>device_40001), "vera>device_40002": Entity(Light#vera>device_40002), "vera>device_5": Entity(Entity#vera>device_5), "vera>device_56": Entity(Entity#vera>device_56), "vera>device_59": Entity(Entity#vera>device_59), "vera>device_63": Entity(ValueSensor#vera>device_63), "vera>device_64": Entity(ValueSensor#vera>device_64), "vera>device_67": Entity(Entity#vera>device_67), "vera>device_68": Entity(ValueSensor#vera>device_68), "vera>device_69": Entity(ValueSensor#vera>device_69), "vera>device_76": Entity(Entity#vera>device_76), "vera>device_77": Entity(Entity#vera>device_77), "vera>housemode": Entity(Entity#vera>housemode), "vera>scene_10": Entity(Script#vera>scene_10), "vera>scene_11": Entity(Script#vera>scene_11), "vera>scene_9": Entity(Script#vera>scene_9), "vera>user_13775022": Entity(Entity#vera>user_13775022), "vera>user_2116531": Entity(Entity#vera>user_2116531), "vera>user_2975462": Entity(Entity#vera>user_2975462) }
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:651> DynamicGroupController#groups group OKforLarm include_capability door_sensor
        [latest-26193]2026-08-08T14:48:45.502Z <DynamicGroupController:5:DynamicGroupController.js:661> DynamicGroupController#groups removing vera>controller_all from set, no matching capability
        ... *removed due to post length, lists all devices that don't match the filter*
        [latest-26193]2026-08-08T14:48:45.519Z <DynamicGroupController:5:DynamicGroupController.js:754> DynamicGroupController#groups group OKforLarm after criterion include_capability, set contains 6
        [latest-26193]2026-08-08T14:48:45.520Z <DynamicGroupController:5:DynamicGroupController.js:481> DynamicGroupController#groups members=Map(1) {"vera>device_10097": Entity(SecuritySensor#vera>device_10097) } newMembers=Set(1) ["vera>device_10097"] current=Set(0) []
        [latest-26193]2026-08-08T14:48:45.520Z <DynamicGroupController:5:DynamicGroupController.js:493> DynamicGroupController#groups group Group#groups>OKforLarm has 0 adds 1 removes 0
        [latest-26193]2026-08-08T14:48:45.520Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Group#groups>OKforLarm by Group#groups>OKforLarm
        [latest-26193]2026-08-08T14:48:45.524Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group OKforLarm done 23ms
        [latest-26193]2026-08-08T14:48:45.524Z <DynamicGroupController:5:DynamicGroupController.js:549> DynamicGroupController#groups _update releasing mutex
        [latest-26193]2026-08-08T14:48:45.956Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Entity#vera>device_10094 by Entity#vera>device_10094
        [latest-26193]2026-08-08T14:48:45.958Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from SecuritySensor#vera>device_10095 by SecuritySensor#vera>device_10095
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:INFO> DynamicGroupController#groups processing pending updates for Array(3) ["UnreachableVeraDevices", "LowBatteryDevices", "OKforLarm"]
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:5:DynamicGroupController.js:519> DynamicGroupController#groups _update acquiring mutex for updates to Array(3) ["UnreachableVeraDevices", "LowBatteryDevices", "OKforLarm"]
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:5:DynamicGroupController.js:522> DynamicGroupController#groups mutex acquired; going to work
        [latest-26193]2026-08-08T14:48:46.157Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating UnreachableVeraDevices
        [latest-26193]2026-08-08T14:48:46.158Z <DynamicGroupController:5:DynamicGroupController.js:475> DynamicGroupController#groups group Group#groups>UnreachableVeraDevices removes all members
        [latest-26193]2026-08-08T14:48:46.159Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group UnreachableVeraDevices done 1ms
        [latest-26193]2026-08-08T14:48:46.159Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating LowBatteryDevices
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:475> DynamicGroupController#groups group Group#groups>LowBatteryDevices removes all members
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group LowBatteryDevices done 1ms
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating OKforLarm
        [latest-26193]2026-08-08T14:48:46.160Z <DynamicGroupController:5:DynamicGroupController.js:481> DynamicGroupController#groups members=Map(2) {"vera>device_10095": Entity(SecuritySensor#vera>device_10095), "vera>device_10097": Entity(SecuritySensor#vera>device_10097) } newMembers=Set(2) ["vera>device_10095", "vera>device_10097"] current=Set(1) ["vera>device_10097"]
        [latest-26193]2026-08-08T14:48:46.161Z <DynamicGroupController:5:DynamicGroupController.js:493> DynamicGroupController#groups group Group#groups>OKforLarm has 1 adds 1 removes 0
        [latest-26193]2026-08-08T14:48:46.161Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Group#groups>OKforLarm by Group#groups>OKforLarm
        [latest-26193]2026-08-08T14:48:46.164Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group OKforLarm done 4ms
        [latest-26193]2026-08-08T14:48:46.164Z <DynamicGroupController:5:DynamicGroupController.js:549> DynamicGroupController#groups _update releasing mutex
        [latest-26193]2026-08-08T14:48:47.828Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from SecuritySensor#vera>device_10095 by SecuritySensor#vera>device_10095
        [latest-26193]2026-08-08T14:48:47.963Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Entity#vera>device_10094 by Entity#vera>device_10094
        [latest-26193]2026-08-08T14:48:48.028Z <DynamicGroupController:INFO> DynamicGroupController#groups processing pending updates for Array(3) ["OKforLarm", "UnreachableVeraDevices", "LowBatteryDevices"]
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:519> DynamicGroupController#groups _update acquiring mutex for updates to Array(3) ["OKforLarm", "UnreachableVeraDevices", "LowBatteryDevices"]
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:522> DynamicGroupController#groups mutex acquired; going to work
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:371> DynamicGroupController#groups updating OKforLarm
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:481> DynamicGroupController#groups members=Map(1) {"vera>device_10097": Entity(SecuritySensor#vera>device_10097) } newMembers=Set(1) ["vera>device_10097"] current=Set(2) ["vera>device_10097", "vera>device_10095"]
        [latest-26193]2026-08-08T14:48:48.029Z <DynamicGroupController:5:DynamicGroupController.js:493> DynamicGroupController#groups group Group#groups>OKforLarm has 2 adds 0 removes 1
        [latest-26193]2026-08-08T14:48:48.030Z <DynamicGroupController:5:DynamicGroupController.js:336> DynamicGroupController#groups entity-change notification from Group#groups>OKforLarm by Group#groups>OKforLarm
        [latest-26193]2026-08-08T14:48:48.033Z <DynamicGroupController:5:DynamicGroupController.js:536> DynamicGroupController#groups update group OKforLarm done 4ms
          Yes, I found this as well. I have a fix that I've been running/testing, not yet into a build. I will get it done before the end of the weekend.
            Thank you for the quick fix!
              163.6k
