Thanks in advance -
Thanks in advance -
A couple of things here...
- Editing the rule will cause re-evaluation, which is likely why you have repeated RESETs in the history with no SETs between.
- As hard as I try, and I keep looking, finding, and fixing, the UI can get out of sync with the running engine/service, so always hard-refresh when the UI isn't making sense.
- If a Rule has been edited, especially multiple times, and it's not performing as expected, reset the Rule. There's button for that:
Even restarting Reactor doesn't do what this button does. - Beyond that, it would also be handy to see the top part of the screen shot that has been cut off (the Triggers group heading and stuff above it).
