  4. Reactor Build 26284 stuck at Loading Reactor UI
4 Posts 2 Posters 42 Views 2 Watching
    wrote last edited by tamorgen
    Good morning all,
    I'm having an issue with the latest version of MSR. I'm unable to get past "Loading Reactor UI..."
    I run a MSR image in Portainer on Proxmox as a Docker VM. This has served me well for about the past 18 months. Previously I ran MSR as a bare metal install.
    To secure and access my local images, I run a Cloudflared LXC and run a Cloudflare tunnel. The Cloudflare tunnel for MSR points to my Proxmox server's local IP port 8554. I've used username/password since it became an option for MSR.
    I've read the notes about new Access control and reverse proxies. I'm not sure that this new feature is what is causing my issue, but this is the only thing I can think of at the moment.
    I also want to point out that if I access the site locally via IP, the site does load properly, albeit with a Not Secure warning:
    Thanks in advance for any advice.
    Reactor (Multi-hub) latest-26284-5f780cf0
    ZWaveJSController [0.1.26048]
      Okay, I determined the issue. I looked in the logs, and MSR is actually seeing the IP of the source host and denying the entry. I've added the assigned IP of from my ISP, as well as my work network to the allowed IP list. I can now access MSR from my workstation at work, as well as my iPhone with VPN to my home network turned on, and my local network as before. What I don't know about, is if my ISP reassigns my IP address, what I can do about it, as this could cause me to have to manually add that IP address every time it's changed. Historically, they haven't changed it often, but I may have to figure a way out to automatically update the config.
        This may be a feature request, which would solve the dynamic IP issue in mentioned in my previous post. Would it be possible to use domain names in the allowed list instead of just IPs (I tried, doesn't appear to work)?
        As I mentioned in the original post, I access MSR via the my Cloudflare domain name. Previous to this update, I was able to access it from anywhere. This lock down is probably a good thing, but it now creates a potential issue when I try and access MSR from my local network.
        Cloudflare automatically updates the Origin IP of my network, which is the same as the IP my ISP assigns me. If I put my domain name in as an allowed source, then anytime my ISP reassigns me an IP address, then that source IP would be allowed.
        My other option may be some sort of bash/cron script, but I'm not sure how successful it would be.
          Have you set any of the new proxy configs?
            145.8k
