  2. Hardware
  3. Shelly i3 as a cheap scene controller for Openluup
Hardware
Shelly Wall Display XL
Hardware
Hardware
DIY HomeKey locks via Reactor
Hardware
A recent thread on supporting the ZRC-90 Z-Wave scene controller got me to wonder, what does everybody use and like? I'll start... oh, and no dashboards. I want to hear from you all about dedicated scene controller devices. Dashboards and apps are great to a point, but my experience is that higher WAF is achieved with (a) a dedicated device (b) in a known location (c) with predictable functions and (d) no extra steps to operate (just walk up to it and push a button -- same effort as a light switch/dimmer). She's not wrong. It's a pain to unlock the phone, find the app, open the app, find the device, tap the device, when you can just walk across the room and push a button. Bonus points for something that can be labeled readably (low WAF for stuck-on tape/thermal labels). I have a ZRC-90 and it's great, but it was temperamental to get working on Vera, and wasn't smooth sailing when it made the move to Z-Wave JS either. A couple of include/exclude cycles were needed to get it fully working on both. Since then, I've done a battery change, and while the buttons work as reliably as ever, the device continues to report the old battery level despite having a measurably fresh battery for over a year now. But I would still recommend it. I have a Hank 4-button that is probably the best and most reliable battery-operated scene controller I have ever used. It's small and unobtrusive, so it lives on a lamp base in our living room and controls the room's mood lighting. I'm not sure they're still available. RIP. I just ran across the Minoston MR40Z on Amazon, and I may try one of those. It looks like an installed (in-wall) Decora switch, but the buttons are actually a removable remote that you can pull off the wall and take to the couch. No line power required. Kinda cool. Maybe a good Hank replacement. But, I've never heard of this manufacturer before, and the concern is always "will I be able to buy more/replacements in one/two/five years?" Among the wired controllers, the Zooz ZEN32 seems to be the most popular modern unit. I like it, but the LEDs are too small for my aging eyes to discern their color in daylight -- they are pin-head sized. Four of the five buttons are too small to label, so low WAF. When I started my Z-Wave network, I used the Leviton four-button scene/zone controllers (VRCS4 and VRCZ4), and these are still all over my house. They're glitchy first-gen Z-Wave stuff (Vizia RF+ actually, so compatible but with proprietary features that aren't usable). They're now discontinued for Z-Wave. Leviton's newer units are WiFi, so if I go that route, it's HomeKit via Home Assistant for those. During the pandemic lock-downs, I built a touch-screen scene controller using an Adafruit PyPortal. It had screens with 1 to 8 labeled, colorable soft buttons that could either perform a device function (i.e. publish to MQTT) or take you to another screen, so it was the love-child of scene controller and dashboard. Wife found it agreeable. But it was just a prototype. Memory limitation of the device was an issue because the PyPortal is really an inexpensive teaching device with a big load of Circuit Python overhead, and the graphic display needs a lot of RAM, so it was severely limited. I'm sure it could work out with the right micro and programming closer to the bare metal. Packaging and powering would also need to be addressed. And, at the end of the day, while "cute," it doesn't seem like something I would want to sell with the house if we ended up moving some day. So, I'm interested in what others are doing and using, or more specifically, what your significant others are comfortable with and willing to use.
Hardware
O
Hardware
Z
Hardware
Hardware
LEDVANCE
O
Hardware
Water Flow Meter & Shutoff
B
Hardware
Hardware
Remote light switch
Hardware
ESP32 / ESP8266
Hardware
Hardware
Hardware
PerHP
After a long wait for an updated version of the rather crude and unfinished Z-Way integration to HASS, i'm now looking (reluctantly) in to replacing Z-Way with Z-wave JS.. Mind you this is a big existing network, not a new controller stick.. I threw up a docker for z-wave JS UI, and tried to connect it to the UZB stick.. It loads the whole network from the stick, but the driver keeps restarting? Looking at the logs, I see a lot of Dropping message because the driver is not ready to handle it yet. It seems like the stick just keeps talking like z-way was still listening? This ends up in the driver crashing repeatedly.. Any ideas to how I can get them talking? In the code snippet below, you see the driver restarting with the graphic letters, seemingly while the stick is mid-sentence, or because of ACK timeout... 2022-10-02T19:19:59.664Z CNTRLR received additional controller information: Z-Wave API version: 6 (legacy) Z-Wave chip type: ZW050x node type Controller controller role: primary controller is the SIS: true controller supports timers: false nodes in the network: 1, 5, 6, 10, 11, 12, 13, 14, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 32, 33, 34, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 4 7, 48, 52, 55, 69, 70, 71, 73, 74, 75, 77, 78, 79, 81, 82, 83 2022-10-02T19:19:59.765Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated 2022-10-02T19:19:59.766Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated 2022-10-02T19:19:59.767Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated 2022-10-02T19:19:59.768Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 277 2022-10-02T19:19:59.769Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 1 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated 2022-10-02T19:19:59.771Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.39 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [+] [Version] sdkVersion: "6.9.0" 2022-10-02T19:19:59.772Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms 2022-10-02T19:19:59.792Z SERIAL » 0x01050006640f97 (7 bytes) 2022-10-02T19:19:59.792Z DRIVER » [REQ] [SetSerialApiTimeouts] payload: 0x640f 2022-10-02T19:19:59.815Z SERIAL « [ACK] (0x06) 2022-10-02T19:19:59.816Z SERIAL « 0x01050106640f96 (7 bytes) 2022-10-02T19:19:59.817Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.177Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:03.178Z DRIVER version 10.2.0 2022-10-02T19:21:03.179Z DRIVER 2022-10-02T19:21:03.179Z DRIVER starting driver... 2022-10-02T19:21:03.199Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:03.212Z DRIVER serial port opened 2022-10-02T19:21:03.213Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:03.229Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.232Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.233Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.234Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.261Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.273Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.274Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.274Z DRIVER loading configuration... 2022-10-02T19:21:03.298Z CONFIG Using external configuration dir /usr/src/app/store/.config-db 2022-10-02T19:21:03.298Z CONFIG version 10.2.0 2022-10-02T19:21:04.284Z DRIVER beginning interview... 2022-10-02T19:21:04.286Z DRIVER added request handler for AddNodeToNetwork (0x4a)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for ReplaceFailedNode (0x63)... 1 registered 2022-10-02T19:21:04.287Z CNTRLR querying controller IDs... 2022-10-02T19:21:04.484Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:04.485Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:04.487Z SERIAL « 0x0123000400511a9f039900b834787d066515a4b79c45bb3af55ea7f6203006010 (37 bytes) 80120c84d 2022-10-02T19:21:04.489Z SERIAL « [DISCARDED] invalid data 0x9ef4 (2 bytes) 2022-10-02T19:21:04.490Z DRIVER Dropping message because it contains invalid data 2022-10-02T19:21:04.490Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:05.488Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i n 100 ms. 2022-10-02T19:21:05.591Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:05.592Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:06.596Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i n 1100 ms. 2022-10-02T19:21:07.698Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:07.699Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:08.717Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D river.ts:3980:23) at ZWaveController.identify (/usr/src/app/node_modules/zwave-js/src/lib/co ntroller/Controller.ts:713:33) at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js /src/lib/driver/Driver.ts:1207:26) at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive r/Driver.ts:1014:16) 2022-10-02T19:21:08.723Z DRIVER destroying driver instance... 2022-10-02T19:21:08.728Z DRIVER driver instance destroyed 2022-10-02T19:21:08.739Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:08.740Z DRIVER version 10.2.0 2022-10-02T19:21:08.740Z DRIVER 2022-10-02T19:21:08.740Z DRIVER starting driver... 2022-10-02T19:21:08.745Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:08.751Z DRIVER serial port opened 2022-10-02T19:21:08.752Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:08.754Z DRIVER loading configuration... 2022-10-02T19:21:08.755Z SERIAL « 0x01080120c84d9ef40138 (10 bytes) 2022-10-02T19:21:08.757Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:08.758Z DRIVER « [RES] [GetControllerId]
Hardware
Hardware
Hardware
Hardware
Hardware
44 Posts 8 Posters 26.3k Views 8 Watching
    Oh, OK. Yes the browser interface is very nice and straight-forward.
    I've set up a couple of URLs, and it all looks good, but nothing appears in the log when I press the swich.
    There is, I suppose, the remote possibility that the switch is not wired correctly or otherwise faulty. The are momentary switched (and configured as such.)
    This is what I see:
    The moment you push a button, the UI reflects it:
    So, if you don't see a blue border, wiring should be double-checked.
      All three switches look to be working from that page, but the destination URL doesn’t seem to be reached. So the Shelly itself seems to be fine. More investigation required!
        Revelation!! ...
        ...I've just noticed these words in the Settings above:
        Works only when button is configured as Toggle
        ...but I have it on a momentary switch!!
        If these things are reliable, then they really are extraordinary. My initial reaction is that WiFi is not appropriate for small HA devices with no bandwidth requirement, but easy browser-based UI is really nice (if you actually read what the words say!) I haven't measured the residual power usage yet, either, but I'm hoping it's low.
          It's just 1 watt, if I remember correctly. More than a zwave one, but it's very easy to install and use.
            I’ve just ordered some more of these, and also a few of their dual relays.
            Lighting strategy is now ZigBee for individual lights and LED strips, but WiFi for light clusters (chandeliers, etc.)
            Looking now for a nice 4-button WiFi had-held scene controller (I did love my ZWave Aeotec MiniMotes!)
              I've practically ordered any device they've shipped lately and I must confess it's the right tool for the job. I'll probably test their binary input device soon.
              Best part is that I've completely integrated them thanks to my mqtt bridge + virtual devices plugin 😁
              I've also deployed 4-5 tasmota based devices in order to get sensors data and I must say zwave is dying behind those tiny wifi devices. I get the point of the mesh and I've invested into zwave, but I think for small setups these are a safer bet.
                I'm now thinking of making a native openLuup plugin for non-MQTT use...
                  That's why I've created the http virtual devices plugin 😁
                  I wanted to stay generic, and I'm considering an Ui to automatically configure devices based on their type. People on the other side usually updates them calling a luup url, or polling them via luup. I've considered the latter as a native option as well.
                    Hmm... problem with configuring my second i3 device. I updated the firmware, and it says it’s the latest, but the version is totally different from my other one! Also, now, neither device is picking up the current time. A bit worrying.
                    Current version: 20200827-070910/v1.8.3@4a8bc427
                    You have latest version of your device!
                    The current Firmware version of your Shelly device is 20200421-183805/master@d834f204 No newer firmware available.
                      I use my own internal ntp time server. I'm not sure why, maybe open a ticket, they're usually very fast to reply.
                        @therealdb said in Shelly i3 as a cheap scene controller for Openluup:
                        maybe open a ticket
                        Yup, done that already. Will be interesting to see the response.
                          Had some interaction with the Shelly folk and currently attached the errant module to the cloud for them to resolve.
                          However, a truckload of new Shelly modules (i3 switches and v2.5 relays) arrived today and the ones I've tried seem to work OK. More than OK, actually. Very impressive. I'm about to replace a Zwave switch controlling a timed thermostat with one of the relays which will have its own built-in timer schedule... no need for a scene!
                          I'm also making a small tweak to openLuup to make it easier to trigger scenes over HTTP.
                            I saw your other post. What about
                            /relay/nn/on
                            /relay/nn/off
                            /relay/nn/toggle
                            /dim/nn/value
                            /color/nn/value
                            /scene/nn
                            This should benefit ha bridge as well.
                              #23
                              I plan to stick with the Shelly API syntax as far as possible.
                              Welcome to Shelly Technical Documentation | Shelly Technical Documentation
                              Using other people's API standards has served me very well (Graphite, WSAPI, Whisper, ...) In fact, this new openLuup API is implemented as a CGI using the WSAPI interface, so it's just an add-on with no change to the basic system at all.
                              I will add dimmers and colours. From this doc:
                              https://shelly.cloud/documents/developers/shelly_cloud_api_access.pdf
                              it seems like the syntax will be
                              turn=[command]white=[value] red=[value]green=[value]blue=[value] gain=[value]key
                              Keys:
                              turn: on or off
                              optional:
                              white, red, green and blue value: 0 -255
                              gain value: 0 -100 it’s only for RGB color
                                This makes sense. I was pushing for a more Tasmota-like (and REST-ful) style, but I'd live with Shelly's one as well 🙂
                                  @akbooer said in Shelly i3 as a cheap scene controller for Openluup:
                                  Done! ... and I have to say that the switch's weekly schedule web interface is the simplest and clearest that I have ever come across.
                                    ArcherS
                                    Shelly Store has at the moment quite good Black Friday discounts on their products.
                                    I just ordered a few to test them out. 🙂
                                    The store was struggling to cope with the load, so I was not alone there...
                                    //ArcherS
                                      I just orderered two shelly uni (just to test them) and two shelly buttons. I'll use those in the cars to automagically handle presence and trigger some scenes. The buttons can call an HTTP endpoint (or send an MQTT message) anytime they'll attach a WiFI network and can ping to signal their presence. We'll see.
                                      Plus, two EMs I had in my cart since the summer, in order to monitor AC consumption on the floors and detect if it's running or not (it's central air and I can already turn on/off, but status is alwasy hit and miss).
                                        I just so much wish that they produced a four button handheld controller.
                                          ArcherS
                                          Yes a multi-button handheld remote would be nice. There are not so many nice Z-wave options either.
                                          I ordered one EM, two Uni, two 16A wallplugs and two i3 units.
                                          The plan to monitor the power consumption of my AC unit with the EM.
                                          I also intend to replace an ageing Fibary Multsensor on my UI5 VeraLite that I use to detect the state of the alarm with an Uni. I tried to include another Fibaro Multisensor into Zway, but it did not perform that well, so I will phase them out. The Uni looks suspiciously similar to the Fibaro Multisensor, let's see how it performs.
                                          The idea with the wallplugs is to monitor power consumption for washer and/or dishwasher, hence 16A to have some margin.
                                          The i3's are just to experiment with for the time being.
                                          //ArcherS
                                            162.2k
