  3. Any decent destination for a Vera Plus?
Hardware
Shelly Wall Display XL
Hardware
Hardware
DIY HomeKey locks via Reactor
Hardware
A recent thread on supporting the ZRC-90 Z-Wave scene controller got me to wonder, what does everybody use and like? I'll start... oh, and no dashboards. I want to hear from you all about dedicated scene controller devices. Dashboards and apps are great to a point, but my experience is that higher WAF is achieved with (a) a dedicated device (b) in a known location (c) with predictable functions and (d) no extra steps to operate (just walk up to it and push a button -- same effort as a light switch/dimmer). She's not wrong. It's a pain to unlock the phone, find the app, open the app, find the device, tap the device, when you can just walk across the room and push a button. Bonus points for something that can be labeled readably (low WAF for stuck-on tape/thermal labels). I have a ZRC-90 and it's great, but it was temperamental to get working on Vera, and wasn't smooth sailing when it made the move to Z-Wave JS either. A couple of include/exclude cycles were needed to get it fully working on both. Since then, I've done a battery change, and while the buttons work as reliably as ever, the device continues to report the old battery level despite having a measurably fresh battery for over a year now. But I would still recommend it. I have a Hank 4-button that is probably the best and most reliable battery-operated scene controller I have ever used. It's small and unobtrusive, so it lives on a lamp base in our living room and controls the room's mood lighting. I'm not sure they're still available. RIP. I just ran across the Minoston MR40Z on Amazon, and I may try one of those. It looks like an installed (in-wall) Decora switch, but the buttons are actually a removable remote that you can pull off the wall and take to the couch. No line power required. Kinda cool. Maybe a good Hank replacement. But, I've never heard of this manufacturer before, and the concern is always "will I be able to buy more/replacements in one/two/five years?" Among the wired controllers, the Zooz ZEN32 seems to be the most popular modern unit. I like it, but the LEDs are too small for my aging eyes to discern their color in daylight -- they are pin-head sized. Four of the five buttons are too small to label, so low WAF. When I started my Z-Wave network, I used the Leviton four-button scene/zone controllers (VRCS4 and VRCZ4), and these are still all over my house. They're glitchy first-gen Z-Wave stuff (Vizia RF+ actually, so compatible but with proprietary features that aren't usable). They're now discontinued for Z-Wave. Leviton's newer units are WiFi, so if I go that route, it's HomeKit via Home Assistant for those. During the pandemic lock-downs, I built a touch-screen scene controller using an Adafruit PyPortal. It had screens with 1 to 8 labeled, colorable soft buttons that could either perform a device function (i.e. publish to MQTT) or take you to another screen, so it was the love-child of scene controller and dashboard. Wife found it agreeable. But it was just a prototype. Memory limitation of the device was an issue because the PyPortal is really an inexpensive teaching device with a big load of Circuit Python overhead, and the graphic display needs a lot of RAM, so it was severely limited. I'm sure it could work out with the right micro and programming closer to the bare metal. Packaging and powering would also need to be addressed. And, at the end of the day, while "cute," it doesn't seem like something I would want to sell with the house if we ended up moving some day. So, I'm interested in what others are doing and using, or more specifically, what your significant others are comfortable with and willing to use.
Hardware
O
Hardware
Hardware
Hardware
LEDVANCE
O
Hardware
Water Flow Meter & Shutoff
Hardware
Hardware
Remote light switch
Hardware
ESP32 / ESP8266
Hardware
Hardware
Hardware
After a long wait for an updated version of the rather crude and unfinished Z-Way integration to HASS, i'm now looking (reluctantly) in to replacing Z-Way with Z-wave JS.. Mind you this is a big existing network, not a new controller stick.. I threw up a docker for z-wave JS UI, and tried to connect it to the UZB stick.. It loads the whole network from the stick, but the driver keeps restarting? Looking at the logs, I see a lot of Dropping message because the driver is not ready to handle it yet. It seems like the stick just keeps talking like z-way was still listening? This ends up in the driver crashing repeatedly.. Any ideas to how I can get them talking? In the code snippet below, you see the driver restarting with the graphic letters, seemingly while the stick is mid-sentence, or because of ACK timeout... 2022-10-02T19:19:59.664Z CNTRLR received additional controller information: Z-Wave API version: 6 (legacy) Z-Wave chip type: ZW050x node type Controller controller role: primary controller is the SIS: true controller supports timers: false nodes in the network: 1, 5, 6, 10, 11, 12, 13, 14, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 32, 33, 34, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 4 7, 48, 52, 55, 69, 70, 71, 73, 74, 75, 77, 78, 79, 81, 82, 83 2022-10-02T19:19:59.765Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated 2022-10-02T19:19:59.766Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated 2022-10-02T19:19:59.767Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated 2022-10-02T19:19:59.768Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 277 2022-10-02T19:19:59.769Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 1 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated 2022-10-02T19:19:59.771Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.39 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [+] [Version] sdkVersion: "6.9.0" 2022-10-02T19:19:59.772Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms 2022-10-02T19:19:59.792Z SERIAL » 0x01050006640f97 (7 bytes) 2022-10-02T19:19:59.792Z DRIVER » [REQ] [SetSerialApiTimeouts] payload: 0x640f 2022-10-02T19:19:59.815Z SERIAL « [ACK] (0x06) 2022-10-02T19:19:59.816Z SERIAL « 0x01050106640f96 (7 bytes) 2022-10-02T19:19:59.817Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.177Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:03.178Z DRIVER version 10.2.0 2022-10-02T19:21:03.179Z DRIVER 2022-10-02T19:21:03.179Z DRIVER starting driver... 2022-10-02T19:21:03.199Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:03.212Z DRIVER serial port opened 2022-10-02T19:21:03.213Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:03.229Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.232Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.233Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.234Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.261Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.273Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.274Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.274Z DRIVER loading configuration... 2022-10-02T19:21:03.298Z CONFIG Using external configuration dir /usr/src/app/store/.config-db 2022-10-02T19:21:03.298Z CONFIG version 10.2.0 2022-10-02T19:21:04.284Z DRIVER beginning interview... 2022-10-02T19:21:04.286Z DRIVER added request handler for AddNodeToNetwork (0x4a)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for ReplaceFailedNode (0x63)... 1 registered 2022-10-02T19:21:04.287Z CNTRLR querying controller IDs... 2022-10-02T19:21:04.484Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:04.485Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:04.487Z SERIAL « 0x0123000400511a9f039900b834787d066515a4b79c45bb3af55ea7f6203006010 (37 bytes) 80120c84d 2022-10-02T19:21:04.489Z SERIAL « [DISCARDED] invalid data 0x9ef4 (2 bytes) 2022-10-02T19:21:04.490Z DRIVER Dropping message because it contains invalid data 2022-10-02T19:21:04.490Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:05.488Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i n 100 ms. 2022-10-02T19:21:05.591Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:05.592Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:06.596Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i n 1100 ms. 2022-10-02T19:21:07.698Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:07.699Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:08.717Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D river.ts:3980:23) at ZWaveController.identify (/usr/src/app/node_modules/zwave-js/src/lib/co ntroller/Controller.ts:713:33) at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js /src/lib/driver/Driver.ts:1207:26) at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive r/Driver.ts:1014:16) 2022-10-02T19:21:08.723Z DRIVER destroying driver instance... 2022-10-02T19:21:08.728Z DRIVER driver instance destroyed 2022-10-02T19:21:08.739Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:08.740Z DRIVER version 10.2.0 2022-10-02T19:21:08.740Z DRIVER 2022-10-02T19:21:08.740Z DRIVER starting driver... 2022-10-02T19:21:08.745Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:08.751Z DRIVER serial port opened 2022-10-02T19:21:08.752Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:08.754Z DRIVER loading configuration... 2022-10-02T19:21:08.755Z SERIAL « 0x01080120c84d9ef40138 (10 bytes) 2022-10-02T19:21:08.757Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:08.758Z DRIVER « [RES] [GetControllerId]
Hardware
Hardware
Hardware
Hardware
Hardware
34 Posts 11 Posters 16.0k Views 9 Watching
  • wmarcolinW Offline
    parkercP 1 Reply Last reply
    • MatohlM Offline
      MatohlM Offline
      Matohl
      I use my Vera+ for the z-wave and 433 devices (I even have one in reserve) together with MSR and Home Assistant, working well. If I remember well I think @toogledbits have said he is experimenting with the MSR on Vera but I'm not sure if that is on the table today.
      • MatohlM Matohl
        @matohl said in Any decent destination for a Vera Plus?:
        That was Ezlo... I do have it running on an Ezlo Plus. Not something I'm probably going to release, though, at least, not just yet.
          I still use a Vera Edge as a Zwave to HTTP bridge, as a peripheral to an openLuup system.
            I have two VeraPlus running at the cabin (in separate houses), one at my parents house, and they work well with only a few devices(z-wave and 433) and cameras.
            I will probably have to replace them when ezlo pulls the plug on the server though.
            G therealdbT 2 Replies Last reply
            • PerHP PerH
              @perh Have they indicated an official EOL date now?
              • PerHP PerH
                @perh just decouple them and you’ll be fine. I’m running off the cloud in the latest year and my Vera plus has never been more stable than today. It’s just a Zwave bridge with a reload once per week, due to some code still running and that I’ll port outside very soon.
                GitHub - toggledbits/Vera-Decouple: Scripts to decouple Vera Home Automation Controllers from their parent cloud services
                Scripts to decouple Vera Home Automation Controllers from their parent cloud services - toggledbits/Vera-Decouple
                  But then i'd have to figure out a way to remote connect to them first.. how do you do that? Can Dataplicity be installed perhaps?
                  Haven't read about EOL date, so it might be years still. 🙂
                  • PerHP PerH
                    @perh I'm using my Synology to (securely) expose it when needed, under https. For longer maintenance, I'm just using a VPN.
                    Having heavily invested in automations, I'm honestly doing this no more than 2-3 times per year. I rarely use remote control, so this is working very well fom me, and overall, the solution is more secure, since I'm not exposing anything to them. As I've said, it has never been so stable.
                      Hi!
                      Reading the comments the destination I am giving to my Vera Plus are:
                      • simulation lab, I have installed the Switchboard Plugin, the old and good Reactor and SiteSensor from @toggledbits , and I think I will download the tools from @therealdb;
                      • I'm also using the Vera with SiteSensor to ping the internet, Hubitat, and MSR, as external control. If one fails, I send a Telegram, connect a switch, and then initiate action on either Hubitat or MSR.
                      Now a question, I do not know if @toggledbits can help.
                      Is it possible to make some settings in MSR, so I can exclude devices that are published from Vera to MSR? I see for example that the three pings that I set up are triggering the MSR unnecessarily, as well as other devices from the lab.
                      Is it possible to have an exclusion table that I don't need MSR to load and synchronize some devices from Vera?
                      • wmarcolinW wmarcolin
                        Hi!
                        @wmarcolin said in Any decent destination for a Vera Plus?:
                        Specifically for VeraController, you can use filter_entity in your config for the controller. It's an arrayobject, and you list the (would-be) entity IDs you want to exclude.
                            ...(redacted other config)
                            implementation: VeraController
                            config:
                              source: "http://192.168.0.123:3480"
                              filter_entity:
                                device_10: true   # true to filter the entity out, false to keep it in
                                device_94: true
                                device_401: true
                        Or, if you are excluding almost all of the devices, and just want Reactor to pick up a few, use accept_entity using the same form, listing the IDs of the devices you want Reactor to have.
                        EDIT: Whoops! It's not an array, it's an object. Fixed above.
                        wmarcolinW tunnusT 2 Replies Last reply
                              config:
                                filter_entity:
                                  device_94: true
                                  device_401: true
                          @toggledbits said in Any decent destination for a Vera Plus?:
                          filter_entity
                          @toggledbits hi!
                          Thanks for the prompt information, but I think something is not working right.
                          I tested the deletion first:
                              config:
                                source: 'http://192.168.33.6:3480'
                                filter_entity:
                                  - device_15
                                  - device_6
                                  - device_13
                          See that it didn't remove the devices.
                          Then I tested for keeping only the ones I am interested in.
                              config:
                                accept_entity:
                                  - device_9
                          Then removed all the devices.
                          Log second scenario, no error:
                          [latest-22023]2022-01-24T19:28:34.186Z <OWMWeatherController:null> Module OWMWeatherController v21354
                          [latest-22023]2022-01-24T19:28:34.189Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                          [latest-22023]2022-01-24T19:28:34.193Z <SystemController:null> Module SystemController v21358
                          [latest-22023]2022-01-24T19:28:34.195Z <Structure:INFO> Starting controller VeraController#vera
                          [latest-22023]2022-01-24T19:28:34.196Z <VeraController:NOTICE> VeraController#vera starting
                          [latest-22023]2022-01-24T19:28:34.248Z <VeraController:INFO> VeraController#vera loaded mapping ver 21346 rev 1 format 1 notice
                          [latest-22023]2022-01-24T19:28:34.250Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
                          [latest-22023]2022-01-24T19:28:34.251Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
                          [latest-22023]2022-01-24T19:28:34.252Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                          [latest-22023]2022-01-24T19:28:34.269Z <Structure:INFO> Starting controller HubitatController#hubitat
                          [latest-22023]2022-01-24T19:28:34.285Z <Structure:INFO> Starting controller DynamicGroupController#groups
                          [latest-22023]2022-01-24T19:28:34.287Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
                          Since the device is not included, the MSR action shows an error in the log.
                          [latest-22023]2022-01-24T19:28:35.487Z <Rule:INFO> Hard Reset Sat 4am (Rule#rule-kxp4v1ly) evaluated; trigger state unchanged (false); rule state remains RESET
                          [latest-22023]2022-01-24T19:28:35.494Z <Rule:CRIT> ReferenceError: Can't find entity "vera>device_9"
                              at Predicate._evaluateCondition (C:\MSR\reactor\server\lib\Predicate.js:635:27)
                              at Predicate._evaluateGroup (C:\MSR\reactor\server\lib\Predicate.js:1015:103)
                              at Predicate._evaluateCondition (C:\MSR\reactor\server\lib\Predicate.js:623:47)
                              at Predicate.evaluate (C:\MSR\reactor\server\lib\Predicate.js:331:38)
                              at Rule._evaluate (C:\MSR\reactor\server\lib\Rule.js:830:62)
                              at async C:\MSR\reactor\server\lib\Rule.js:786:17
                          [latest-22023]2022-01-24T19:28:35.496Z <Rule:CRIT> ReferenceError: Can't find entity "vera>device_9"
                            @toggledbits opened Mantis 300.
                              Sorry, not a bug, I just gave you the wrong syntax. I fixed my earlier post.
                              wmarcolinW 1 Reply Last reply
                                @toggledbits testing!
                                Perfect removed the indicated
                                  filter_entity:
                                    device_15: true
                                    device_6: true
                                    device_13: true
                                Ok, kept only the informed one that had to stay, removed all the others.
                                  accept_entity:
                                    device_9: true
                                Thank you very much!
                                      config:
                                        filter_entity:
                                          device_94: true
                                          device_401: true
                                  @toggledbits double-checking that for InfluxFeed plugin configuration syntax is:
                                    filter_entities:
                                           - "vera>device_398"
                                           - "vera>device_413"
                                    Check the docs; clearly after what I did to @wmarcolin , my memory is not reliable of these details! 🙂
                                    In any case, the indenting is way off.
                                      @toggledbits testing with version 22025 we have the following situation.
                                      In the manual (https://reactor.toggledbits.com/docs/Troubleshooting-Entities/), it looks like this:
                                        accept_entity:
                                          "device_123": true
                                        dump_entity:
                                          "device_123": true
                                      I tested it this way in the new version and it works like the manual - without quotes (have to fix the manual):
                                          config:
                                            accept_entity:
                                              device_9: true
                                      So, I tested the new version that I understand you have aligned with the other systems:
                                            accept_entity:
                                              - device_9
                                      OR
                                            filter_entity:
                                              - device_9
                                      IT WORKED!!!
                                      Testing the way that mentioned @tunnus :
                                            filter_entity:
                                              - "vera>device_9"
                                      IT DOESN'T WORK, with or without the quotes it doesn't work.
                                      IN SUMMARY, the form can be for Vera, don't know for other hubs:
                                        accept_entity:
                                          device_9: true
                                      or
                                        accept_entity:
                                          - device_9
                                      I hope I have helped.
                                          accept_entity:
                                            "device_123": true
                                          dump_entity:
                                            "device_123": true
                                            config:
                                              accept_entity:
                                                device_9: true
                                              accept_entity:
                                                - device_9
                                        OR
                                              filter_entity:
                                                - device_9
                                        IT WORKED!!!
                                              filter_entity:
                                                - "vera>device_9"
                                          accept_entity:
                                            device_9: true
                                        or
                                          accept_entity:
                                            - device_9
                                        The reason it doesn't work is because you are including a controller ID to make it a canonical ID. Canonical IDs are not used in that context because the configuration is already specific to one controller -- you don't tell it the controller for filter_entity in a VeraController config because it's in the controller's config, so it already knows.
                                        InfluxFeed is different because it watches entities for all controllers, so when identifying an entity, you have to use a canonical ID.
                                        As for quotes or no quotes, as long as the string doesn't contain any characters with special meaning to YAML, you don't need quotes. Do you know what those are? I don't keep that in my head. So I default to using quotes whenever it's anything other than A-Z, 0-9 and underscore. The > used in canonical IDs can definitely cause problems, so I always quote canonical IDs.
                                          New use for Vera, and helping to save him from the incinerator 🙂
                                          One of the eventual problems I am having with Hubitat, are devices that are added with Security S0, and several community posts report that this is a problem.
                                          So today I removed and reinstalled what had S0, but 4 there was no way to get in without Security, and to not create a problem in Hubitat's z-wave network, I installed again in Vera: Door Lock Yale B1L YRD110-ZW-0BP, Smoke Sensor Smoke (2x) and Bulb Zipato RGBW2.US.
                                          Of course I had problems to include in the Vera, the bulb is failing, everything we already know in the Vera. Just unfortunate that Hubitat can not bypass this problem.
