  3. Can a Ezlo Plus be bridged to a Vera Plus
Hardware
Shelly Wall Display XL
Hardware
Hardware
DIY HomeKey locks via Reactor
Hardware
A recent thread on supporting the ZRC-90 Z-Wave scene controller got me to wonder, what does everybody use and like? I'll start... oh, and no dashboards. I want to hear from you all about dedicated scene controller devices. Dashboards and apps are great to a point, but my experience is that higher WAF is achieved with (a) a dedicated device (b) in a known location (c) with predictable functions and (d) no extra steps to operate (just walk up to it and push a button -- same effort as a light switch/dimmer). She's not wrong. It's a pain to unlock the phone, find the app, open the app, find the device, tap the device, when you can just walk across the room and push a button. Bonus points for something that can be labeled readably (low WAF for stuck-on tape/thermal labels). I have a ZRC-90 and it's great, but it was temperamental to get working on Vera, and wasn't smooth sailing when it made the move to Z-Wave JS either. A couple of include/exclude cycles were needed to get it fully working on both. Since then, I've done a battery change, and while the buttons work as reliably as ever, the device continues to report the old battery level despite having a measurably fresh battery for over a year now. But I would still recommend it. I have a Hank 4-button that is probably the best and most reliable battery-operated scene controller I have ever used. It's small and unobtrusive, so it lives on a lamp base in our living room and controls the room's mood lighting. I'm not sure they're still available. RIP. I just ran across the Minoston MR40Z on Amazon, and I may try one of those. It looks like an installed (in-wall) Decora switch, but the buttons are actually a removable remote that you can pull off the wall and take to the couch. No line power required. Kinda cool. Maybe a good Hank replacement. But, I've never heard of this manufacturer before, and the concern is always "will I be able to buy more/replacements in one/two/five years?" Among the wired controllers, the Zooz ZEN32 seems to be the most popular modern unit. I like it, but the LEDs are too small for my aging eyes to discern their color in daylight -- they are pin-head sized. Four of the five buttons are too small to label, so low WAF. When I started my Z-Wave network, I used the Leviton four-button scene/zone controllers (VRCS4 and VRCZ4), and these are still all over my house. They're glitchy first-gen Z-Wave stuff (Vizia RF+ actually, so compatible but with proprietary features that aren't usable). They're now discontinued for Z-Wave. Leviton's newer units are WiFi, so if I go that route, it's HomeKit via Home Assistant for those. During the pandemic lock-downs, I built a touch-screen scene controller using an Adafruit PyPortal. It had screens with 1 to 8 labeled, colorable soft buttons that could either perform a device function (i.e. publish to MQTT) or take you to another screen, so it was the love-child of scene controller and dashboard. Wife found it agreeable. But it was just a prototype. Memory limitation of the device was an issue because the PyPortal is really an inexpensive teaching device with a big load of Circuit Python overhead, and the graphic display needs a lot of RAM, so it was severely limited. I'm sure it could work out with the right micro and programming closer to the bare metal. Packaging and powering would also need to be addressed. And, at the end of the day, while "cute," it doesn't seem like something I would want to sell with the house if we ended up moving some day. So, I'm interested in what others are doing and using, or more specifically, what your significant others are comfortable with and willing to use.
Hardware
O
Hardware
Hardware
Hardware
LEDVANCE
O
Hardware
Water Flow Meter & Shutoff
Hardware
Hardware
Remote light switch
Hardware
ESP32 / ESP8266
Hardware
Hardware
Hardware
After a long wait for an updated version of the rather crude and unfinished Z-Way integration to HASS, i'm now looking (reluctantly) in to replacing Z-Way with Z-wave JS.. Mind you this is a big existing network, not a new controller stick.. I threw up a docker for z-wave JS UI, and tried to connect it to the UZB stick.. It loads the whole network from the stick, but the driver keeps restarting? Looking at the logs, I see a lot of Dropping message because the driver is not ready to handle it yet. It seems like the stick just keeps talking like z-way was still listening? This ends up in the driver crashing repeatedly.. Any ideas to how I can get them talking? In the code snippet below, you see the driver restarting with the graphic letters, seemingly while the stick is mid-sentence, or because of ACK timeout... 2022-10-02T19:19:59.664Z CNTRLR received additional controller information: Z-Wave API version: 6 (legacy) Z-Wave chip type: ZW050x node type Controller controller role: primary controller is the SIS: true controller supports timers: false nodes in the network: 1, 5, 6, 10, 11, 12, 13, 14, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 32, 33, 34, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 4 7, 48, 52, 55, 69, 70, 71, 73, 74, 75, 77, 78, 79, 81, 82, 83 2022-10-02T19:19:59.765Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated 2022-10-02T19:19:59.766Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated 2022-10-02T19:19:59.767Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated 2022-10-02T19:19:59.768Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 277 2022-10-02T19:19:59.769Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 1 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated 2022-10-02T19:19:59.771Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.39 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [+] [Version] sdkVersion: "6.9.0" 2022-10-02T19:19:59.772Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms 2022-10-02T19:19:59.792Z SERIAL » 0x01050006640f97 (7 bytes) 2022-10-02T19:19:59.792Z DRIVER » [REQ] [SetSerialApiTimeouts] payload: 0x640f 2022-10-02T19:19:59.815Z SERIAL « [ACK] (0x06) 2022-10-02T19:19:59.816Z SERIAL « 0x01050106640f96 (7 bytes) 2022-10-02T19:19:59.817Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.177Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:03.178Z DRIVER version 10.2.0 2022-10-02T19:21:03.179Z DRIVER 2022-10-02T19:21:03.179Z DRIVER starting driver... 2022-10-02T19:21:03.199Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:03.212Z DRIVER serial port opened 2022-10-02T19:21:03.213Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:03.229Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.232Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.233Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.234Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.261Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.273Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.274Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.274Z DRIVER loading configuration... 2022-10-02T19:21:03.298Z CONFIG Using external configuration dir /usr/src/app/store/.config-db 2022-10-02T19:21:03.298Z CONFIG version 10.2.0 2022-10-02T19:21:04.284Z DRIVER beginning interview... 2022-10-02T19:21:04.286Z DRIVER added request handler for AddNodeToNetwork (0x4a)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for ReplaceFailedNode (0x63)... 1 registered 2022-10-02T19:21:04.287Z CNTRLR querying controller IDs... 2022-10-02T19:21:04.484Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:04.485Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:04.487Z SERIAL « 0x0123000400511a9f039900b834787d066515a4b79c45bb3af55ea7f6203006010 (37 bytes) 80120c84d 2022-10-02T19:21:04.489Z SERIAL « [DISCARDED] invalid data 0x9ef4 (2 bytes) 2022-10-02T19:21:04.490Z DRIVER Dropping message because it contains invalid data 2022-10-02T19:21:04.490Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:05.488Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i n 100 ms. 2022-10-02T19:21:05.591Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:05.592Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:06.596Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i n 1100 ms. 2022-10-02T19:21:07.698Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:07.699Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:08.717Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D river.ts:3980:23) at ZWaveController.identify (/usr/src/app/node_modules/zwave-js/src/lib/co ntroller/Controller.ts:713:33) at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js /src/lib/driver/Driver.ts:1207:26) at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive r/Driver.ts:1014:16) 2022-10-02T19:21:08.723Z DRIVER destroying driver instance... 2022-10-02T19:21:08.728Z DRIVER driver instance destroyed 2022-10-02T19:21:08.739Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:08.740Z DRIVER version 10.2.0 2022-10-02T19:21:08.740Z DRIVER 2022-10-02T19:21:08.740Z DRIVER starting driver... 2022-10-02T19:21:08.745Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:08.751Z DRIVER serial port opened 2022-10-02T19:21:08.752Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:08.754Z DRIVER loading configuration... 2022-10-02T19:21:08.755Z SERIAL « 0x01080120c84d9ef40138 (10 bytes) 2022-10-02T19:21:08.757Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:08.758Z DRIVER « [RES] [GetControllerId]
Hardware
Hardware
Hardware
Hardware
Hardware
2 Posts 2 Posters 797 Views 2 Watching
  • L Offline
    L Offline
    Lieber77
    I have a legacy Vera system that in my home and I need to add a few devices to a cottage on my property. The Vera zwave won't see devices that far away. Both the house and cottage are on the same LAN. Can I bridged an Ezlo Plus to my existing Vera plus and if so are there instructions?
      MSR is the best route at the moment. You could easily use it to map your Ezlo devices to virtual ones in Vera. If you need virtual devices, try the ones in my signature. Despite its name, you could use them as Virtual Devices with no HTTP actions attached and ge the change in status in MSR. Not trivial, but your simplest route at the moment.
        137.6k
