  4. Why is this Green and ticked when its not true ? And how to do OR
Error: Command timeout
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
HA 2025.9.4 Supported Yet?
19 Posts 3 Posters 2.1k Views 2 Watching
    My condition is that the current set point of the Thermostat is greater than 10
    The current set point is currently 10
    So I'd expect this to be not ticked and not green aka false.
    If I used >= then yeah OK but not when I use >
    Also I am not sure I have this correct ?
    I want an OR in between the two window sensors.
    So if the setpoint is greater than 10 and window 1 is open OR window 2 is open then fire my action.
    In PLEG I just write my condition like this:
    Thermostat_SetPoint > 10.00 and (MasterBedWindow_TrippedStatus==1 or KidsBedWindow_TrippedStatus==1)
    ElcidE 1 Reply Last reply
      wrote on last edited by Elcid
      @cw-kid set up like below and with or
      So top comment and any one of other comments would need to be true.
      Obviously the comments would be entities
      • ElcidE Elcid
        @elcid Hiya mate.
        So the Thermostat's current setpoint >10 trigger that also goes in to the group or would that remain at the top like this>
        Basically if the current setpoint is over 10 degrees and either of the upstairs windows are open or indeed both of them are open, then I want it to fire the HTTP command to Node-Red to do the TTS on the Google Speaker.
          what you have is
          Themostat > 10 and (master bedroon or kidbed window open)
          so for group to go true the temp has to be 11 or greater and one window has to be true
          • ElcidE Elcid
            what you have is
            @elcid That's exactly what I wanted then. (I think)
            Assuming it will fire if both windows are open also.
            Or one or the other window is open.
            I will test it.
            Cheers.
              Yes will fire/go true, if one or more windows,
              You can also add time condition, say you wanted to wait 60 seconds just in case some one just opened window for a few seconds.
              click 3 dots for other options on trigger/condition
                Its not working.
                Because its not evaluating the current set point properly it seems.
                I set it to 9 which is less than 10 but its still true when it should be false
                • ElcidE Elcid
                  @elcid said in Why is this Green and ticked when its not true ? And how to do OR:
                  That's a good idea. I see the extra options but not sure where to stick in my 60 second delay without breaking it even more LOL
                    use sustained for so windows have to be open the sustained time.
                    Your group appears to be working as it is true. What are your reactions
                    • ElcidE Elcid
                      It shouldn't be true though, it should be false if its not > than 10
                      So how can it be true when the thermostat is set to 9 ?
                      Reactions ? You mean what is my action ?
                      It just sends a HTTP GET request out.
                        Its not clear. It says "False" at the top in the blue bar.
                        But its green and ticked.
                        The current set point is 9.
                        My trigger is >10
                        So why is it green and ticked ?
                        If I open a window now it runs the action when it shouldn't because the heating is off as its currently 10 or less.
                        I only want the action to run when the heating is on - setpoint is greater than 10.
                          Reminder: this is the first time this code has run in anyone's hands other than mine. 🙂 It is also several years less used and tested than Vera Reactor.
                          There is a bug in numeric comparisons, and it will be fixed for today's build (later this evening).
                            Thought it was me again doing something stupid.
                              How do we update the Raspberry Pi installation when you release an update ?
                                No it's me. So sorry. Updates are easy. All you need to do is stop Reactor, un-tar the release package in the reactor directory, and don't run the install script. Just start Reactor again. That will leave your config files intact (the script shouldn't clobber them anyway, but then, 9 isn't greater than 10, is it? Sigh....)
                                  @toggledbits Hi
                                  Was this fixed in the 21050 release ?
                                  Thank you.
                                    @toggledbits said in Why is this Green and ticked when its not true ? And how to do OR:
                                    No LOL I was having a blonde moment 😲
                                      @cw-kid said in Why is this Green and ticked when its not true ? And how to do OR:
                                      Then I must have been having an early senior moment when I leaked that one. Sheesh.
                                      I do believe that all of the numeric comparisons are working now.
                                        @toggledbits Just updated to 0.1.21051 and I can confirm its now working with my Thermostat and the trigger >10
                                        10 or below is false and 11 or above is true.
                                        Thank you
                                        • Error: Command timeout
                                        • [Solved] Local expression in Rule does not evaluate as they used to do
                                          74.3k
                                          583
                                        • Shelly Wall Display XL
