  4. Sunset with offset didn't run
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
34 Posts 5 Posters 11.7k Views 4 Watching
    Also I have seen this saving problem on more than just one rule.
    I've seen in on a few rules when either adding items like additional triggers or removing items.
    Then you cannot click either of the two save buttons.
    Only the red exit w/o saving button works.
    K Offline
    K Offline
    kfxo
    @cw-kid said in Sunset with offset didn't run:
    I have been able to possibly reproduce your saving issue. I have noticed with rules that have a Date/Time After Trigger cannot be modified and saved.
      It's 2 29 am here now this rule just fired and turned on my lounge lamps.
      K 1 Reply Last reply
        Actually any time I manually turn off the lounge lamps via my Harmony remote it's now firing the MSR rule and turning them back on.
          @toggledbits as I said your welcome to connect to my laptop and edit the rules for yourself and press a save button to see what happens.
            I was also the one who had issues saving PLEG changes many years ago and Richard eventually got to the bottom of it and managed to sort out the issue.
            Maybe I have bad luck, but I cannot currently save any MSR rules I modify by adding new triggers or deleting them.
            I am only reporting what I am seeing.
              K Offline
              K Offline
              kfxo
              I think there might be something going on with sunrise/sunset too. Im pretty sure sunset was 90 minutes late triggering for me. Im doing some more testing on that though to confirm.
              If your rule is the same as posted above, this is because you have a condition in the rule for the lamp being false, meaning the rule will be false when the lamp is on and then when it goes off, it becomes true again.
                I'm not saying my rule is correct.
                It most likely isn't
                I wanted to include a check that the turn on lamps rule is only run if the lamps are off in the first place.
                If the lamps are already on then there's no need to have the rule action run.
                So if I've set it up wrong what is the best way to handle this
                I am a Reactor newbie..
                  K Offline
                  K Offline
                  kfxo
                  You need to use the constraints. These are new and Im not exactly positive on the answer at this time but I think you would check if the lights are off in the constraint.
                    OK thanks. I was advised not to use Contraints whilst learning MSR.
                    Seems I have a learning curve to get over and I apologise for being a pain in the arse for the next few months to everyone in this forum.. 😁
                    • Black CatB Offline
                      Black CatB Offline
                      Black Cat
                      Stop thinking PLEG......It will only frustrate you especially if you are trying to test the status of a device.
                      I'm not sure if you can actually do it as you would in PLEG, yes, I know it's frustrating but to move forward you need to unlearn what you already know.
                      aka Zedrally
                        Make sure you upgrade to 21050 if you haven't already.
                          I have the same issue using a different web browser Microsoft Edge. I added a new trigger to an existing rule and the save buttons aren't clickable.
                          Are there any instructions on how to upgrade to the new version of Reactor for Raspberry Pi ?
                          Thank you
                          I've found the update instructions trying it now.
                          ElcidE 1 Reply Last reply
                            Thank you
                            @cw-kid
                            Installation - Reactor - Multi-Hub Automation
                              I'm stuck on the part that says restart reactor. How do I do that ?
                                wrote on last edited by Elcid
                                #22
                                "node app.js" - if still in trial mode
                                or
                                "nohup ./app.sh &" - if running under script
                                  #23
                                  I've messed it up, looks like I have the new reactor installation within the old one, as I now have two reactor folders.
                                  I guess I'll delete the reactor sub-folder and try it again.
                                  The date stamps are yesterday though.
                                    #24
                                    Yes you want to be in the folder that holds the reactor folder (documents), when you tar xzvf.... . I found the instructions confusing to.
                                      Is this command wrong then ? The tar.gz file is located in the /Documents folder.
                                      cd /home/pi/Documents/reactor
                                      tar xzvf /home/pi/Documents/reactor-0.1-21050-f5e9257.tar.gz
                                        Like that then
                                          Yes, that's correct
                                            163.0k
