  4. Sunset with offset didn't run
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
34 Posts 5 Posters 11.7k Views 4 Watching
    I'm stuck on the part that says restart reactor. How do I do that ?
      wrote on last edited by Elcid
      #22
      "node app.js" - if still in trial mode
      or
      "nohup ./app.sh &" - if running under script
        #23
        I've messed it up, looks like I have the new reactor installation within the old one, as I now have two reactor folders.
        I guess I'll delete the reactor sub-folder and try it again.
        The date stamps are yesterday though.
          #24
          Yes you want to be in the folder that holds the reactor folder (documents), when you tar xzvf.... . I found the instructions confusing to.
            Is this command wrong then ? The tar.gz file is located in the /Documents folder.
            cd /home/pi/Documents/reactor
            tar xzvf /home/pi/Documents/reactor-0.1-21050-f5e9257.tar.gz
              Like that then
                Yes, that's correct
                  OK I am now on version 0.1.21050
                    OK I just added two new triggers to an existing rule and I can now save OK. So looks like Patrick has fixed it, many thanks.
                    Now I need to figure out why this sunset rule to turn on my lounge lamps isn't working any tips ?
                      I think I am not understanding this:
                      before <time> -- will be true between midnight and time (changes to false at time);
                      after <time> -- will be true between time and midnight (changes to false at midnight).
                      This is the current triggers
                      Late last night around 2:30am when I turned off the lamps the rule was then firing and turning them back on.
                        #31
                        Would that not be after sunset - 40
                        so if sunset is 5.00pm
                        the light would turn on only after 4.20pm up to midnight
                          #32
                          Yes I think I made a mistake by setting it to "before". I'll change it to after and see what happens tonight.
                            #33
                            The rule also fired because you turned the lamps off, which made lamp conditions go true. Your logic needs to be deeper than this for what you want, I think. What you have basically written here is 'turn on the lamps after sunset if they are off and not in away or vacation', and that doesn't seem to be what you intended, but it did what it was told.
                            Agree with Elcid... your "before" on sunset needs to be an "after".
                            And, if you are really wanting this only to fire when the lights are off, then yes, it's time for Constraints as the easiest way... place your light conditions in the Constraints. Remember to set AND/OR properly: use AND if all lights have to be off for the rule to fire, or OR if the rule can fire as long as any of the monitored lights is off.
                              #34
                              The sunset never became true the lights didn't turn on. I changed it to "after"
                              I've deleted the rule and created it again from scratch. See what happens tomorrow.
                              UPDATE:
                              This worked today using Constraints instead of having everything in Triggers.
                                163.0k
