  4. Sunset with offset didn't run
34 Posts 5 Posters 10.9k Views 4 Watching
    #23
    I've messed it up, looks like I have the new reactor installation within the old one, as I now have two reactor folders.
    I guess I'll delete the reactor sub-folder and try it again.
    The date stamps are yesterday though.
      wrote on last edited by Elcid
      #24
      Yes you want to be in the folder that holds the reactor folder (documents), when you tar xzvf.... . I found the instructions confusing to.
        Is this command wrong then ? The tar.gz file is located in the /Documents folder.
        cd /home/pi/Documents/reactor
        tar xzvf /home/pi/Documents/reactor-0.1-21050-f5e9257.tar.gz
          Like that then
            Yes, that's correct
              OK I am now on version 0.1.21050
                OK I just added two new triggers to an existing rule and I can now save OK. So looks like Patrick has fixed it, many thanks.
                Now I need to figure out why this sunset rule to turn on my lounge lamps isn't working any tips ?
                  I think I am not understanding this:
                  before <time> -- will be true between midnight and time (changes to false at time);
                  after <time> -- will be true between time and midnight (changes to false at midnight).
                  This is the current triggers
                  Late last night around 2:30am when I turned off the lamps the rule was then firing and turning them back on.
                    #31
                    Would that not be after sunset - 40
                    so if sunset is 5.00pm
                    the light would turn on only after 4.20pm up to midnight
                      #32
                      Yes I think I made a mistake by setting it to "before". I'll change it to after and see what happens tonight.
                        #33
                        The rule also fired because you turned the lamps off, which made lamp conditions go true. Your logic needs to be deeper than this for what you want, I think. What you have basically written here is 'turn on the lamps after sunset if they are off and not in away or vacation', and that doesn't seem to be what you intended, but it did what it was told.
                        Agree with Elcid... your "before" on sunset needs to be an "after".
                        And, if you are really wanting this only to fire when the lights are off, then yes, it's time for Constraints as the easiest way... place your light conditions in the Constraints. Remember to set AND/OR properly: use AND if all lights have to be off for the rule to fire, or OR if the rule can fire as long as any of the monitored lights is off.
                          #34
                          The sunset never became true the lights didn't turn on. I changed it to "after"
                          I've deleted the rule and created it again from scratch. See what happens tomorrow.
                          UPDATE:
                          This worked today using Constraints instead of having everything in Triggers.
                            145.5k
