  4. Support for 3rd party Vera plugins ?
39 Posts 5 Posters 14.7k Views 5 Watching
    OK. Also, the way some plugins work, they create standard devices, and some of those standard devices already have at least some support, if not full. So for the Hue lights, for example, you should be able to find an AltHue child and turn it on/off, set its color, etc. It may be missing special Hue functions, but it should do the generic stuff already. If that's not the case, we'll need to investigate why. So, if you've got a Hue-based color light or strip, give it a try in the Entities list and see (and report here) what works and what doesn't.
    I'm always working in the background on device support. So if you give me a list of the plugins you use, I can give those some priority.
    • MatohlM Offline
      MatohlM Offline
      Matohl
      The AltHue plugin works fine as well as RfxTrx plugin and, of course, your own Switchboard, Virtual Sensor, Sonos. I have not installed, yet, the Harmony plugin so I can not test it now, although I have a Harmony in the TV-room.
        Switchboard and VirtualSensor come along for free because I used standard devices for those plugins. Sonos I had already written the mappings for, because I use Sonos around my house, so I at least grabbed what I know I can get right. I'm thrilled to hear that RfxTrx works.
        I just did mappings for color lights, which were incomplete (attributes but no actions yet), and I just did both attributes and actions for a generic thermostat. Unfortunately, I can't easily test thermostat, because my own thermostat plugins don't use Vera's standard thermostat devices (they're horribly broken and hard to write a functional plugin/virtual on top of). So I'm curious how that will pan out. All that will be in tonight's 21054.
        MatohlM 1 Reply Last reply
          Can confirm that Vera Reactor has Harmony support. You’re able to start/end activities and send device commands too
          MatohlM cw-kidC 2 Replies Last reply
            MatohlM Offline
            MatohlM Offline
            Matohl
            @pabla Yes, I used it before in Reactor but do you know if it's working in MSR as well?
            PablaP 1 Reply Last reply
            • MatohlM Matohl
              @matohl Can't confirm for MSR unfortunately
                MatohlM Offline
                MatohlM Offline
                Matohl
                @toggledbits Great!
                  Don't sweat it. Let me take a look and give a mapping a try. Just keep in mind, I don't have the device, so I'm flying totally blind--I can build, but I can't test. I rely on your hands and eyes for that.
                  • MatohlM Offline
                    MatohlM Offline
                    Matohl
                    Dont worry, I was refering to your comment "...mappings for color lights, which were incomplete...". We will take us on the Harmony when it comes 🙂
                      @pabla said in Support for 3rd party Vera plugins ?:
                      Sounds promising if it already works in Reactor plugin for Vera.
                      In addition I'd need to be able to also tell which Harmony Activity is currently active? Or if the Power Off activity is active etc.
                      • MatohlM Matohl
                        @matohl said in Support for 3rd party Vera plugins ?:
                        In MSR or in the Reactor plugin for Vera?
                          wrote on last edited by Pabla
                          @cw-kid Yes
                          @cw-kid said in Support for 3rd party Vera plugins ?:
                            MatohlM Offline
                            MatohlM Offline
                            Matohl
                            @cw-kid Both
                            • MatohlM Matohl
                              @cw-kid Both
                              @matohl Is it ?
                              I can't see how to run a Hue Scene or start the ColorLoop off the Hue Bridge.
                              There doesn't appear to be any Actions implemented yet against the AltHue device.
                              MatohlM 2 Replies Last reply
                                @matohl Is it ?
                                MatohlM Offline
                                MatohlM Offline
                                Matohl
                                @cw-kid You are running the AltHue app in Vera, right? Not looking at the Hue app but do you see your lamps in MSR as entities?
                                  @matohl Is it ?
                                  MatohlM Offline
                                  MatohlM Offline
                                  Matohl
                                  @cw-kid ! Like this?
                                    Yes the AltHue plugin.
                                    Yes I see my Hue lamps listed in the Entities
                                    I can turn them on and off and control other basic stuff.
                                    But can't see how to initiate a hue scene for example.
                                    • MatohlM Offline
                                      MatohlM Offline
                                      Matohl
                                      #21
                                      Ok Hue scenes I missed that. That is probably not implemented yet
                                        AltHue lamps in Vera are standard Vera RGB dimmer devices are they not. That is why they are working now with MSR for basic controls.
                                        However I don't think any of the AltHue plugin specific functions have been implemented yet in to MSR.
                                          #23
                                          You can see better what I mean from this screen shot from PLEG.
                                          We are currently missing the functions of the althue service ID
                                          RunHueScene and SetEffect (ColorLoop) etc.
                                            160.4k
