  4. Support for 3rd party Vera plugins ?
39 Posts 5 Posters 14.7k Views 5 Watching
    Can confirm that Vera Reactor has Harmony support. You’re able to start/end activities and send device commands too
    @pabla said in Support for 3rd party Vera plugins ?:
    Sounds promising if it already works in Reactor plugin for Vera.
    In addition I'd need to be able to also tell which Harmony Activity is currently active? Or if the Power Off activity is active etc.
    PablaP 1 Reply Last reply
    • MatohlM Matohl
      The AltHue plugin works fine as well as RfxTrx plugin and, of course, your own Switchboard, Virtual Sensor, Sonos. I have not installed, yet, the Harmony plugin so I can not test it now, although I have a Harmony in the TV-room.
      @matohl said in Support for 3rd party Vera plugins ?:
      In MSR or in the Reactor plugin for Vera?
      MatohlM 1 Reply Last reply
        wrote on last edited by Pabla
        @cw-kid Yes
        @cw-kid said in Support for 3rd party Vera plugins ?:
          MatohlM Offline
          MatohlM Offline
          Matohl
          @cw-kid Both
          • MatohlM Matohl
            @cw-kid Both
            @matohl Is it ?
            I can't see how to run a Hue Scene or start the ColorLoop off the Hue Bridge.
            There doesn't appear to be any Actions implemented yet against the AltHue device.
            MatohlM 2 Replies Last reply
              @matohl Is it ?
              MatohlM Offline
              MatohlM Offline
              Matohl
              @cw-kid You are running the AltHue app in Vera, right? Not looking at the Hue app but do you see your lamps in MSR as entities?
                @matohl Is it ?
                MatohlM Offline
                MatohlM Offline
                Matohl
                @cw-kid ! Like this?
                  Yes the AltHue plugin.
                  Yes I see my Hue lamps listed in the Entities
                  I can turn them on and off and control other basic stuff.
                  But can't see how to initiate a hue scene for example.
                  • MatohlM Offline
                    MatohlM Offline
                    Matohl
                    #21
                    Ok Hue scenes I missed that. That is probably not implemented yet
                      AltHue lamps in Vera are standard Vera RGB dimmer devices are they not. That is why they are working now with MSR for basic controls.
                      However I don't think any of the AltHue plugin specific functions have been implemented yet in to MSR.
                        #23
                        You can see better what I mean from this screen shot from PLEG.
                        We are currently missing the functions of the althue service ID
                        RunHueScene and SetEffect (ColorLoop) etc.
                          And here is a list of all the Harmony plugin service id functions
                            As @rigpapa said, he needs to map them.
                            Since we're at it, I think both my VeraAlexa and VeraTelegram plug-ins are good candidate as a native MSR plug-in, since they could be written as node.js/bash script. Virtual HTTP Devices plug-in is using standard services, so we should be good.
                              Indeed.
                              I'm not currently using your Telegram Vera plugin, I'm just sending out HTTP requests from Vera also now from MSR, to their Cloud API / my Telegram account.
                              MSR Doesn't natively support Telegram messenger either by the looks of it.
                                And that’s ok if you want to send text only, but images/videos could be complex, since you need to send a file as well.
                                  @therealdb said in Support for 3rd party Vera plugins ?:
                                  Yeah I'm not doing that currently just text.
                                    Telegram plugin will be supported in 21055 (build later today). I am working on ALTHUE. Challenging since I don't own these devices.
                                      @toggledbits said in Support for 3rd party Vera plugins ?:
                                      let me know if you need help. for ALTHue, I think an emulator (ie: HA-Bridge) could be enough.
                                        Would a device dump for the main AltHue device in Vera help ? Now I know how to do them.
                                          I got all your stuff. That really helps. First pass support is in for 21055. Let's see how it goes.
                                            160.4k
