  4. Setting RGB colour values
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
10 Posts 7 Posters 3.0k Views 6 Watching
    "You need to use 0.0 to 1.0, not 0 to 255 (just like dimming values)."
    How would I set the colour Purple as an example ?
    Its RGB value is: 128, 0, 128
      wrote on last edited by Elcid
      0.5019607843137255, 0, 0.5019607843137255 You may want to round them. LOL
        Correct. You can also use the "set" action instead of "set_rgb"; that takes a single value that you can specify in hex: 0x800080.
        By the way, at least for the moment, the use of 0-1 for RGB is not cast in stone. Now is the time to change it if it's going to drive everyone nuts, before more people are using it. I can see a case for 0-255 instead, since most color picker sites give you values in that range.
          0-255 would be clearer, or 0 - 2.55. That conversion to 0-1 could produce errors.
            Plus one for 0-255 they are the values I am familiar with using for setting RGB values.
              I agree. 0-255 is the way to go!
              • MatohlM Offline
                MatohlM Offline
                Matohl
                Agreed 🙂
                  Andr
                  Yep, 0-255 please
                    Another vote for 0-255 if it was still needed.
                      It's done!
                        164.0k
