x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
I'm currently on version 26011. I understand that the aarch64 image is no longer supported. So, I therefore need to update to the ARM64 image. Can anyone possibly suggest how I update my docker compose.yaml file (see below). Ideally I'd like to keep my existing reactions etc. rather than start from scratch.
# Multi-System Reactor template docker-compose.yml (version 22160)
# Change the lines indicated by "DO"...
services:
reactor:
container_name: reactor
environment:
TZ: GB
restart: "always"
expose:
- 8111
ports:
- 8111:8111
volumes:
- /home/pi/docker/reactor:/var/reactor
tmpfs: /tmp
Installation trouble
Are you sure that's the correct location?
mine is /storage/emulated/0/Download/reactor-0.1-21055-9c0054e.tar.gz
I use x-plore file manager which will copy file location to clipboard@elcid said in Installation trouble:
Yes while i was able to navigate to storage/downloads under Termux the correct path to unpack was
