Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Multi-System Reactor Developer Preview AVAILABLE
Access to the /tools folder is also one of the challenges for the Synology docker container, and command line access is necessary to run the tool, there is no GUI. It's also a node.js application, and node is not available on the NAS when you SSH in; it exists only within the docker container.
For the moment, I'm happy to run the import for you, if you email me a recent (preferably new) Luup Reactor backup file via the email address in the "Support" section of the About page in MSR.Agh. Check that. I can't. It needs access to your device data. I'm going to have to work out some kind of GUI for this. Won't be soon.... -
Thanks for the clarification. Figured I might be a "special case" (who, me?).
Not a high priority on this end, just eager to play. In the meantime, I too shall research what are the options for one to conduct a Terminal session directly on one's Synology NAS. I feel as though this ought to be possible. Will report back any salient findings.- Libra
N.B. I shall be starting my journey here... https://www.synology.com/en-global/knowledgebase/DSM/help/DSM/AdminCenter/system_terminal
I just tested importing all my reactors from openluup, and it worked beautifully! (once i changed the "-" to "_" in the "import-reactor-backup.js" - the manual has that wrong)
I'll try enabling some of the less important rules tomorrow. One thing i'll look into is how to have common logic for i.e. light control in multiple rooms.
Looks very nice, @toggledbits! -
Build 21060
Problem Reports:
PR 0000074: ContactSensor (Hubitat)
PR 0000068: Support HSM (Hubitat)
PR 0000068: Support system mode (Hubitat)
PR 0000050: Further enhancements to thermostat for Hass
PR 0000072: Support trip and untrip actions for Vera security sensorsEnhancements/non-PR fixes:
- Capability prefixing in Hubitat device mapping for increased specificity in certain types
- Improve the detail card display in the Entities list
- Temporary: enhanced logging of all actions performed on entities (e.g. by reactions, Entities list, etc.)
- Rule status card: Interval conditions now show date of last trip
- Rule status card: Date conditions now show time they are waiting for (may be temporary, maybe we like it and it stays)
- "tamper" system capability added
Today was a big day for details in device support. A lot of things got combed out, and many of the outstanding PRs addressed.
I will make a Synology docker container update tomorrow from this build.
Build 21061
0000050 - Additional tuning for Hass thermostats; please check
Other highlights:
- Support for color bulbs on Hubitat, with both RGB and HSL color modes (HSL is native to Hubitat);
- A bug in 21060 that caused newly-created rules to not be runnable until Reactor restart has been fixed;
- The build number will now be shown in the upper-right corner (previously unused area);
- Hubitat and Vera controllers were not passing control to superclass when an action didn't have a controller-specific implementation;
- Added new "hs_color" capability for hue+saturation color model (hsl is hs + dimming level);
IF YOU HAVE AN OPEN PR from a previously-opened device support issue, please check your PR and, if necessary, performance against this build 21061. I spent a lot of time today tweaking and tuning Hass thermostats, and Hubitat color lights. Yesterday's build included support for modes and HSM on Hubitat. But many of these bugs have no confirming feedback. Some of you are great at getting back to the PR and reporting your findings, good or bad; it would be great if everyone did this, as it's the easiest way for me to track. But the rule going forward is, no news is good news, and if I don't hear from you, I'll close the report.
ALSO please remember to check your email for reports from Mantis, and don't forget your Spam/Junk folders! Please mark "Not Spam" if your email system allows, or whitelist the domain, so you get the questions or feedback in a timely way.
@toggledbits What to do if the PR has already been closed? But we have feedback confirming what was implemented is working.
I've opened some PRs again just to leave that feedback.
But other times I've not bothered as they were already closed.Wasn't sure what was best thing to do.
If it's not closed closed, you should be able to add a note without changing its status. That's why I've been leaving things "resolved" for at least a full day after the build the bug is fixed in. Mantis is new to me, too, so I'm still learning as well.
I can't leave a new note or comment on a PR that is currently resolved. For example this one here
To leave a note I have to press the Reopen button.
OK. Well, if it's good news, leave it closed; if it's needs work yet, go ahead and re-open.
Build 21062
Fixed:
- 0000078 - Fix dimming.set on Hass
- 0000077 - Support input_boolean on Hass
- 0000076 - Support GC100 plugin on Vera
- 0000050 - Thermostat support tweaks for Hass
Other work:
- Cleanup of RGB light model for Hass, added HS(L) model, support effects;
- Support ZWave device capability zwave_device, for Vera and Hass (Hubitat TBD)
- Documentation work
Build 21063
- 0000081: Implement RunLua action (on system entity for each VeraController instance)
- 0000080: Fix a problem running Vera scenes
- 0000075: Limit time delays to 24 hours (a multi-day delay on a schedule, specifically >24 days, could overflow JavaScript's 32-bit signed integer millisecond timers)
Other work:
- Fixed an issue with "changes" operator restoring configured values too literally (was inserting word "null" rather than blank/empty string)
- Progress on getting "set variable" action working. It's pretty much working for global expressions/variables. Still working on rule-based variables. PR 5 remains open.
- A lot of "linting". The old-school software-types will know what I mean.
Can confirm #80 and #81 and "issue with "changes" operator" are all working OK.
I've very nearly moved all my PLEG conditions / actions over to MSR.
I am waiting to be able to use an Expression value in a rule, for my "Master" dimmer virtual devices.
And for the Scene Activation stuff being exposed, for Fibaro Dimmer 2 modules for double / triple click events.
Also need to figure out how to setup a motion activated light rule.
Scene activation is going to be tricky because Vera doesn't expose enough information over user_data or status requests. Doable, for sure, but it will need to be done slightly differently from the way you do it on Vera. It's the same thing openLuup runs into with scene controllers and
sl_
prefixed state variables. I don't see a PR for that capability, though. Go ahead and open one. -
Build 21064
- 0000082 - Support for ZWave scene controllers (system capability and Vera)
Other work:
Much time spent today getting Set Variable action update and running. Docs still need updates. The new substition syntax is
${{variable-name-or-expression}}
Build 21065
No PRs fixed today.
Build 21067
No PRs fixed today.
Build 21068
- 0000089 - Entity action substitution values don't update after first run
- 0000090 - Expression not saving when modified
- 0000091 - Expression UI issues
- 0000092 - Expression UI issues
Build 21069
- 0000095: Fix annoying change of attribute when changing device selection
- 0000096: value_sensor.value now allows any data type
- 0000098: global expressions recreated with same name remember old values of prior expression
