    If it's not closed closed, you should be able to add a note without changing its status. That's why I've been leaving things "resolved" for at least a full day after the build the bug is fixed in. Mantis is new to me, too, so I'm still learning as well.
    I can't leave a new note or comment on a PR that is currently resolved. For example this one here
    To leave a note I have to press the Reopen button.
      OK. Well, if it's good news, leave it closed; if it's needs work yet, go ahead and re-open.
        #74
        Build 21062
        Fixed:
        • 0000078 - Fix dimming.set on Hass
        • 0000077 - Support input_boolean on Hass
        • 0000076 - Support GC100 plugin on Vera
        • 0000050 - Thermostat support tweaks for Hass
        Other work:
        • Cleanup of RGB light model for Hass, added HS(L) model, support effects;
        • Support ZWave device capability zwave_device, for Vera and Hass (Hubitat TBD)
        • Documentation work
        • K Offline
          K Offline
          kfxo
          Another good release. Confirming that 0000078 and 0000077 are tested and working on my system.
            Build 21063
            • 0000081: Implement RunLua action (on system entity for each VeraController instance)
            • 0000080: Fix a problem running Vera scenes
            • 0000075: Limit time delays to 24 hours (a multi-day delay on a schedule, specifically >24 days, could overflow JavaScript's 32-bit signed integer millisecond timers)
            Other work:
            • Fixed an issue with "changes" operator restoring configured values too literally (was inserting word "null" rather than blank/empty string)
            • Progress on getting "set variable" action working. It's pretty much working for global expressions/variables. Still working on rule-based variables. PR 5 remains open.
            • A lot of "linting". The old-school software-types will know what I mean.
              #77
              Can confirm #80 and #81 and "issue with "changes" operator" are all working OK.
              I've very nearly moved all my PLEG conditions / actions over to MSR.
              I am waiting to be able to use an Expression value in a rule, for my "Master" dimmer virtual devices.
              And for the Scene Activation stuff being exposed, for Fibaro Dimmer 2 modules for double / triple click events.
              Also need to figure out how to setup a motion activated light rule.
                Scene activation is going to be tricky because Vera doesn't expose enough information over user_data or status requests. Doable, for sure, but it will need to be done slightly differently from the way you do it on Vera. It's the same thing openLuup runs into with scene controllers and sl_ prefixed state variables. I don't see a PR for that capability, though. Go ahead and open one.
                  #79
                  Build 21064
                  • 0000082 - Support for ZWave scene controllers (system capability and Vera)
                  Other work:
                  Much time spent today getting Set Variable action update and running. Docs still need updates. The new substition syntax is ${{variable-name-or-expression}}
                      Build 21065
                      No PRs fixed today.
                        Build 21067
                        No PRs fixed today.
                          Build 21068
                          • 0000089 - Entity action substitution values don't update after first run
                          • 0000090 - Expression not saving when modified
                          • 0000091 - Expression UI issues
                          • 0000092 - Expression UI issues
                            Build 21069
                            • 0000095: Fix annoying change of attribute when changing device selection
                            • 0000096: value_sensor.value now allows any data type
                            • 0000098: global expressions recreated with same name remember old values of prior expression
                              #85
                              Build 21072
                              • 0000108: Editing an extended attribute after having a system attribute selected applies validation rules of system attribute
                              • 0000107: Improve button consistency between rules and reactions
                              • 0000104: Error when attempting to recreate variable used in rule
                              • 0000095: Also fix in Reactions (reselect of action if device changes)
                              • 0000100: Make sl_CentralSceneAttr available for Vera
                              The x_vera_state capability is gone, and has been replaced with x_vera_svc_XXXX capabilities, wherein XXXX is the service ID on the Vera device. This slows startup, as additional queries must be made of every Vera device at initialization; the user_data query does not provide sufficient information. The Hubitat and Hass controllers also model this behavior. It's very tidy on Hubitat and Hass, I'm happy to say (and there is no performance penalty on these platforms).
                              The bad news (Vera users): If you are using x_vera_state attributes in your rules, you will need to edit them and choose the newer capability. Good news: this model will probably never change.
                                Build 21073:
                                • 0000110: Problem with formatting and reselection of Interval conditions in "relative to condition TRUE". Good time to mention that this mode is now DEPRECATED. This functionality was long ago replaced in Reactor for Vera by pulse output mode, but I didn't deprecate the feature in RFV at the time; should have. It is deprecated now in MSR.
                                Ongoing UI work, including exporting of group to new Rule, and importing of Rule to group.
                                  Build 21074
                                  • 0000110 - Interval condition not restoring related condition (option) correctly on edit
                                  • 0000111 - Hass identified service not available (androidtv)
                                  • 0000112 - Expression error
                                  • 0000113 - Bridged Vera systems shows no devices (corrupt geofencing data)
                                  • No PR - Fix precedence issue with lexpjs "each" and "first" statements
                                  This version is also ready for testing under systemd on RPi (I've been running it that way all day). I will publish more on that later; I'm being called to the dinner table.
                                    Build 21075:
                                    • 0000114: Fix loss of condition options on device change
                                    • 0000115: Add restart button to Tools page
                                    • No PR: Update lexpjs to fix && and || return values.
                                    Continuing work on UI cleanups are in the fore these days. Also work getting the HTTP API squared away sufficiently that I can port my automated test tool and start writing new test scripts.
                                      Build 21076:
                                      • 0000122 - Pushover notifications fail (dup/same cause as 119)
                                      • 0000121 - "in" operator malfunction (Conditions)
                                      • 0000120 - getEntity() fails to find entity when using name
                                      • 0000119 - SMTP Notifications fail
                                      • 0000106 - Include ID in entities list of expression builder
                                      • 0000063 - Reorganize entity list in triggers and constraints
                                      PRs 63 and 106 are addressed by a long-planned change finally implemented which I call the "Entity Picker". It operates similar to the Entities tab at the top leve of the UI, providing filters for source controller, group and capability. It also provides a name search that filters as you type. And, it remembers the last set of filters, so when you bring it up, your last search is intact. This has been deployed in all locations where entity selection was previously done with a drop-down menu.
                                        #90
                                        Build 21077:
                                        • 0000123: Rename of rule sometimes doesn't stick
                                        • 0000124: Request action URL check doesn't allow variable substitution
                                        Notification now supports (hopefully) CallMeBot. The dist-config contains an updated notifications.yaml with a section for CMB. It looks like this:
                                        notification:
                                          # other method configurations not shown
                                          # CallMeBot
                                          CallMeBot:
                                            profiles:
                                              default:
                                                # api_url - Access URL for CallMeBot API being used
                                                api_url: http://api.callmebot.com/start.php
                                                # api_key - (if needed) API key (use for Facebook API, WhatsApp API, etc.).
                                                #           If the API you are using does not require it, leave it
                                                #           commented out or blank.
                                                #api_key: "place api key here"
                                                # source - (if needed) Source field for some APIs. If yours does not require
                                                #          it, leave it commented out or blank.
                                                #source: "source-value"
                                                # phone - (if needed) Phone field for some APIs. If yours does not require
                                                #phone: "phone-number"
                                                # user - (if needed) User field for some APIs. If yours does not require
                                                #user: "username"
                                                # lang - (optional) Language/voice; default "en-US-Standard-C".
                                                #        See CallMeBot docs for possible values.
                                                #lang: "en-US-Standard-C"
                                                # rpt - (optional) Number of times to repeat message; default: 1.
                                                #rpt: 1
                                        If you run into an issue, logs will help here.
                                          Build 21078:
                                          • 0000122: Prowl notifications not working
                                          • 0000125: Add name search to Entities list (like Entity Picker)
                                          • 0000129: Exit after creating rule leaves empty rule
                                          • 0000130: Improve "last value" display for expressions
                                            161.9k
