  4. Accessing VOI from MSR
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
20 Posts 5 Posters 5.5k Views 5 Watching
    @cw-kid google has closed all the local apis. But if you found something to use, I’ll take a look.
    @therealdb Google suck sometimes. Why don't they have any local APIs.
      @cw-kid
      @cw-kid said in Accessing VOI from MSR:
      Good question. This move was actually the first thing that got me to remove everything google from my house from devices to browsers, search engines, email service etc... They actually did initially offer a local API but removed it for the philips hue as an example. Their strategy is to collect as much data as possible from us, customers since we are actually not their customers as part of their business model. We are their products. They are forcing people to rely on their cloud. Alexa is much better in that sense that though it is shifting to favor cloud centered environment, they have kept their local APIs open. That being said all of these cloud based environment have some major downsides: latency, reliability, privacy. I am gradually moving to local voice processing as well with homekit and it seems to turn out being a bit of a project.
      @LibraSun, what devices are you looking to control? There has to be better, more direct ways to do it than to go through the amazon cloud...
        My plugin can do anything local. Plus, it will always work 😬
        I’ve been running it since almost 3 years. Tts, Alexa routines (ie to control dnd, music, weather, alarms) and direct commands. It’s always working. Look at my signature to get it.
        @therealdb said in Accessing VOI from MSR:
        I'm getting mixed messages here, though, so allow me to inquire before I proceed with installing VeraAlexa plug-in...
        On GitHub, the readme states to the contrary...
        "On Vera only TTS is implemented."
        but later suggests:
        "When jq package is installed [such as with Vera f/w 7.32], the plug-in will automatically switch to the avanced version."
        It also include this proviso, which is unclear to me:
        "only accounts with MFA disabled"
        So, which of the following functionalities will my Vera Plus actually enjoy once I install the plug-in [under 7.31], and which will only happen after upgrading to 7.32 firmware?
        • Text-to-Speech (TTS) over Alexa/Echo
        • Announcements to Groups
        • Text-to-Command ("VOI") from Vera
        (SORRY IF I'M BEING OBTUSE... it's not intentional, lol)
        • Libra
          Vera 7.31 will only get tts. Maybe written commands, I’ve not tested it.
            ...and what does "MFA disabled" mean in this context?
              @librasun presumably that's referring to your Amazon account and 2 factor authentication, needs to be disabled.
                Ah, thanks for explaining. Could not figure out the meaning of "MFA" but now get it: "Multi-Factor Authentication" 🙂
                  I have to update the doc, since I have MFA on my account, with Authenticator app and oath tool in place wonderfully working together. But this definitely requires openluup.
                    I double checked and spoken commands are available even if jq is not installed:
                    -- execute a spoken command on Bedroom device
                    luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1",
                       "RunCommand",
                       {Command="-e textcommand:'Alexa, I’m leaving' -d 'Bedroom'"}, 666)
                    I've updated the doc as well.
                      Sweet!! Thanks. Now, if I could just get VOI to succeed in turning off the screen of my Echo Spot, which so far can only be done in person by voice ("Alexa, turn off the screen").
                      I've begged Amazon tech support to improve that feature to be responsive to automation, but so far no go.
                        You should be able to do it via voice commands. I added a specific section in read me and I’ll probably create a specific service in next version.
                          164.0k
