  4. The x_vera_state capability is gone
22 Posts 5 Posters 6.6k Views 5 Watching
    You will only find them in rules and getEntity expressions, too. There were no actions in x_vera_state, so no need to worry about reactions.
      I used to take pains to remove (by setting to a null value using Luup, I believe) any extraneous device parameters I had introduced due to typos, etc. Now, I'm much less fussy about them and tend to leave bogus variables in place.
      As @kfxo had worried (above), I thought my couple of dozen or so Rules in MSR would require major editing with the changes introduced in rev. 21072, but happily found only TWO occurrences of x_vera_state in my workflow. Lucky!
      K Offline
      K Offline
      kfxo
      @librasun said in The x_vera_state capability is gone:
      Ended up not being too bad but I had to click through like 300 rules just to make sure I did not miss anything.
      This release is top notch. I had a list of Hass mappings I wanted to start requesting @toggledbits and now they are all there.
        It should still be the case that the most frequently-used device types should get mappings with their most-frequently-used attributes, but now we can take our time about it. The Reactor system capabilities are just simpler wrappers for the native controller ones. Eventually, they will also facilitate moving a device from one controller type to another. If, for example, you are using the Reactor binary_sensor capability in a Rule, and you move that device to another controller, it should still work as a binary_sensor on the new controller. On the other hand, if you've decided to use x_vera_svc_micasaverde-com_SecuritySensor1.Tripped in your rule and you move the device to HomeAssistant or Hubitat, you won't get that benefit.
          @toggledbits said in The x_vera_state capability is gone:
          Genius !
          I am keeping all mine as the Reactor System ones then.
          Unless there is some specific requirement where I can only use x_vera_svc_
            So how can I manually remove this SubMasters1 Service ID ?
            Looking in the list in the Entities area of MSR, that SubMasters is the only Vera plugin that I have uninstalled but a Service ID for it remains.
            When I select it, it lists these devices:
            Looking at those devices Variables in Vera I cannot see any Variables related to SubMasters I don't think.
                If you expand those entities and look at their attributes, you will likely find x_vera_svc_toggledbits_com_Submasters1.xxxx where xxxx is some name. The variables on Vera will have the same xxxx name.
                  x_vera_svc_toggledbits_com_Submasters1.Random="0.5573104607556194"
                  So the variable is called "Random" it appears. I can see that in Vera on the Variables tab of the device.
                    It's living up to its name! Run this on your Vera, putting in the device number where indicated:
                    luup.variable_set( "urn:toggledbits-com:serviceId:Submasters1", "Random", nil, DEVNUM )
                    luup.reload()
                    You'll also need to restart MSR, since there's no indication from the Vera when a state variable is deleted, it can't know.
                      I vote that the above -- namely, Vera Variable Zapper -- be included among the Tools planned for MSR. Or is that too purpose-specific?
                      I've always hoped for a programmatic/UI means of pruning unwanted Variables from my Devices without resorting to Luup code on Vera.
                        I have run that command against each device number and now all those affected devices no longer have a "Random" variable.
                        After restarting MSR I can now no longer see the SubMasters1 service ID so its all gone now.
                        Thank you.
                          @librasun I believe that is fixed in Vera fw 7.32
                          "12. Fixed the issues with not being able to remove or set an attribute or variable to the empty value".
                            161.3k
