  4. Home Assistant, ReferenceError: auth is not defined
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
HA 2025.9.4 Supported Yet?
Rule Set UI bug - RESOLVED
14 Posts 3 Posters 1.8k Views 3 Watching
    Andr
    wrote on last edited by Andr
    I doesn't succeed with connection to my home assistant.
    Anyone that can see what's wrong?
    I have also tried with token between " instead of '
    From reactor.yaml
    - id: hass
      enabled: true
        source: 'ws://12.12.12.9:8123'
        access_token: 'Rm97bt83DGwqyfv4c6wiQRPByhbkJmnYwviP8MLQZXw'
    From command window:
    PS C:\reactor> node app.js
    Configuration path: config resolved C:\reactor\config
    2021-02-28T17:45:25.872Z <app:null> Reactor "0.1.21058" starting on v14.16.0
    2021-02-28T17:45:25.874Z <app:INFO> Process ID 1408; platform win32/x64 Windows 10 Education
    2021-02-28T17:45:25.875Z <app:INFO> Home C:\reactor; data in .
    2021-02-28T17:45:25.894Z <default:INFO> Module Entity v21057
    2021-02-28T17:45:25.898Z <Controller:null> Module Controller v21058
    2021-02-28T17:45:25.908Z <default:null> Module Structure v21050
    2021-02-28T17:45:25.917Z <default:null> Module Ruleset v21041
    2021-02-28T17:45:25.919Z <default:null> Module Rulesets v21041
    2021-02-28T17:45:25.938Z <default:null> Module Rule v21058
    2021-02-28T17:45:25.942Z <default:null> Module Engine v21055
    2021-02-28T17:45:25.944Z <default:null> Module httpapi v21041
    2021-02-28T17:45:25.954Z <default:null> Module httpproxy v21054
    2021-02-28T17:45:25.985Z <default:null> Module wsapi v21053
    2021-02-28T17:45:25.987Z <app:NOTICE> Starting HTTP server and API...
    2021-02-28T17:45:25.996Z <httpapi:NOTICE> HTTP API v1 21041 base URL http://12.12.12.12:8111; listening
    2021-02-28T17:45:26.007Z <app:NOTICE> HTTP server running; registering proxy endpoints.
    2021-02-28T17:45:26.008Z <app:NOTICE> Starting WSAPI...
    2021-02-28T17:45:26.009Z <wsapi:NOTICE> wsapi: starting version 21053
    2021-02-28T17:45:26.011Z <app:NOTICE> Endpoints up; starting Structure...
    2021-02-28T17:45:26.012Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
    2021-02-28T17:45:26.018Z <Structure:INFO> Structure#1 starting controller interface hass (HassController)
    2021-02-28T17:45:26.021Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
    2021-02-28T17:45:26.022Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
    2021-02-28T17:45:26.047Z <default:null> Module VeraController v21058
    2021-02-28T17:45:26.052Z <default:null> Module HassController v21053
    2021-02-28T17:45:26.054Z <default:null> Module OWMWeatherController v21027
    2021-02-28T17:45:26.065Z <default:null> Module SystemController v21054
    2021-02-28T17:45:26.076Z <VeraController:NOTICE> VeraController#vera starting
    2021-02-28T17:45:26.079Z <VeraController:INFO> VeraController#vera loaded mapping ver 21057 rev 2 format 1 notice
    2021-02-28T17:45:26.109Z <Controller:INFO> HassController#hass device data loaded; checking structure
    2021-02-28T17:45:26.111Z <Controller:ERR> ./server/lib/hass_devices.yaml implementation of capability hvac_blower_swing uses unknown attribute mode
    2021-02-28T17:45:26.112Z <Controller:WARN> ./server/lib/hass_devices.yaml implementation of capability hvac_blower_swing does not provide attribute swing; using fixed value=(null)
    2021-02-28T17:45:26.129Z <Controller:NOTICE> HassController#hass attempting reconnection to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:26.130Z <Controller:NOTICE> HassController#hass connecting to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:26.155Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
    2021-02-28T17:45:26.170Z <app:INFO> Structure is now running
    2021-02-28T17:45:26.171Z <app:INFO> Pausing for controllers' initial ready
    2021-02-28T17:45:26.190Z <Controller:NOTICE> HassController#hass connected, starting protocol
    2021-02-28T17:45:26.200Z <Controller:ERR> HassController#hass message handler for auth_invalid failed: ReferenceError: auth is not defined
    2021-02-28T17:45:26.210Z <Controller:NOTICE> HassController#hass websocket closed, 1000
    2021-02-28T17:45:26.286Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
    2021-02-28T17:45:26.466Z <VeraController:NOTICE> Controller VeraController#vera is now online.
    2021-02-28T17:45:26.505Z <OWMWeatherController:ERR> [Entity:setPrimaryAttribute] Attempt to set primary to power_switch.state invalid, not in { "x_vera_rgbcontroller_plugin": { "device_type": "ZWaveColorDevice", "configured": true, "color": "#e900ff0000", "message": "" } }
    2021-02-28T17:45:26.506Z <VeraController:ERR> VeraController#vera exception/error while updating VeraController#vera
    2021-02-28T17:45:26.507Z <VeraController:CRIT> Error: Entity#vera>device_235:setPrimaryAttribute() can't set power_switch.state, not defined for entity
        at Entity.setPrimaryAttribute (C:\reactor\server\lib\Entity.js:364:19)
        at C:\reactor\server\lib\VeraController.js:692:118
        at processTicksAndRejections (internal/process/task_queues.js:93:5)
    2021-02-28T17:45:31.213Z <Controller:NOTICE> HassController#hass attempting reconnection to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:31.215Z <Controller:NOTICE> HassController#hass connecting to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:31.226Z <Controller:NOTICE> HassController#hass connected, starting protocol
    2021-02-28T17:45:31.237Z <Controller:ERR> HassController#hass message handler for auth_invalid failed: ReferenceError: auth is not defined
    2021-02-28T17:45:31.256Z <Controller:NOTICE> HassController#hass websocket closed, 1000
    2021-02-28T17:45:36.258Z <Controller:NOTICE> HassController#hass attempting reconnection to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:36.260Z <Controller:NOTICE> HassController#hass connecting to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:36.272Z <Controller:NOTICE> HassController#hass connected, starting protocol
    2021-02-28T17:45:36.283Z <Controller:ERR> HassController#hass message handler for auth_invalid failed: ReferenceError: auth is not defined
    2021-02-28T17:45:36.298Z <Controller:NOTICE> HassController#hass websocket closed, 1000
    2021-02-28T17:45:41.302Z <Controller:NOTICE> HassController#hass attempting reconnection to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:41.303Z <Controller:NOTICE> HassController#hass connecting to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:41.314Z <Controller:NOTICE> HassController#hass connected, starting protocol
    2021-02-28T17:45:41.336Z <Controller:ERR> HassController#hass message handler for auth_invalid failed: ReferenceError: auth is not defined
    2021-02-28T17:45:41.353Z <Controller:NOTICE> HassController#hass websocket closed, 1000
    2021-02-28T17:45:46.355Z <Controller:NOTICE> HassController#hass attempting reconnection to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:46.357Z <Controller:NOTICE> HassController#hass connecting to ws://12.12.12.9:8123/api/websocket
    2021-02-28T17:45:46.368Z <Controller:NOTICE> HassController#hass connected, starting protocol
    2021-02-28T17:45:46.377Z <Controller:ERR> HassController#hass message handler for auth_invalid failed: ReferenceError: auth is not defined
    2021-02-28T17:45:46.394Z <Controller:NOTICE> HassController#hass websocket closed, 1000
    2021-02-28T17:45:47.169Z <app:NOTICE> Shutdown signal (SIGINT) received. Stopping Reaction Engine...
    2021-02-28T17:45:47.172Z <Engine:NOTICE> Engine#1 has shut down.
    2021-02-28T17:45:47.172Z <app:NOTICE> Closing APIs...
    2021-02-28T17:45:47.173Z <wsapi:NOTICE> wsapi closing...
    2021-02-28T17:45:47.179Z <httpapi:NOTICE> HTTP API closing...
    2021-02-28T17:45:47.180Z <app:NOTICE> Closing Structure...
    2021-02-28T17:45:47.181Z <Structure:INFO> Structure#1 Stopping controllers...
    2021-02-28T17:45:47.183Z <VeraController:NOTICE> VeraController#vera stopping
    2021-02-28T17:45:47.184Z <Controller:NOTICE> HassController#hass stopping
    2021-02-28T17:45:47.189Z <Controller:NOTICE> HassController#hass stopping
    2021-02-28T17:45:47.190Z <OWMWeatherController:NOTICE> OWMWeatherController#weather stopping
    2021-02-28T17:45:47.191Z <Controller:NOTICE> SystemController#reactor_system stopping
    2021-02-28T17:45:47.193Z <Controller:NOTICE> SystemController#reactor_system stopping
    2021-02-28T17:45:47.194Z <Structure:INFO> Structure#1 Final data sync...
    2021-02-28T17:45:47.199Z <Structure:NOTICE> Structure Structure#1 stopped
    2021-02-28T17:45:47.199Z <app:NOTICE> Stopping timers...
    2021-02-28T17:45:47.200Z <app:NOTICE> Shutdown complete, process ID 1408
    2021-02-28T17:45:47.201Z <wsapi:NOTICE> wsapi: server closed
    FORCED EXIT
      Looks like you are using the wrong kind of access token. The instructions specify that you have to use a long-lived access token, and these are usually very long on Hass. Yours is very short (at least, much shorter than the LLATs I've seen on my own system). Did you use a Long-Lived Access Token?
        Andr
        @toggledbits said in Home Assistant, ReferenceError: auth is not defined:
        The lengts seems random I think.
        I did 3 tokens, first one super long.
        When it didn't work i created another one, in first post.
        Now I created the third one, and this became super long, and it works.
        No idea why, long-lived tokens is the only I can create...
        • F Offline
          Hi! My HA does not connect either. I get a "websocket error" over and over again. This is my reactor.yaml:
            - id: hass
              enabled: true
              name: Home Assistant
                source: 'ws://192.168.50.167:8123'
                access_token: "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI0ZDg4MzVjZmJkMjQ0ODYwODZhYzc1ZTExZDk2MGU1OSIsImlhdCI6MTYxNTczMzMyMSwiZXhwIjoxOTMxMDkzMzIxfQ.eMGyHpM"
          • F Offline
            In CMD it looks like this:
            2021-03-14T15:20:27.492Z HassController:NOTICE HassController#hass attempting reconnection to ws://192.168.50.167:8123/api/websocket
            2021-03-14T15:20:27.492Z HassController:NOTICE HassController#hass connecting to ws://192.168.50.167:8123/api/websocket
            2021-03-14T15:20:27.501Z HassController:WARN HassController#hass socket error during open: Error: socket hang up
            2021-03-14T15:20:27.502Z HassController:NOTICE HassController#hass socket to ws://192.168.50.167:8123/api/websocket closed during open
            2021-03-14T15:20:27.505Z HassController:ERR HassController#hass connect error with ws://192.168.50.167:8123/api/websocket: websocket error
            2021-03-14T15:20:27.505Z HassController:WARN HassController#hass failed to connect/initialize communication: websocket error
              Make sure you have the websocket API enabled in your Hass configuration.
              Home Assistant WebSocket API
              Instructions on how to setup the WebSocket API within Home Assistant.
              • F Offline
                Thanks. I stupid newbie question... I guess I should add this line to configuration.yaml:
                websocket_api:
                But what else?
                  That's all that's necessary. I also add the documented sensor lines so I can see how many connections are active, but it's not strictly necessary to functionality.
                  • F Offline
                    I'm afraid it doesn't work @toggledbits. Shouldn't there be anything after the ":", an IP-adress or something?
                    • F Fanan
                      @fanan said in Home Assistant, ReferenceError: auth is not defined:
                      If you are referring to the "websocket-api:" line in your Home Assistant configuration, no, that line stands by itself. It needs to be properly formatted and placed in your HomeAssistant configuration file. Check your HomeAssistant log for any errors related to its configuration file.
                      Oh, and just to make sure I've asked, are you keeping up with the builds? Are you testing on the latest build?
                      Ref: https://www.home-assistant.io/integrations/websocket_api/
                      • F Offline
                        Ah - I didn't understand that I had to install the websocket_api. I thought it was enough to edit the configuration.yaml-file.
                        Now I'm going to figure out how to install...
                        • F Offline
                          @toggledbits ; Just a stupid question, since I´m kind of new to this.... Do I have to install the websocket api? I have HACS installed and have tried to add it to the custom resporitories. I tried to add the URL:
                          core/homeassistant/components/websocket_api at dev · home-assistant/core
                          :house_with_garden: Open source home automation that puts local control and privacy first. - home-assistant/core
                          and a few more URL as well... But I only get: "Repostitory structure for 2021.3.4 is not compliant", or something else if I try other URL:s.
                          I don't want to waste your time with these newbie questions, but after hours and days of failure, I´m becoming desperate... 🥴
                            I just installed Hass via docker, and all I needed to do was add that line to my Hass config and generate the Long-Lived Access Token and everything connected right up. I've never had a problem connecting to Hass, and I didn't have to install anything additional. This is what my configuration file looks like:
                            # Configure a default setup of Home Assistant (frontend, api, etc)
                            default_config:
                            http:
                              server_host: 0.0.0.0
                            websocket_api:
                            sensor:
                              platform: websocket_api
                            group: !include groups.yaml
                            automation: !include automations.yaml
                            script: !include scripts.yaml
                            scene: !include scenes.yaml
                            • F Offline
                              @toggledbits. My HA installation is on a VM (VirtualBox) on Windows 10. That shouldn't be problem I guess?
                              • [Solved] Local expression in Rule does not evaluate as they used to do
                                74.0k
                                527
                              • Shelly Wall Display XL
                              • [Solved] alarm() in global expression throws error in log.
                                960
