  4. Replacing SiteSensor Plugin (Vera) with MSR
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
91 Posts 7 Posters 59.7k Views 6 Watching
    That's easy, it has it, so all I need to do is add the menu item to the UI.
      Great. If you filter the "Entities" list (left nav) for the "wx" capability, you should find the entity that contains your local weather data.
      @toggledbits I found this:
      Oddly, the historical is returning Melgrove lol I left the config so that it would pull from the default location which is using lat/long.
        I'm not sure where you're going with this post? Are you reporting a problem?
          @toggledbits I guess I am - unless I'm misreading the docs. I believe to have OWM set to use the default location of MSR which is Hanahan SC, not Melgrove Someplace.
          I don't want to file a bug until I'm sure it's MSR and not me.
            OK. In order to sort that out, I need to see your configuration for both the default system location and OWM. Post here or PM is fine.
              @toggledbits Posted via PM.
                OK. Looks like all is good, OWM is just returning an odd place name (who knows what data they sourced that from), and since you are using "default" configuration (home location from Reactor main config), it's using OWM's returned name for the entity name. If you do a custom location in the OWM config, you can set the name by adding the "name" to the custom config. I'm going to extend that behavior to the default location config as well, and that will be in today's build. If you want to get it fixed before that, just add a location to your OWMController config section:
                  - id: weather
                    enabled: true
                    implementation: OWMWeatherController
                      appid: "yourappidhere"
                      locations:
                        - id: home
                          name: "My Custom Place Name"
                          latitude: nn.nnnnnn
                          longitude: nn.nnnnnn
                    - id: weather
                      enabled: true
                        locations:
                          - id: home
                            latitude: nn.nnnnnn
                  @toggledbits I'm a few nightly builds behind so I'll wait until you have tonight's out. Thanks!
                    For MSR users with SiteSensor still installed back on Vera, you might want to consider letting MSR take over those duties. Here's a quick run-down of how I imported one of my SiteSensor recipes into a Rule on MSR, using OpenWeather API* as an example.
                    STEP 1: Copy the Basics from Vera
                    (a) Go to your Vera > Devices, locate SiteSensor (the main instance, not one of its children devices) and click ► for details then click SETTINGS.
                    (b) Copy and paste (into Notepad or other text editor) the Request URL along with each of the defined expressions.
                    STEP 2: Create a Rule on MSR
                    (c) Jump into Rule Sets and click "Create Rule". Click its title to rename the rule 'OpenWeather (API)" and click 'Rename'.
                    (d) Decide on appropriate Triggers (in my case, it's an OR group that includes an [INTERVAL] set to "Every 3 hours" plus a few [ENTITY ATTRIBUTE] entries reacting to things like entering/leaving home, waking up, etc.).
                    (e) In Set Reacion, create an [HTTP REQUEST] > [GET] action.
                    (f) Paste your old "Request URL" into the "Request URL" box.
                    FYI GET calls to OpenWeather API* take the form:
                    http://api.openweathermap.org/data/2.5/weather?zip=<your_ZIP_code>&id=<your_Wx_ID>&appid=<app-id>&units=imperial
                    (g) Create four new blank Expressions (name them openWx, Tx, Hx and Rx).
                    (h) Click SAVE & EXIT
                    STEP 3: Process the Response
                    (i) Re-open rule "OpenWeather (API)" by clicking the 'Edit' icon.
                    (j) Within the [HTTP REQUEST] action, assign "Capture response to:" ► openWx
                    (k) Down in Expressions, click "[+]Add Expresssion" then enter the following:
                    Tx := round(openWx.main.temp,1)
                    // yields current outdoor temperature
                    Hx := round(openWx.main.humidity)
                    // yields current humidity conditions
                    Rx := openWx.rain ? ( openWx.rain['3h'] ? openWx.rain['3h'] : 0) : 0
                    // yields predicted rainfall, if present; otherwise 0
                    (l) Click SAVE & EXIT. Enjoy!
                    Naturally, your specific needs and workflow will differ from the one I've outlined here. For instance, you may wish to explore the contents of the JSON object in openWx for additional data of interest to you, and define variables to match.
                    My goal here has been to illustrate some key concepts needed for moving from SiteSensor over to MSR:
                    • Some syntax is the same, such as dot notation for object.item.access;
                    • Other syntax has changed, such as the use of ternary A ? B : C in place of IF (A, B, C);
                    • Manually setting an [INTERVAL] in lieu of SiteSensor's timed schedule;
                    Pro tip: If your workflow demands that other Rules react to the output of the "OpenWeather (API)" rule, then be sure to create all of the aforementioned Expressions under "Global Expressions" instead, so they become accessible across all Rule Sets.
                    Once the transition is complete, you can either DISARM SiteSensor on Vera or remove it entirely with "Remove Device" (which will automatically remove all of its child devices).
                    *Additional reading:
                    OpenWeather API : https://openweathermap.org/api
                    FREE SUBSCRIPTION REQUIRED TO USE THIS SERVICE
                    PRO TIP: See below for optimal way to incorporate OpenWeatherMap into your MSR workflow(s), by enabling the service directly in the reactor.yaml config file.
                    @librasun said in Replacing SiteSensor Plugin (Vera) with MSR:
                    I never used SiteSensor plugin for Vera before.
                    Thanks for the MSR example you wrote.
                    I wanted to try this out and found this Covid-19 API here.
                    However the http command they give doesn't seem to return any results data, either just in the web browser or in my MSR rule.
                    https://covid19-api.com/country?name=UK&format=json
                    The curl command does work OK however
                    curl -X GET "https://covid19-api.com/country?name=UK&format=json" -H "accept: application/json"
                    How do I specify the application/json in the MSR rule? Assuming the problem is related to that.
                      Same way. One header per line in that field.
                        #21
                        In the "Request Headers" field in the "Set Reaction" I have tried the following:
                        Accept: application/json
                        and tried:
                        Content-Type: application/json
                        It allows me to save the rule but when I go back in to the rule that field is empty again and its not collecting the response data in to my empty expression / variable.
                          So there are two separate issues here:
                          1. First, we need to figure out if the UI is correctly storing the headers or not, and if the problem is merely that it is not restoring/displaying them correctly when you go back into the editor. The check for that is to go into the reaction, add the headers, and save. Then, open the rule status view and it will show you the rule ID underneath the rule condition status and expressions. Go to your reactor/storage/rules directory, and grab the same-named file (with .json suffix) and post it here. Let's see what's being stored.
                          2. Look at the logs to see where the reaction is running and what the request is doing. There may be errors logged.
                          It's entirely possible that the problem is 1, 2, or even both.
                            #23
                            I cannot upload files to this forum it seems.
                            I have uploaded the rule to my One Drive here
                              OK. There's definitely two broken things in the handling of headers, so go ahead and open a PR for this. No need to post the rule there (again); I've got it and have the issue in hand, but unfortunately, it's not just a UI issue.
                                OK done
                                https://reactor.toggledbits.com/mantisbt/view.php?id=147
                                  #26
                                  OK so lets say I now have a variable in MSR that contains some data pulled down from a HTTP Request to some online API somewhere.
                                  How can I send that value / information to a Generic IO Sensor in Vera ?
                                  I know how to create a GenericIO device in Vera and I know how to send data to it from a simple HTTP command, for example this command will send the text "Hello World"
                                  http://Vera-IP/port_3480/data_request?id=lu_variableset&DeviceNum=128&serviceId=urn:micasaverde-com:serviceId:GenericSensor1&Variable=CurrentLevel&Value=Hello World
                                  And here is the device in Vera:
                                  But how to create a rule to send the contents of an MSR variable (expression) ?
                                  LibraSunL 1 Reply Last reply
                                    #27
                                    I'm going to assume the data was returned in JSON format? In which case MSR treats that like an object {}, whose keys can be referenced with dot notation.
                                    For example, if your variable respData stored the response {animal:"cat", clothing:"suit", food:"chow"} and you want to send the current value of the "chow" key therein, simply reference that value with respData.chow.
                                    One hurdle you may have to overcome, since the data is being fetched and stored in Rule A, but you want to reference the results in Rule B, is that you'd then have to either (a) store respData as a Global Expression, or (b) create a blank Expression in Rule B, and tell Rule A to [Set Variable] on it.
                                      @cw-kid said in Replacing SiteSensor Plugin (Vera) with MSR:
                                      In case you revised your question, or I misinterpreted it earlier, here goes:
                                      It sounds like you want to send data from MSR to a plug-in / virtual device / sensor over on Vera. Before you begin, go to that "device" > Advanced > Variables and determine which of its variables is intended to receive the data.
                                      Click "EDIT" next to that variable, and look for its complete "service" name in the window; copy that string for use back in MSR.
                                      Close that window on Vera, then head back over to MSR.
                                      In MSR, you will want an [ENTITY ACTION] in the Set Reaction. Choose the target device as the 'Entity' and choose "x_vera_device.set_variable" as the action.
                                      Fill out the three fields, where "service:" and "variable:" come from the string you copied earlier. For "value:" either type a constant (numeric or "text"), or a variable name properly clad in curly brackets ( e.g. ${{respData}} ) so the value gets substituted next time the Rule triggers.
                                      Hope this helps!!
                                        @LibraSun
                                        That's great thanks I think you just answered my question, think I know what to do now, I will give it a try.
                                          @LibraSun
                                          Its working. I now have my current WAN IP address being sent from MSR to a virtual device (Generic IO Sensor) on Vera.
                                          So now know how to send any data stored in an expression / variable from MSR to a device on Vera !
                                            164.6k
