  4. Replacing SiteSensor Plugin (Vera) with MSR
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
91 Posts 7 Posters 59.7k Views 6 Watching
    @librasun
    Doesn't make any difference with lowercase "uk"
    My expression in the rule says "null" and no data is being brought down.
    @cw-kid said in Replacing SiteSensor Plugin (Vera) with MSR:
    If it's any consolation, their site seems to be throwing a 500 error when I try to visit https://covid19-api.com/country?name=uk&format=json in my browser. How about yours?
      #37
      @librasun said in Replacing SiteSensor Plugin (Vera) with MSR:
      Same for me also.
      However try their CURL command in a terminal window, that works and brings back data OK
        Does something like this kind of device for displaying data already exist somewhere?
        Yes, the SiteSensor plug-in ( also by @toggledbits ) for Vera.
        #38
        But aren't we trying to "replace" that plugin 😁
        Some decent Generic IO Sensor virtual device we could create and send data too directly from MSR would be nice.
        EDIT: I've just noticed my tweaked GenericIO device does not appear correctly in the Vera mobile app but only on the UI7 web GUI.
        LibraSunL 1 Reply Last reply
          Yes, for this reason we can never truly abandon SiteSensor. Why reinvent the wheel, anyway?
          But it does beg the question: Why do you need a generic sensor on your Vera when it could "live" on MSR? After all, is it not just a placeholder for data?
            So I can add that device in to the Home Remote dashboard app also.
            If it's only on MSR I don't know how to connect Home Remote to MSR directly.
              Fair enough (although I'm certain that capacity will come once MSR variables get exposed via the API).
                Just updated to today's build, the headers are now saved in that field and no longer vanish.
                However I've tried this and no data is being returned / stored
                #42
                Sheesh. I'll admit I'm a little on edge this morning because we had a major storm roll through last night with some nasty lightning (and a tornado very close to us) and it apparently killed my daily-use laptop (cheap, old, no big loss, just a distraction to recover but they were almost two-for-a-dollar on sleezeBay), so forgive me, but...
                There have been no fewer than 10 posts since the above quoted post, and despite my admonition in bold text yesterday in this very thread, not one mention of what may lie in reactor.log.
                  #43
                  Its working now with the new update and pulling down data OK, thanks.
                  However I am not able to split out the data in to different global expressions. I think I have it setup correctly but all the global expressions say "null".
                  RULE:
                  GLOBAL EXPRESSIONS:
                    Notice the [ that starts the displayed value... it's an array. The { that follows tells you there's an object as the first element of the array. So you need to pluck the first element out of the array, then dereference through it to the key you want, like covidstats[0].critical.
                    cw-kidC 2 Replies Last reply
                      @toggledbits said in Replacing SiteSensor Plugin (Vera) with MSR:
                      That works thanks, my global expressions are now being populated with data.
                      I just added covidstats[0]. to all of them in the rule.
                        How about this data for Carbon from the National Grid ?
                        I want to pick out "forecast" and "index" data.
                        (object) {"data":[{"regionid":3,"dnoregion":"NPG North East","shortname":"North East England","postcode":"YO1","data":[{"from":"2021-03-27T13:00Z","to":"2021-03-27T13:30Z","intensity":{"forecast":34,"index":"very low"},"generationmix":[{"fuel":"biomass","perc":24.6},{"fuel":"coal","perc":0},{"fuel":"imports","perc":2.2},{"fuel":"gas","perc":0.2},{"fuel":"nuclear","perc":35.4},{"fuel":"other","perc":0},{"fuel":"hydro","perc":4.5},{"fuel":"solar","perc":6.3},{"fuel":"wind","perc":26.9}]}]}]}
                          #47
                          You can take not-terribly-human-readable blobs like that over to a JSON Pretty Print website (such as https://jsonformatter.org/json-pretty-print), paste it in and hit the "Outline" button, to see how the data looks in its underlying structure.
                          json_pretty_print.png This allows you to quickly pinpoint the blob.key.subkey.data item you need to pull from in MSR.
                          Traversing the tree from upper-left to lower-right, I see the first instance of "forcecast" lives inside an overall object {} (I'm naming response), then the first item (i.e. element 0) of an array [] within data, then inside another array within another key called data, then a key called intensity, and finally the key you want, forecast, yielding:
                          response.data[0].data[0].intensity.forecast
                          cw-kidC G 2 Replies Last reply
                            Remember that openLuup’s Test Lua window, gives you the pretty() function to do the same...
                            local x  = luup.devices[2]
                            print(pretty(x))
                            Gives:
                              category_num = 0,
                              description = "    openLuup",
                              device_num_parent = 0,
                              device_type = "openLuup",
                              embedded = false,
                              hidden = false,
                              id = "",
                              invisible = false,
                              ip = "",
                              mac = "",
                              pass = "",
                              room_num = 0,
                              subcategory_num = 0,
                              udn = "uuid:0058c0cb-c730-209a-50ab-6c88b470a8fd",
                              user = ""
                              #49
                              @librasun
                              They don't make it easy to work all this out do they.
                              "cointensity" is the name of my expression within the rule that first stores all the data pulled down from the HTTP request etc.
                              So for my in-line substitution I have tried this, which doesn't work.
                              ${{ cointensity.response.data(0).data(0).intensity.forecast }}
                              I also tried:
                              ${{ cointensity.data(0).data(0).intensity.forecast }}
                              and a few other variations as well.
                              I want to pass the "forecast" data to a Global Expression called "currentcarbonintensity"
                                I misled you a bit. MSR uses lexpjs, which references array elements in square brackets [] not the parentheses I first wrote (I'll edit my response, above).
                                Go with cointensity.data[0].data[0].intensity.forecast
                                  #51
                                  (Also, I prefer to simply create another variable and set its value to cointensity.data[0].data[0].intensity.forecast and then reference THAT variable in my ${{ }} substitution. Why? Because this gives MSR a chance to tell me exactly where my expression is going wrong.)
                                  If you follow this scheme in your workflow, you can entirely avoid having to use [Set Variable] so often, since the dependent variables will all "set themselves" immediately.
                                  For example, a change to response will automatically update the values in any variable(s) defined by response.stuff or response.stuff.still.more.stuff (caveat: as long as those variables appear below response in your list of Expressions!).
                                    @librasun
                                    Thanks its working now.
                                    These are the Global Expressions and its pulling in the correct data now.
                                      #53
                                      Think I need a Vera plugin Dev.
                                      I've tried to create a modified GenericIO device with four variables but its not working.
                                      My MSR rule is sending out the data to each variable in Vera OK
                                      But I can't seem to get that data to display on the front of the device in the web GUI.
                                      Also for the Home Remote dashboard app, I'd need the generic sensor device and its data fully exposing to the SDATA stream. As Home Remote uses that for integration in to Vera etc.
                                      So close, but I don't think I'm going to be able to properly create these types of devices in Vera myself.
                                      EDIT:
                                      Got it working now, I was using the wrong ServiceID in my MSR rule to set the variables.
                                      Now I just need to figure out how to get this data in to the Vera SDATA output stream for Home Remote to see.
                                      This is all I am seeing in SDATA currently:
                                       { "name": "Covid-19 Stats", "altid": "", "id": 703, "category": 0, "subcategory": -1, "room": 8, "parent": 0, "configured": "0", "light": "4325315" },
                                      "light" is showing "4325315" which is the Confirmed number of Covid Cases, so that's a start, I need the other variables exposing to the SDATA stream some how.
                                      EDIT2: I've added more <stateVariable> sections in to the S_GenericSensor2.xml file and now I can see all four variables data in the SDATA output stream, so I should now be able to add this device in to Home Remote and see all the data.
                                      { "name": "Covid-19 Stats", "altid": "", "id": 703, "category": 0, "subcategory": -1, "room": 8, "parent": 0, "variable2": "3768434", "variable3": "630", "variable4": "126515", "variable1": "4325315", "configured": "0" }
                                      EDIT3: I now have a tile on a dashboard page in the Home Remote app.
                                      So as a proof of concept this works.
                                      Just need an easier way to create these virtual devices in Vera.
                                      Someone on the Vera forum suggested taking a look at the MultiString plugin.
                                        It's moments like this that I'm grateful for online Forums where the open exchange of ideas and experience works to everyone's advantage, without fear of reprisal from those "in charge". 🙂
                                          #55
                                          Just testing some different online API's see what's possible.
                                          If your in the UK the National Grid have a Carbon Intensity online API here. This is for my region / area.
                                          The data also breaks down by percent the types of generation used, Wind, Solar, Nuclear, Coal etc but not added that as yet.
                                          Vera:
                                          Home Remote:
                                          Need to play about with the tiles and add an icon and reposition some items yet.
                                            164.6k
