  4. Can someone explain for me how to use Reset reaction in MSR without disturbing other rules.
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
34 Posts 4 Posters 6.2k Views 4 Watching
    Matteburk
    With these 2 rules and mode is evening or day and rule 2 is triggered light is turned off after 120s by rule 1
    Rule 1 :Bathroomlight is turned on and dimmed to 20% if motion (follow,delay reset 120s) is true and Night mode is on
    Reset Reaction: turn off light.
    RUle 2: Bathroomlight is turned on and dimmed to 100% if motion(follow, delay reset 600s) is true and day or Evening mode I true
    Reset Reaction: Turn off light
    How do you turn off lights in similar cases without disturbing other rules with same sensors...
    /Mattias
    • M Matteburk
      /Mattias
      @matteburk My guess is that Rule 1 is somehow also triggered, I would use Contraints to make sure they only fire when they are supposed to. I'm still learning Constraints but have similar Rules where schedules, motion sensors, lux and house mode is involved and got that set up but can't really explain very good as it's more of a trial and error for me at the moment 🙂
      The documentation is mixing Conditions and Constraints which for me is opposites and I'm mixing a lot of NOT's to make it TRUE and FALSE in the correct places.
      M 1 Reply Last reply
        Matteburk
        @crille yes i understand but you cant have constraints for Reset Reactions. Only for Reactions.
        I’m not friend with MSR at them moment but I know it’s just something I understand wrong... Gaaah drives me nuts!
        • M Matteburk
          @matteburk Yes, the Constraints would block the Reaction in Rule 1 to run, thus will Reset Reaction in Rule 1 not run.
            @toggledbits I think it's becoming apparent that users might interpret Constraints in one of two diametrically opposite meanings. Some might think for example that a TRUE constraint condition will prevent the rule from continuing to run. Others, more correctly in my opinion, will understand that a constraint condition must be TRUE in order for the rule to run.
            I wonder if there could not be some clarifying language in the user interface?
              I'll refer to the documentation, and you can tell me if it's clear enough or still needs work: https://reactor.toggledbits.com/docs/Rulesets/
              Also, it would be good to have the full rules posted in this thread. The descriptions of what the rules look like just leave too much room for interpretation. Let's see what's actually being done.
                Matteburk
                  Matteburk
                  • M Matteburk
                    @matteburk I think you need to put AND in top level for the triggers for Rule 1.
                      Matteburk
                      @crille saw that , have been experimenting so got a typo... but still same problem for me anyway
                        Matteburk
                        Rule 1
                        @toggledbits Here are screenshots
                        Rule 1
                        Skärmavbild 2021-03-28 kl. 18.23.09.png Skärmavbild 2021-03-28 kl. 18.23.22.png
                        Rule 2
                          OK, that's a start, I guess, although they are barely readable. Maybe we'll need to go back to some kind of Logic Summary-like thing.
                          Now, what are these supposed to do, and what is the problem you are having with them?
                          • M Matteburk
                            Rule 1
                            Rule 1
                            Rule 2
                            @matteburk I would still put condition "natt"/"dag" and "kväll" in Constraints as it's not a trigger, rather a condition and would prevent Reaction/Reset Reaction to run.
                            Edit: Clarification for future readers. Forcing the Constraints condition to go FALSE prevents the SET/Reset Reaction to run.
                            toggledbitsT M 2 Replies Last reply
                              @crille said in Can someone explain for me how to use Reset reaction in MSR without disturbing other rules.:
                              No, that's not how Constraints work. Constraints do not prevent Reset reactions.
                                @toggledbits No, but it will prevent the Reaction to run, thus the Reset Reaction?
                                  Matteburk
                                  Rule 1 is 1 motion sensor I Master bedroom and 2 motion sensors in bathroom that if any is true (delayed reset 120s)and Natt mode is true master bedroom light and bathroom light is turn on. Reset reaction turn off
                                  Rule 2 If any of the 2 motion sensors in bathroom is true(delayed reset 600s) and dag or kväll mode is true bathroom light is turned on . Reset reaction turn off
                                    THAT is true, so we need to be careful how we phrase it, because your other statement is incorrect and misleading, and would give other readers the wrong idea. But you are correct in the last: if the SET reaction does not run, neither can the RESET, because RESET will only follow SET (once the basic state of the rules has been established).
                                    • M Matteburk
                                      @matteburk And the problem?
                                        Matteburk
                                        The problem is when rule 2 is set and reset is delayed 600s rule 1 is being resetted by reset reaction in it and lights go of in 120 s instead of 600s as it should
                                          Matteburk
                                          @crille I know. that's how I normally think but I have tried this to get around my problem.... 🙂
                                            180
                                            3.6k
                                            3.2k
                                            756
