Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section:
authtrack:
max_attempts: 4
within_minutes: 180 # 180 minutes = 3 hrs
block_expiration_minutes: 10080 # 7 days
At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)?
EDIT: some logs
[latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started
[latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111
[latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service
[latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI...
[latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol
[latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC)
[latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S)
[latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186
[latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed.
[latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed
[latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
I'm trying to allow anonymous access from a local network to /api/v1/log, but the problem now with the reverse proxy configuration is that this access is open via proxy to the internet. At least I wasn't able to configure ACL so that only an access from a local network would be permitted.
reactor.yaml:
baseurl: "http://192.168.1.12:8111"
proxy_baseurl: "https://external.com:30000"
trusted_proxy: "192.168.1.12"
Local traffic would originate from 192.168.1.0/24 network. Synology is acting as a reverse proxy and hosting MSR as a docker container (which has its own network and IP 172.18.0.5). MSR build is latest-26298-fbb75fb8
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
Using the above ACL works, but it enables access via proxy also. If I use source_ip: 192.168.1.0/24, then it doesn't work either locally or remotely. So I'm kinda lost what should I use as source_ip in this case?
I've seen many of you using Dynamic Group Controller. I'm using it myself for monitoring device battery levels. I've read and re-read the Dynamic Group Controller docs and still cannot come to an answer for my question so let me paint my scenario:
I've migrated from EchoSpeaks in Hubitat ('cause borked and seemingly unmaintained) to Alexa Devices in Home Assistant ('cause not borked in 2026.11.0) to be able to send TTS to my Echo devices.
In EchoSpeaks I could create groups. Sweet.
In Alexa Devices I don't seem to be able to do so. As such, my thought was "wait - isn't there a way in MSR?"
Is this an effective scenario that Dynamic Group Controller can be used for?
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
updates as operator is missing in MSR
Not missing, impossible.
Without knowing more, it's probably adequate for you to use changes in most cases. The updates operator was added to RFV to support two device types with special behavior: locks and scene controllers. Most people never use it if they don't use those device types.
