  3. Docker
  4. Openluup docker filling up disk space?
Moving to Docker
Docker
PerHP
Docker
InfluxDB 1.x in docker
PerHP
Docker
Grafana on Docker
Docker
4 Posts 2 Posters 1.5k Views 2 Watching
      Not seen this myself, but only started running Docker recently, and I'm certainly no expert on that.
        The answer was offcourse logs. I didn't put in any limit to it, so everything is stored!
        Found the solution here, update the docker compose files, and on we go. 🙂
          The solution i mentioned has a typo, this is what i added to the compose file:
          logging:
                  driver: "json-file"
                  options:
                      max-file: "5"
                      max-size: 10m
          with the "5" for max-file.
            156.2k
