  4. Status Tab Preview
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Status Tab Preview
20 Posts 5 Posters 2.6k Views 5 Watching
  • toggledbitsT Online
    toggledbitsT Online
    The status tab is starting to come together, and is supported in part by a new Alerts mechanism.
    This is the place for discussion about that. Please don't open PRs at this point, as I'm not finished with the work. I estimate I'm about half done with what I know I have to do so far, and I imagine more to come later. If you have bugs to report, I'll take them here in this thread.
      It's lookin' mighty good. Props to you, sir!
        Nice! is a "Changed by" (rule/expression) column in that lower table in the works as well? 😉
          toggledbitsT Online
          In the Entities? Probably not. How would I know what changed it?
          PerHP 1 Reply Last reply
          • MatohlM Offline
            MatohlM Offline
            Matohl
            Nice, good work! I wait with my suggestions until I see what you have in mind.
              The ALARM BELL already saved my bacon. A couple of otherwise "proven good" Rules evidently went rogue after I switched from detecting House Mode with Reactor (which yielded numbers 1, 2, 3, 4) to MSR's Vera > HouseMode feature (which yields strings "home", "away", "night" and "vacation"). This meant rewiring my logic flow, which got a bit out of kilter.
              Anyway, MSR's "Status" report caught some unexpected "NULL" evaluations in the Trigger conditions, which led me down the proper rabbit hole to fix those and get both Rules back on track.
              TIP: To account for the "NULL" condition (coming from a failed lookup in a "table" object I created -- see the ecobee plug-in is notorious for throwing an empty value back for Thermostat Mode in certain not-so-rare circumstances), I simply moved from:
              [ Expression Value ] [ modesMatch ] [ is FALSE ]  // was bombing when NULL
              to
              [ Expression Value ] [ modesMatch ] [ <> ] [ TRUE ]  // works when FALSE or NULL
              P.S. Oddly, the "Alarm Bell" icon remains %(#cc0000)[red] even after resolving the alerted conditions. (Solved with browser refresh)
                The new version with alert bell seems to have messed up the menu when viewing on my phone, even in desktop mode. I can't get to the top of the menu and rule sets etc.
                EDIT: MSR version 21091 fixes this issue
                  I also have this alert and cannot get rid of it when pressing the X
                    Vera "Rooms" are appearing in Recently Changed Entities for some reason ?
                    MatohlM 1 Reply Last reply
                      @toggledbits i'm thinking if some rule in reactor changed the state of the entity, it could be a column to identify that rule. changes done by others could simply state "other" or similar.
                      This is related to the other inquiry i had about entity change history..
                        toggledbitsT Online
                        Yeah, but there's no way to determine that.
                          MatohlM Offline
                          MatohlM Offline
                          Matohl
                          @cw-kid Same here. It is flooded by changes from the rooms 🙂
                            One of my Alerts says "
                            Unable to resolve global expression "timeStamp"
                            Last 22:23:06; this alert has repeated 3 times." ... yet I have no such variable. Perhaps I once did but not now that I can tell.
                              toggledbitsT Online
                              Something is referring to it...
                              ...and yes I realize I need to make finding that something easier but, steps... one thing at a time...
                                Just as:
                                Reaction task "66" failed due to an exception
                                TypeError: Cannot read property 'length' of undefined
                                Last 09:21:10
                                must point to /something/ but I stand to be educated on where to look. The reactor Log, perhaps?
                                EDIT: Found line by searching for "length" in reactor.log.1 (downloaded from Synology NAS). Doesn't specify exactly what component the problem is with, but it did name the affected Rule. I suspect it's to do with a long JSON string in one of its variables that happened to contain an empty array as a 'value'.
                                  toggledbitsT Online
                                  Yes, log. All kids love log.
                                    Do we really want disabled rules to appear among the list of Set Rules in status?
                                      Can confirm the new Alert notification is working in a Reaction and puts an alert right on to this Status page under Current Alerts.
                                        Neat! Will "clicking the red bell" eventually take us directly to the Alerts panel?
                                          Also, so as to minimize the number of "SET" (but otherwise inactive) Rules, I decided to change all of my
                                          [ Entity Attribute ]  [ X ]  [ is FALSE] // remains true indefinitely when OFF
                                          to
                                          [ Entity Attribute ]  [ X ]  [ changes ]  [ (any) ] to  [ FALSE ] // only true briefly when turned OFF
                                          Dunno if I'm OCD or just didn't want Status implying that something was "going on" when it's not. 🙂
                                            97.2k
                                          • Next Release?
