  4. TimeStamp variable in MSR
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 3 Posters 1.3k Views 2 Watching
  • E Offline
    E Offline
    Edwin1972
    In MSR I want to calculate the time in seconds between two actions. I use 2 variables. Time1 and Time2. The difference between the two actions is TotalTime (Time2 – Time1). Is it possible to write a timestamp to a variable in MSR?
      from the docs
      Time Handling Functions time( [ year [, month [, day [, hour [, minute [, second ]]]]]] ) — returns the current time if no arguments are given; otherwise a date/time is constructed using as many arguments as are provided; the result is a Unix Epoch time in milliseconds;
      http://192.168.1.10:8111/docs/Expressions-%26-Variables/#time-handling-functions
        You may recall I cooked up a human-readable "Timestamp" expression in MSR and posted the recipe here. But like @Elcid pointed to in the Docs, you can likely get away with just using ${{ time( ) }} in your [ Set Variable ] step, and simple subtraction in your Expressions area. Don't forget to divide by 1000 for seconds rather than milliseconds!
        • E Offline
          E Offline
          Edwin1972
          Thanks for the quick response! I'm going to try to use it in my logic
            162.5k
