  4. Feature request on reactions side.
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
37 Posts 4 Posters 7.1k Views 4 Watching
    Tarkus
    Secondary conditional rules on reactions.
    LibraSunL 1 Reply Last reply
    • T Tarkus
      @tarkus said in Feature request on reactions side.:
      Could you please expound further? My first guess is that you'd like to see a 2nd set of Conditions, which get evaluated later (e.g. after Set Reaction runs), in lieu of calling another Rule?
        I can give an example.
        I have a rule that turns off my garden lights at 12.30am every night via a schedule.
        In that rules "Set Reaction" I also wanted a http request to make a TTS announcement to my Google Home speaker.
        However I only wanted the http request to be sent if Vera was still in Home mode.
        If Vera is in Night mode and I'd already gone to bed, I didn't want the TTS announcement to occur at all.
        There was no way for me to do this in MSR that I could see, so instead I had to use Lua code in the "Set Reaction" and have Vera itself evaluate its current House mode status and send the http request or not.
        I was unable to have this additional condition (constraint) in the "Set Reaction" just for the http request part of the actions.
        I could of maybe created a second rule only for the http request action, but I don't want to create a bunch of other rules just for this type of thing.
          The rule that turns off your garden lights ("Garden Lights Off" ) will go true at the appointed time (presumably). This rule should not have the TTS request.
          A second rule ("Garden Lights Announcement") uses a Rule condition in its triggers to watch the Garden Lights Off rule, and has a constraint for Home mode. Set reaction is the TTS request.
          Done.
            Done.
            Yes that makes sense and I understand how that could work with two rules.
            But I didn't want two rules, so instead used Lua code initiated in my rules "Set Reaction", to determine Vera's current House mode status and have Vera send out the http request if in "Home" mode or NOT if in any other mode.
              Tarkus
              @librasun Sure I currently have lua that has multiple "if" conditions that is run on the reaction side. Consider these "if" conditions in the lua the secondary conditions.
              Usage senario:
              Say you have 3 separate expression / variables with varying values of 0-9 lets call them.
              Variable_1
              Variable_2
              Variable_3
              On the reaction side
              If variable_1 = 2
              Send TV IR code for digit 1
              If variable_1 = 2
              Send TV IR code for digit 2
              etc, etc
              delay 1 second
              If variable_2 = 1
              If variable_2 = 2
              etc, etc
              delay 1 second
              If variable_3 = 1
              If variable_3 = 2
              etc, etc
              • T Tarkus
                Usage senario:
                Variable_1
                Variable_2
                Variable_3
                If variable_1 = 2
                If variable_1 = 2
                etc, etc
                delay 1 second
                If variable_2 = 1
                If variable_2 = 2
                etc, etc
                delay 1 second
                If variable_3 = 1
                If variable_3 = 2
                etc, etc
                If I'm following your example correctly, each of your three variables can take on integer values from 0-9 inclusive, derived from the status of some device on Vera (I call it tv here for convenience). And you want to send three separate IR codes determined by each variable's value. Here's how I would do that in MSR (in pseudocode, of course):
                EXPRESSIONS:
                v1 := getEntity( "vera>tv" ).attributes.<attr>.<val1>
                v1 := getEntity( "vera>tv" ).attributes.<attr>.<val2>
                v1 := getEntity( "vera>tv" ).attributes.<attr>.<val3>
                buttonCodes := ["code0","code1","code2", ... ,"code9"]
                c1 := buttonCodes[v1]
                c2 := buttonCodes[v2]
                c3 := buttonCodes[v3]
                SET REACTION:
                [Entity Action] ["vera>device_<remote#>"] [x_service_name_send_code] [${{ c1 }}]
                [Delay] [ 1 ]
                [Entity Action] ["vera>device_<remote#>"] [x_service_name_send_code] [${{ c2 }}]
                [Delay] [ 1 ]
                [Entity Action] ["vera>device_<remote#>"] [x_service_name_send_code] [${{ c3 }}]
                What I'm doing is asking MSR to "lookup" the corresponding buttonCode from an array (conveniently indexed 0 through 9), assigning those string values to c1-c3, and making those substitutions in each successive steps of the Set Reaction.
                Am I close to your goal?
                  Tarkus
                  wrote on last edited by Tarkus
                  I am afraid the Global Cache IR plugin that Patrick added support for does not seem to work with expressions in the send code field. I tried to add the hex code for a digit to a Global expression and put ${{Digit_1}} in the send code field but it did not work.
                    Can you show me the valid values which the plugin accepts? (After all, they do exist and are transmitted by Lua, and I haven't yet encountered a value which MSR cannot send, so this makes me doubly curious.) Maybe I need to see more of your actual setup, if you don't mind?
                    FUN READ: https://kinkeadtech.com/control-ir-devices-with-z-wave/
                      Tarkus
                      @librasun
                      Patrick did say the Plugin was really barebone's or something to that effect.
                      IR.png-D5;,p-{in[ji1GS
                        @toggledbits can variable substitution be added to the "Code" field shown?
                          Variable substitution works in all action fields.
                            There you go! 🙂
                              Tarkus
                              yes, it just does not fire when putting the code into a variable.
                                Did you look in the MSR logs to see what was being sent? Did you look in the Vera log to see what was being received?
                                • T Tarkus
                                  Is MSR giving you any feedback in the Log and/or Status screen? I ask because perhaps you haven't used quotes around the hex code strings when defining your variables, for instance?
                                  T 2 Replies Last reply
                                    Tarkus
                                    Have not gotten that far. Just was playing around with this, this morning before my workday started. Will dig into logs when I get a chance.
                                      Tarkus
                                      @librasun Definitely did not use quotes, will try that.
                                        Tarkus
                                        @librasun Ok the quotes did the trick! So I am assuming for
                                        I am assuming I am making 10 variables. i.e.
                                        code0="0000 0067 0000 000D 0060 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 0422"
                                        ect, ect....
                                        • T Tarkus
                                          ect, ect....
                                          ect, ect....
                                          Okay, not exactly. In my example, above, I had intended for you to paste all 10 codes, with quotes, directly into the array itself. I now see how cumbersome that would look, and not lend itself very well to editing.
                                          So your approach of creating all 10 variables this way makes more sense... BUT you'd have to reference them in the array without quotes, as in:
                                          buttonCodes = [code1, code2, code3, .... , code9]
                                          and be sure to place this Expression definition after all 10 codeN declarations (this is just a best practice, not mandatory).
                                            998
                                            2.0k
                                            3.7k
                                            3.3k
