  4. Feature request on reactions side.
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
37 Posts 4 Posters 12.7k Views 4 Watching
  • T Tarkus
    @librasun Sure I currently have lua that has multiple "if" conditions that is run on the reaction side. Consider these "if" conditions in the lua the secondary conditions.
    Usage senario:
    Say you have 3 separate expression / variables with varying values of 0-9 lets call them.
    Variable_1
    Variable_2
    Variable_3
    On the reaction side
    If variable_1 = 2
    Send TV IR code for digit 1
    If variable_1 = 2
    Send TV IR code for digit 2
    etc, etc
    delay 1 second
    If variable_2 = 1
    If variable_2 = 2
    etc, etc
    delay 1 second
    If variable_3 = 1
    If variable_3 = 2
    etc, etc
    @tarkus said in Feature request on reactions side.:
    If I'm following your example correctly, each of your three variables can take on integer values from 0-9 inclusive, derived from the status of some device on Vera (I call it tv here for convenience). And you want to send three separate IR codes determined by each variable's value. Here's how I would do that in MSR (in pseudocode, of course):
    EXPRESSIONS:
    v1 := getEntity( "vera>tv" ).attributes.<attr>.<val1>
    v1 := getEntity( "vera>tv" ).attributes.<attr>.<val2>
    v1 := getEntity( "vera>tv" ).attributes.<attr>.<val3>
    buttonCodes := ["code0","code1","code2", ... ,"code9"]
    c1 := buttonCodes[v1]
    c2 := buttonCodes[v2]
    c3 := buttonCodes[v3]
    SET REACTION:
    [Entity Action] ["vera>device_<remote#>"] [x_service_name_send_code] [${{ c1 }}]
    [Delay] [ 1 ]
    [Entity Action] ["vera>device_<remote#>"] [x_service_name_send_code] [${{ c2 }}]
    [Delay] [ 1 ]
    [Entity Action] ["vera>device_<remote#>"] [x_service_name_send_code] [${{ c3 }}]
    What I'm doing is asking MSR to "lookup" the corresponding buttonCode from an array (conveniently indexed 0 through 9), assigning those string values to c1-c3, and making those substitutions in each successive steps of the Set Reaction.
    Am I close to your goal?
      Tarkus
      wrote on last edited by Tarkus
      I am afraid the Global Cache IR plugin that Patrick added support for does not seem to work with expressions in the send code field. I tried to add the hex code for a digit to a Global expression and put ${{Digit_1}} in the send code field but it did not work.
        Can you show me the valid values which the plugin accepts? (After all, they do exist and are transmitted by Lua, and I haven't yet encountered a value which MSR cannot send, so this makes me doubly curious.) Maybe I need to see more of your actual setup, if you don't mind?
        FUN READ: https://kinkeadtech.com/control-ir-devices-with-z-wave/
          Tarkus
          @librasun
          Patrick did say the Plugin was really barebone's or something to that effect.
          IR.png-D5;,p-{in[ji1GS
            @toggledbits can variable substitution be added to the "Code" field shown?
              Variable substitution works in all action fields.
                There you go! 🙂
                  Tarkus
                  yes, it just does not fire when putting the code into a variable.
                  LibraSunL 1 Reply Last reply
                    Did you look in the MSR logs to see what was being sent? Did you look in the Vera log to see what was being received?
                    • T Tarkus
                      Is MSR giving you any feedback in the Log and/or Status screen? I ask because perhaps you haven't used quotes around the hex code strings when defining your variables, for instance?
                      T 2 Replies Last reply
                        Tarkus
                        Have not gotten that far. Just was playing around with this, this morning before my workday started. Will dig into logs when I get a chance.
                          Tarkus
                          @librasun Definitely did not use quotes, will try that.
                            Tarkus
                            @librasun Ok the quotes did the trick! So I am assuming for
                            I am assuming I am making 10 variables. i.e.
                            code0="0000 0067 0000 000D 0060 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 0422"
                            ect, ect....
                            • T Tarkus
                              ect, ect....
                              ect, ect....
                              Okay, not exactly. In my example, above, I had intended for you to paste all 10 codes, with quotes, directly into the array itself. I now see how cumbersome that would look, and not lend itself very well to editing.
                              So your approach of creating all 10 variables this way makes more sense... BUT you'd have to reference them in the array without quotes, as in:
                              buttonCodes = [code1, code2, code3, .... , code9]
                              and be sure to place this Expression definition after all 10 codeN declarations (this is just a best practice, not mandatory).
                                Tarkus
                                @LibraSun So this is where I am at and I am stuck. The variable Channel gets pulled in from veras multistring and it gets split into the Character variables. That part works, just trying to work thru the rest.
                                  Tarkus
                                  I also forgot to mention that I need to work a "." into the array
                                    #23
                                    For starters, you've put spaces between buttonCodes and the [ which will not be interpreted correctly.
                                    Look above at my original example: the syntax is buttonCodes[index] with no spaces.
                                    (edit: extra spaces should be OK)
                                    Secondly, your definition of buttonCodes itself shows just a long comma-separated list, which cannot work as is. To make it an array, it must start with [ and end with ].
                                    Third, you reference buttonCodes in other variables, but named the expression ButtonCodes which is different. These things must match exactly.
                                    Fourth, some of your CharacterN definitions result in alphanumeric characters which are NOT "just 0 through 9" -- like "x" or "." -- hence they CANNOT serve as the index for an array lookup. Another approach is needed (example: use an Object, per the suggestion below).
                                    This is proving more challenging than expected -- even turning everything into an Object would pose its own hazards at this point -- but getting the syntax right is way more than half the battle!
                                      #24
                                      Also note that the data type of most of the index expressions is a string. Use int() to make sure it's a number: C1 = ButtonCodes[ int( Character1 ) ]
                                      Also, it may be useful to break everything out this way while you're testing and figuring it out, but ultimately, you may want to combine them: C1 = ButtonCodes[ int( substr( Channel, 0, 1 ) ) ]
                                        Tarkus
                                        The X's are just left over remnants of the lua process I was using. It was just padding and acted a indicator that the channel was at a end and stop the process. So channel 7.1 would come over as 7.1xx. I set 5 characters to accommodate a 5 digit channel i.e. 135.1 I will take a look at your suggestions.
                                          #26
                                          One technique I use involves setting up to "parallel" arrays, an example of which I'll outline here without explicit reference to the problem at hand. I hope to share the mechanics of it without clutter...
                                          value_I_have := getEntity(vera>source).parameter.i.want // result is "y"
                                          array_of_values := ["x","y","z"] // all possible  input values listed in some order
                                          array_of_codes := ["0123","2345","3456"] // desired converted output values for "x", "y" and "z"
                                          buttonPush := array_of_codes[ indexOf (array_of_values, value_I_have) ]
                                          Let that sink in a bit. In fact, if I were you @Tarkus , I'd mess around with abbreviated versions of this example in a throwaway Rule, just to get the feel for how each input affects the output.
                                            165.6k
