Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
Low-priority GUI feedback
@toggledbits said in Low-priority GUI feedback:
Here are the eyes in that library:
Though I don't "love" the eyes, I'm accustomed to them being used with Switchboard app (I believe), so I know they do the job.
We don't need "fancy".
@toggledbits I just happened to catch a glimpse, in Rule Sets with one of my Rules expanded, of the countdown displaying:
false as of 13:23:58 waiting 0-0:00:03
// then0-0:00:02
, then0-0:00:01
I believe...
instead of just:
false as of 13:23:58 waiting 0:00:01
02, 03, etc.
The extra '0-` bit disappeared after a few seconds, and only happened at the beginning of the count. (My constraint condition is supposed to be true for 60 seconds, and I was specifically watching it to monitor progress.) -
@toggledbits Nice touch allowing the Expression definition cells to be persistently resized. Really helps with large "Objects".
Also just noticing the A-Z sort button atop Rule Sets, which I haven't used yet, but that's a nice touch! New to 21096 or just me not noticing before? -
They're not really persistently resized, it's just taking a guess at the size needed based on the number of newlines, but wrapping of very long lines will probably goof it up. But, better than not doing it.
A-Z has been around for a very long time...
One thing that I do believe changed with the release of 21096 is that Rule Sets now resets to the topmost ruleset on each visit. Not sure that's a positive development...?
With about 20 Rule Sets, while editing a particular group (say "HVAC"), I may jump back and forth to Entities, Expressions, Scope, etc. then back to "HVAC".
Now, Rule Sets always snaps back to "Assistants" (that is, label nearest "A" -- I keep them alphabetically sorted). Do you have any user feedback to support that behavior? (I can live with it; it's just extra mouse clicks, lol) If not, I vote "go back to 'LastSelectedRuleset'".
IMPORTANT @toggledbits -- I wanted you to bask in this PR-free day, so am asking in the Forum instead:
If Rule A has nothing in the Set Reaction, I've noticed that it does not "trip" or "trigger" despite the Conditions being met. Consequently, another Rule B failed to execute with its otherwise automatic [Rule State] [Rule A Set] being true.Any immediate thoughts on this? And would my immediate "fix" be to include at least a "Comment" in Rule A's Set Reaction?
I know this is an edge case, but I have several rules like Rule A all grouped together, half with nothing in Set (almost as "placeholders" for when I think of actual stuff I want them to do).
I have tons of rules with no reactions. The setting and saving of the rule state is also quite separate in the code from the point where the reaction is selected and started (or not).
Anything logged?
If your Rule logging level is 5, there should be sufficient info in the logs for you to see "entity-changed" entries like this:
2021-04-09T01:55:23.325Z <Rule:5:Rule.js:466> Rule#rule-grpwswz9u9 dependency notification entity-changed Entity#house>device_6 from Entity#house>device_6 2021-04-09T01:55:23.325Z <Rule:5:Rule.js:479> Rule#rule-grpwswz9u9 requesting eval; entity-changed Entity#house>device_6
That will be followed by (possibly with stuff between):
2021-04-09T01:55:23.325Z <Rule:5:Rule.js:814> Rule#rule-grpwswz9u9 (Auto Fan On) evaluate() acquiring mutex 2021-04-09T01:55:23.326Z <Rule:5:Rule.js:820> Rule#rule-grpwswz9u9._evaluate() mutex acquired, evaluating
This indicates that the rule is setting up for evaluation (making sure it's not already doing an evaluation). Then:
2021-04-09T01:55:23.326Z <Rule:5:Rule.js:668> Rule#rule-grpwswz9u9 evaluateExpressions() with 0 expressions 2021-04-09T01:55:23.326Z <Rule:5:Rule.js:863> Rule#rule-grpwswz9u9._evaluate() trigger state now false (was false) 2021-04-09T01:55:23.326Z <Rule:5:Rule.js:871> Rule#rule-grpwswz9u9._evaluate() constraints state true 2021-04-09T01:55:23.326Z <Rule:null> Rule#rule-grpwswz9u9 rule state now false, changed no
The first of these lines indicates the number of expressions being evaluated, which is the first phase of rule evaluation. The next line follows the evaluation of the trigger conditions and gives the new trigger state and the prior state. The line that follows is the evaluation result of the constraints. The fourth line states the overall rule state, and if that's different from the prior rule state. It is after this last line that the reaction to run is chosen (it is only run if the rule state changed as shown in the last log entry).
Yup, it was the lock's fault. Seems to have significant lag sending over the "unlocked" status, so my Triggers got out of sync. Fixed!
Relieved to know that "empty" Rules are both permitted and normal.
It has to be, otherwise you would not be able to easily use them as building blocks for other rules. I do this extensively.
@toggledbits okay, I am ready to formalize this feature request:
Would you consider allowing the run reaction action to allow free form text entry, in such a way that you could still use the drop-down list of reactions, but you could also enter the canonical Rule ID either directly as a text string or via substitution?
I can see why you may not want to do this since it introduces the possibility of typographical errors.
The reason I'm asking is that I may want to set up a rule that acts as sort of a "director" that runs other rules based on a lookup. Of course I can currently do it in the reverse direction where those rules simply run based on the output value and that's that.Thoughts?
FEEDBACK @toggledbits Note how objects with "text" keys get sorted in "Last Value:" according to "numbers first then letters" (i.e. dictionary style) rather than the order in which keys appear in the Object declaration.
Probably not bothering most users, but could mildly disrupt workflow of someone who routinely copies "Last Value:" for Pretty Print purposes. I know I'd prefer original order.
Object properties (dictionary keys) do not have a deterministic or guaranteed order in JavaScript.
UPDATE: Seemingly resolved. Trivial. I added a "hold true for 2 seconds" on Trigger condition, the wait apparently needed in order for "turn ON" event (in Constraints) to be recognized on Vera. Funny, too, because that's the 1st action Alexa's routine issues. Lessons learned: (1) MSR's idea of synchrony is not always the same as my own; and, (2) Alexa may stutter when executing successive steps in Routines (WOW! Noticing gaps of up to 7 seconds here, sometimes Step 1 precedes Step 2, sometimes other way around!).
@toggledbits , pursuant to PR#164 (Closed), I'm unfortunately still grappling with a Rule that (SOMETIMES!) refuses to fire, even when all Conditions go TRUE virtually simultaneously. I may be the world's worst Log reader, but I think the following snippet of said Rule's evaluation process supports what I'm saying:
2021-04-13T14:43:07.810Z <Rule:5:Rule.js:749> Rule#rule-knay6sc6 dependency notification entity-changed Entity#vera>device_211 from Entity#vera>device_211 2021-04-13T14:43:07.811Z <Rule:5:Rule.js:755> Rule#rule-knay6sc6 requesting eval; entity-changed Entity#vera>device_211 2021-04-13T14:43:07.812Z <Rule:5:Rule.js:950> Rule#rule-knay6sc6 (Alexa Director (alexa)) evaluate() acquiring mutex 2021-04-13T14:43:07.813Z <Rule:5:Rule.js:954> Rule#rule-knay6sc6._evaluate() mutex acquired, evaluating 2021-04-13T14:43:07.813Z <Rule:5:Rule.js:958> Rule#rule-knay6sc6 update rate is 0/min limit 60/min 2021-04-13T14:43:07.814Z <Rule:5:Rule.js:880> Rule#rule-knay6sc6 evaluateExpressions() with 3 expressions 2021-04-13T14:43:07.815Z <Rule:5:Rule.js:970> Rule#rule-knay6sc6._evaluate() trigger state now false (was false) 2021-04-13T14:43:07.816Z <Rule:5:Rule.js:972> Rule#rule-knay6sc6._evaluate() constraints state false 2021-04-13T14:43:07.817Z <Rule:null> Rule#rule-knay6sc6 rule state now false, changed no 2021-04-13T14:43:07.936Z <Rule:5:Rule.js:749> Rule#rule-knay6sc6 dependency notification entity-changed Entity#vera>device_211 from Entity#vera>device_211 2021-04-13T14:43:07.938Z <Rule:5:Rule.js:755> Rule#rule-knay6sc6 requesting eval; entity-changed Entity#vera>device_211 2021-04-13T14:43:07.939Z <Rule:5:Rule.js:950> Rule#rule-knay6sc6 (Alexa Director (alexa)) evaluate() acquiring mutex 2021-04-13T14:43:07.940Z <Rule:5:Rule.js:954> Rule#rule-knay6sc6._evaluate() mutex acquired, evaluating 2021-04-13T14:43:07.941Z <Rule:5:Rule.js:958> Rule#rule-knay6sc6 update rate is 1/min limit 60/min 2021-04-13T14:43:07.942Z <Rule:5:Rule.js:880> Rule#rule-knay6sc6 evaluateExpressions() with 3 expressions 2021-04-13T14:43:07.943Z <Rule:5:Rule.js:970> Rule#rule-knay6sc6._evaluate() trigger state now false (was false) 2021-04-13T14:43:07.945Z <Rule:5:Rule.js:1578> cond cond6zfyayg evaluation state false->true 2021-04-13T14:43:07.946Z <Rule:5:Rule.js:1578> cond const evaluation state false->true 2021-04-13T14:43:07.947Z <Rule:5:Rule.js:972> Rule#rule-knay6sc6._evaluate() constraints state true 2021-04-13T14:43:07.948Z <Rule:null> Rule#rule-knay6sc6 rule state now false, changed no
i.e. both the Triggers and Constraints condition (one each) jump to TRUE, yet the Rule itself remains FALSE, leaving another Rule (which watches this one's state) flapping in the breeze.
Didn't wanna clutter Mantis with this, but happy to. First wanted to pass this by you here, so you could request files/evidence.
As additional background, what's supposed to happen is Alexa hears me utter a preset phrase, causing an Alexa Routine to run. It runs fine (I know because she speaks and turns on music) and performs the two steps (turning on a VS on Vera and dimming another one to a specific value), which I see go "green" in MSR. And yet, as described herein, the Rule itself just sits idle.
Thanks for any guidance here!
- LS
2021-04-13T14:43:07.943Z <Rule:5:Rule.js:970> Rule#rule-knay6sc6._evaluate() trigger state now false (was false).
This is saying the trigger state is false. It says that in both cases. It follows by saying the rule state is false (which is correct if the triggers are false). The constraints are indeed true, but if the triggers are false, the rule state will still be false.
Much appreciated, and sorry for the n00b question. I've spent the morning chasing down gremlins left and right surrounding this "Alexa Director" endeavor, and I give up. I inadvertently created a thicket of Franken-Rules which deserve to go back into the grave.
Think I'll stick with Virtual Switches after all, as they are far more deterministic, predictable, and UI friendly than any attempt I've made thus far to reinvent them with pure logic.
Ha ha, I was having Triggers accidentally trigger multiple Rules and then, once tightened down even further, NONE of the Rules.
I will henceforth regard the VS as a necessary resource on Vera, especially when used as an adjunct to Alexa Routines.
Not a n00b question at all. I'd really like to see for myself what's happening. If you still experiment with it more, crank the rule's log level to 6, and send me the results.
I'm sure to fiddle around further, but intend that to happen with inconsequential test Rules rather than some of my most prized "Leaving Home", "Coming Home" level workflows.
Will advise... thx.
P.S. You may legitimately ask, "Why are you trying to avoid Virtual Switches in the first place?" Answer: Because I hate having to create them, configure them, propagate them through the Vera UI (rename, relocate, hard refresh) and again through the Alexa ecosystem (name, discover, configure in Routines, etc.). I've been searching for a quick-to-expand alternative method, one that presents itself in all four UIs (Vera, MSR, Alexa, VeraMobile) with rapid adaptability to new workflows (e.g. "Time for Doing a Puzzle") which I might in turn choose to knock down after a few days.
