  4. Build 21117
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Build 21117
19 Posts 3 Posters 2.3k Views 3 Watching
    "This feature applies to rule-based reactions only; it is not a feature of global reactions (and for the removal of doubt, will not be in future)"
    Good news about the option for additional further conditions within actions.
    I have a few existing rules I can rebuild for this new feature.
    Also If not with Global Reactions, will we at some point be able to initiate a rule sets actions via a http request sent in to MSR?
    And have no other trigger on that rule set?
    A manually triggered "scene" if you like.
      You already can, and it works great. See @toggledbits separate post about the MSR API for a current list of HTTP requests you can send.
      So long as you predicate your Rule with a Trigger that watches an Expression Value, all you need to do is send that value. Ideally, your Rule (or another one) would 'reset' the empty variable. I like to name these watched variables things like "Do", or "Go" or "Run". The setup can be as simple as letting 0 be the resting state, and the Trigger can watch for (changes) from (0) to (1), or even just [ <> ] [ 0 ].
      Send an HTTP request to set that variable to something non-zero to cause the Rule to execute.
      Later, perhaps in the Reset Reaction, set your "Run" variable back to 0. Works like a charm!
        OK thanks I didn't know we could do that. That should work also as you suggest.
        I'll give it a try and ask you if I get stuck 😁
          Presumably you could only have one expression variable named "Run" for that particular rule set.
          So we need a differently named expression variable for each rule set we wanted to trigger in this manner.
          Not too much of a problem if we don't have too many of them.
            In a fancy pants setup, you could designate a single (again, empty/expressionless) Global Expression called "Run". Create an auxiliary Rule whose sole purpose is to 'reset' that expression back to 0 (after a nominal 2-second delay, say) whenever it changes.
            You could then Trigger an almost infinite number of other Rules, each with a Trigger watching for [Expression Value] [Run] [changes] from [0] to [N] where N is that Rule's assigned trigger. So long as you don't anticipate too much traffic of this type - in other words, whereby incoming HTTP Set commands trip over each other - such a setup should work smoothly and consistently.
            PRO TIP: Knowing that I will forget these N assignments, I always place a Comment with notes, or even a hand-built Object in an Expression somewhere, reminding me...
            1 = Lights Out
            2 = Time for Bed
            12 = Nightlight Toggle, etc.
              OK I think I get what your suggesting. We can just have a Global Expression named "Run" and it can have any number value set via a http request sent in to MSR 1,2,3,4 or whatever and then your different rule sets would monitor for their trigger that run =1 or run =2 etc.
                If that is possible then it kinda makes Global Reactions redundant.
                  Yes and no. My only use case for Global Reactions has been rare times when I want to call the exact same routine from multiple other Rules, without it living inside yet another Rule. Good for compactness and ease of editing. Otherwise, I never use Global Reactions.
                  EDIT: Just looked again. I have none! 🙂
                    @librasun said in Build 21117:
                    That's true I didn't think of that use case.
                    I have only been using Global Reactions like manually triggered Vera scenes, as I could send a http request in to MSR and have that Global Reaction run.
                    However Global Reactions have limitations e.g. they have no contraints / conditions.
                      @LibraSun
                      Do you have an example URL to set a Global Variable ?
                      variable/:name/set - (PUT) set the global variable specified to a value (JSON data); the request body must be application/json type.
                      How do you specify your value for the variable ?
                        I just updated to this build I think:
                          To me this reads like we won't be able to send a simple one line HTTP request to MSR to change a Global Variable to trigger a Rule Set:
                          Which if so, this probably isn't going to work for me.
                          Its difficult enough already to have the Home Remote dashboard app send out a HTTP Request when a dashboard button is pressed.
                          If I have to also contend with a request body and having to specify application/json type etc, I don't think I'll be able to do it,
                            I can't even seem to get Postman working as a test.
                            Trying to set the Global Variable named "run" to a value of "3"
                            <pre>SyntaxError: Unexpected token 3 in JSON at position 0<br> &nbsp; &nbsp;at JSON.parse (&lt;anonymous&gt;)<br> &nbsp; &nbsp;at createStrictSyntaxError (/home/pi/Documents/reactor/node_modules/body-parser/lib/types/json.js:158:10)<br> &nbsp; &nbsp;at parse (/home/pi/Documents/reactor/node_modules/body-parser/lib/types/json.js:83:15)<br> &nbsp; &nbsp;at /home/pi/Documents/reactor/node_modules/body-parser/lib/read.js:121:18<br> &nbsp; &nbsp;at invokeCallback (/home/pi/Documents/reactor/node_modules/raw-body/index.js:224:16)<br> &nbsp; &nbsp;at done (/home/pi/Documents/reactor/node_modules/raw-body/index.js:213:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/Documents/reactor/node_modules/raw-body/index.js:273:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (events.js:314:20)<br> &nbsp; &nbsp;at IncomingMessage.EventEmitter.emit (domain.js:483:12)<br> &nbsp; &nbsp;at endReadableNT (_stream_readable.js:1241:12)</pre>
                              @toggledbits to the rescue??
                              FWIW, I'm on rev. 21117 and currently do not have any inbound HTTP calls in my workflow. Wish I could help you more!
                                Quick question for @toggledbits ...
                                Will having a Constraint Group in Reset Reaction -- all by itself, doing nothing, and with no other Actions defined in the R.R. -- cause the Rule to stop the Set Reaction mid-stream if the Rule goes unset? And if so, will that behavior manifest only when the R.R. Group is TRUE?
                                Or will MSR be agnostic towards orphaned/FALSE Constraint Groups in the R.R., allowing the S.R. to run to completion. I'm thinking that's how most users would expect things to go, but felt it prudent to inquire. Thanks!
                                  Facts:
                                  1. Reactor only looks at the number of actions on the reaction to determine if it is "runnable" as a counter-reaction.
                                  2. Constraints are evaluated, which is to say, their states are determined, at the same time the triggers are evaluated, including constraints in action groups (so before either the SET or RESET reaction is run, the constraint states have already been determined).
                                  3. Constraints are considered for logic purposes only at the time they are applicable: the rule constraint state is only considered if the rule is transitioning from reset to set and is preparing to run the SET reaction; reaction constraint states (regardless of location) are only considered at the moment the group is encountered during the reaction run.
                                  4. When a reaction is stopped, all child reactions (i.e. groups, with or without constraints) are stopped as well. So if a set rule resets with a runnable RESET reaction, and there are still groups running from the SET reaction, the remaining SET reaction groups will be stopped together with the SET reaction itself.
                                    @cw-kid said in Build 21117:
                                    Documentation fail. The PUT body needs to look like this:
                                      "name": "<variablename>"
                                      "value": <new value, any valid JSON type>
                                    The variable name given must match that in the URL.
                                    I just added a GET for this as well just for simplicity/basic use only, to be in next build:
                                    http://msr-ip:8111/api/v1/variable/testme/set?value=123
                                    In this case, the value set will always be a string type, because that's what query parameter values are.
                                    cw-kidC 2 Replies Last reply
                                      @toggledbits said in Build 21117:
                                      Perfect thank you
                                        How will subsequent updates to the Docker image be managed after rev. 21117? I'm uncertain whether the Synology NAS > Docker > Registry approach to things means we no longer have to download new Image files and re-launch the Container. Would love to have an Auto-Update option somewhere in the mix.
                                        • Next Release?
